20 Most Recent Panasonic KX-TG6702B Twin Cordless Phone Questions & Answers
0answers
Caller I D doesnt work line to house is good batteries are new
It would be worth contacting your service provider to determine if your subscriber settings for the caller ID service are active. Talking Caller ID Handset Dial #162 then 1 on 0 is off Base Unit caller id Dial #*162 1 on 0 is off Guess this toggles it from 1 or 0 in the settings http://eng.faq.panasonic.com/app/answers/detail/a_id/20750/~/troubleshooting---caller-id-is-not-working. You might unplug the base station for a few seconds and then plug it back in. It might restore the function. http://phone.manualsonline.com/manuals/mfg/panasonic/kx_tg6702_1.html
11/26/2017 9:25:15 PM • Panasonic... • Answered on Nov 26, 2017
Caller ID still not right
I have the same problem. By chance are you using Verizon FIOS? One line is VOIP and shows CallerID and the other does not.
10/6/2009 10:08:53 PM • Panasonic... • Answered on Oct 06, 2009
2answers
How do u get your Panasonic house phone working model number is kxtga850e keeps saying no link to base reconnect main base ac adaptor
It sounds like the phone system base station is burned out.
2/3/2024 8:19:25 AM • Panasonic Lands... • Answered on Feb 03, 2024
My phone is always on MUTE. How do I turn that off?
Press the mute button to turn mute off.
12/27/2023 5:21:29 PM • Panasonic Lands... • Answered on Dec 27, 2023
How i can change panasonic kx ts500mxw ring tone
I don't think that is possible on that model of phone. This is a phone with only the basic features and a fixed ringtone.
12/21/2023 9:33:34 AM • Panasonic Lands... • Answered on Dec 21, 2023
Panasonic KX-FLB 852 Call Service 6 problem
See Section 6 (Troubleshooting) Section of Service Manual and Page 118 for remedial action. Troubleshooting Guide; User Recoverable Errors - Panasonic KX-FLB852CX Service Manual [Page 81] ' ManualsLib
11/3/2023 10:16:44 AM • Panasonic Lands... • Answered on Nov 03, 2023
2answers
One Panasonic KX-T7633 Phone Not Showing Caller ID
What did you dial when checking voice mail?
10/23/2023 1:24:07 PM • Panasonic Lands... • Answered on Oct 23, 2023
Panasonic portable phone KX-TGD 530 manual
Panasonic has the manual for the KX-TGD530 cordless phone system with digital answering machine here: https://help.na.panasonic.com/telephones-fax/telephones/kx-tgd530/ . Note: the manual covers several models, including some without the answering machine feature. The current link to the manual is https://help.na.panasonic.com/wp-content/uploads/2023/02/KXTG3712_TG372x_TG373x_TG732SK_TG733SK_TG734SK_TGD43x_TGD51x_TGD53x_PNQX8349YA_ENG_ESP.pdf . I hope this helps. Cindy Wells
10/19/2023 9:30:40 PM • Panasonic Lands... • Answered on Oct 19, 2023
I'm having trouble pairing to a Panasonic su htb 350 from my phone
Refer to Page 27 of user manual of your speaker system (Panasonic Sc Htb350 Owner S Manual (usermanual.wiki)) Follow the procedure given. I hope your issue will be resolved.
9/14/2023 1:44:28 PM • Panasonic Lands... • Answered on Sep 14, 2023
2answers
I have lost the voicemail on my KX-DT343 it now has reorder showing and no message
You can download the manual and "File/Save As" to your Documents folder from here (under "Resources")...
9/3/2023 12:46:32 AM • Panasonic Lands... • Answered on Sep 03, 2023
Panasonic KX-T7433 CO Not Assigned Error
The "CO Not Assigned" error on your Panasonic KX-T7433 handset indicates that the Central Office (CO) line has not been properly assigned to the handset. Since you've mentioned that other handsets in your office can connect to CO-01 without any issues, the problem seems to be specific to certain handsets. Here are a few steps you can take to troubleshoot and potentially resolve this issue:
  1. Restart the Handset: Sometimes, a simple restart can resolve temporary glitches. Try unplugging the handset's power cord for a few seconds and then plugging it back in.
  2. Check CO Assignment: Double-check the CO assignment settings on the problematic handsets. Make sure that the CO-01 line is correctly assigned to those handsets. Follow these steps:
    • Press the "Program" button on the handset.
    • Dial 1 (CO Line Access).
    • Dial the line number you want to assign (in your case, 01).
    • Press the "Auto Dial/Store" button to save the assignment.
    • Hang up the handset.
  3. Reset the Handset: If reassignment doesn't work, you can try resetting the handset to its default settings. Keep in mind that this will erase any customized settings on the handset. To perform a reset:
    • Make sure the handset is not in use.
    • Press and hold the "Program" button while you reconnect the power cord.
    • Keep holding the "Program" button until the handset displays "Initializing..." and then release the button.
    • The handset will restart and return to its default settings. You'll need to reconfigure any personalized settings afterward.
  4. Firmware Update: Check if there are any firmware updates available for the Panasonic KX-T7433 system. Outdated firmware can sometimes cause compatibility issues. Refer to the user manual or Panasonic's official website for instructions on updating the firmware.
  5. Contact Panasonic Support: If none of the above steps resolve the issue, it might be best to contact Panasonic's customer support. They can provide specific guidance based on your model and system setup.
  6. Physical Check: Ensure that the physical connections and cables related to the CO-01 line are secure and functioning properly. A loose connection could lead to communication problems.
Keep in mind that these steps are general suggestions and may need to be adjusted based on the specific model of your phone system and any unique configurations in your office. If you're not comfortable performing these steps yourself, it's recommended to seek assistance from a professional technician or the manufacturer's support team.
8/9/2023 5:52:14 PM • Panasonic Lands... • Answered on Aug 09, 2023
Why does my Panasonic KX-TGM420 go straight to voice mail?
Voicemail is a service of your telephone company. If your calls are going to voicemail, check the settings following the directions for the service. If the answering system is getting the calls, then check if the KX-TGM420 handset(s) and base are set to a ringer volume of 0. You can change this from either the base or a handset by pressing the + button while the phone is ringing. Otherwise, when the phone system is in standby (no calls in or out), press # 1 6 0 on a handset or * # 1 6 0 on the base. Then set the ringer volume on the handset (0-6) or base (0-10). This is the equivalent of pressing menu and navigating through the menu (Menu > Settings > Ringer Adjustment > Ringer Volume (Incoming)). You can also turn off the ringer by pressing and holding 0 on the handset and Ringer Off on the base. See pages 33 and 44 of the manual, link below. I hope this helps. The manual is available here: https://help.panasonic.ca/viewing/ALL/KX-TGM420/OI/TGM420_PNQX7794YA/TGM420_PNQX7794YA.pdf . Cindy Wells
6/30/2023 2:47:46 AM • Panasonic Lands... • Answered on Jun 30, 2023
I have a panasonic home phone want to remove the voice mail sign and light flashing
To remove the voicemail indicator and stop the flashing light on your Panasonic home phone, you can try the following steps: 1. Access the voicemail system: Dial your home phone number from your Panasonic phone or another phone and let it ring until it goes to voicemail. Enter your voicemail password or follow the prompts to access your voicemail messages. 2. Listen to and delete all voicemail messages: Check your voicemail inbox for any new or saved messages. Listen to each message and follow the instructions to delete them. Ensure that your voicemail box is empty. 3. Exit the voicemail system: Once you have listened to and deleted all voicemail messages, exit the voicemail system by following the prompts or hanging up the call. 4. Reset the phone: Disconnect the power adapter from the back of your Panasonic phone base unit. Wait for about 30 seconds and then plug the power adapter back in. This will perform a reset on the phone and clear any residual indicators. 5. Check the voicemail indicator: After the phone has rebooted, check if the voicemail indicator is still active or if the light is still flashing. If the issue persists, proceed to the next step. 6. Disable visual voicemail feature (if applicable): Some Panasonic home phones offer a visual voicemail feature that may trigger the voicemail indicator and flashing light. To disable this feature, consult the user manual for your specific model and follow the instructions to turn off the visual voicemail function. 7. Contact Panasonic support: If you have followed the above steps and are still unable to remove the voicemail indicator or stop the flashing light, it's recommended to contact Panasonic customer support for further assistance. They can provide specific guidance based on your phone model and help troubleshoot the issue. Remember to consult the user manual for your Panasonic home phone model as the steps and features may vary slightly. this video might help
6/21/2023 2:00:52 AM • Panasonic Lands... • Answered on Jun 21, 2023
How to resolve continous tone on KX-TX880MX deskphone that locks you out of use
The recurring issue you are experiencing with the KX-TS880MX phones emitting an intrusive noise/continuous tone can be frustrating. There could be several potential causes for this problem. Here are a few suggestions to help you troubleshoot and potentially resolve the issue: 1. Interference: Check if there are any sources of interference near the affected phones, such as other electronic devices or power sources. Move the phones away from potential sources of interference and observe if the issue persists. 2. Faulty Phone Line: Ensure that the phone line connected to the affected phones is not damaged or experiencing any issues. Try connecting the affected phones to a different phone line or port to see if the problem persists. 3. Firmware/Software Update: Check if there are any firmware or software updates available for the KX-TS880MX phones or the TDA600 Panasonic system. Updating the firmware or software can often resolve compatibility issues and fix known bugs. 4. Reset and Reconfiguration: Perform a factory reset on the affected phones and reconfigure them on the TDA600 Panasonic system. This can help eliminate any software glitches or misconfigurations that may be causing the problem. 5. Contact Panasonic Support: Reach out to Panasonic's customer support or the dealer from whom you purchased the phones. Describe the issue in detail and inquire if they have encountered similar problems with this particular model. They may be able to provide specific troubleshooting steps or offer a solution. If none of the above steps resolve the issue, and the problem persists only with the KX-TS880MX model phones, it's possible that there may be a defect with those units. In such cases, replacement or repair may be necessary.
6/21/2023 1:02:35 AM • Panasonic Lands... • Answered on Jun 21, 2023
Panasonic KX-TG6702B Twin Cordless Phone Logo
7 questions posted
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
caller d doesnt work line house good
  • Lands Phones
