All the ignitors simultaneously popping unless unplugged
Usually this is from moisture getting into a spark ignitor switch, which is located under your burner knobs. A pan boiling over, someone cleaning your cooktop and using a sprayer, too much water on a sponge, very high humidity, can all get moisture into a switch. Recommend you unplug your cooktop for a few days and see if your switch dries out. Plug it back in an see if it works properly again. If it doesn't then you will have to replace one, or all of the switches, depending if they come seperately or in a set. This entails removing the top of the cooktop, which can be very difficult if not impossible in some cases. Heat and corrosion go together, so in just a few years the screws or nuts that hold the burners down onto the cooktop are so corroded that you cannot remove them without chiseling the nuts off or drilling out the screws, which then damages the burner bodies underneath. Can make it unrepairable in some cases. Drying the unit out works about 80% of the time. Good Luck, Appliance Specialists
12/23/2009 1:57:56 AM •
Whirlpool...
Answered
on Dec 23, 2009
