20 Most Recent
Nikon COOLPIX S8 Digital Camera Questions & Answers
Error lensa
You mean "lens error" this will need to be fixed by camera tech, this is not a user fix and there is no magic button to cure the problem.
How can i put wallpaper in display
If you are using Mozilla Firefox you can simply right click and click set to desktop(or something along those lines) If not, download the picture open with a picture viewing tool you have preinstalled and do the same thing.
I need software to install
You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
I accidentally put my new
With your left thumb, press the button on the back of the camera that says "ISO."
While holding this button in, use your right thumb to rotate the rear control dial (located at the top right corner of your camera).
Look at the window on the top to watch the numbers change. Stop when you get to the one you want to use.
Source(s):
http://www.jimsdigitaldiary.com
Lense error
try these:-
- connect it to pc and on it
- vaccum the barrel of lens
- changing mem. card and batt. for 2min.
- shake it.
- on and off in different positions
- hit the part near lens softly with palm (trust me this made mine work)
Lens cover error
try these:-
- shake it.
Just bought Nikon p600 and cant connect to WiFi help
U need to download nikon wmu software from google playstore or appstore. Then start wifi of ur camera and then start wifi connection in ur mobile.select "nikon p600" in wifi setup.when connected, start application named "wmu" in ur mobile.wait for the connection.after few seconds wifi connection will be established.hope this would help u!
