20 Most Recent Logitech Harmony 670 LCD Remote Control Questions & Answers
Logitech Harmony 670 remote stuck on Safe Mode.
1. Remove the batteries. While holding the 2 button down, connect the USB cable. The remote will boot into normal mode. Did this fix the problem? If no, please continue to troubleshoot.
ANSWER:
2. Update the firmware. Update the configuration. Did this fix the problem? If no, please continue to troubleshoot.
ANSWER:
3. There could be a stuck button on the remote causing the symptom. Remove the batteries from the remote. Push in, and massage each button ensuring it is not stuck down. Replace the batteries and Update the firmware. Update the configuration. Did this fix the problem? If no, please continue to troubleshoot.
ANSWER:
4. Remove the batteries from the remote. Manually place the remote into `Safe Mode` by holding off and plug in the USB. Upgrade the firmware in the remote. Update the configuration. Did this fix the problem? If no, please e-mail us back for further information about your issue.
ANSWER:
FIRMWARE:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
8/31/2018 8:19:45 AM • Logitech Harmony... • Answered on Aug 31, 2018
How do I get to the ''Menu screen'' when playing a DVD movie?
It's likely the remote has the wrong code, so it will only work certain functions. You need to try lots of codes, if you do not know the player's code, till ALL function buttons work, not just some.
8/9/2017 4:08:24 PM • Logitech Harmony... • Answered on Aug 09, 2017
Actually it's a harmony 600, not 670. Can't get it to work with Daenyx tv, any suggestions?
Contact the manufacturer's customer support center.
5/25/2016 7:28:29 PM • Logitech Harmony... • Answered on May 25, 2016
M670 instructions for use on a pc it is a mouse thing
Is this the manual you are looking for?https://docs.sony.com/release/CDXM670.PDFor thishttps://www.jlmwholesale.com/sites/default/files/brochure/M670_680_Installation_Instructions.pdf Actually I can't fing any other device with the model number you indicated. Maybe you should be more specific with your thingy...
7/2/2015 9:24:43 PM • Logitech Harmony... • Answered on Jul 02, 2015
0answers
How do I reprogram for a new brand dvr?
Download the user manual to your remote control for more details about setup. It will be best for you to visit this site, I assumes. It helps me so much to get answers to to many problems. The site name is <Electro-help>. Google for it. it is an electronic equipments service help site. you can locate this site, either at the bottom of the first page or at the top of the second by Google search. The site will appear as it is stated above, and is a blogspot site. Im sure that you can gather all details you want.
6/15/2012 5:57:15 AM • Logitech Harmony... • Answered on Jun 15, 2012
Configure AV on Bush TV with BD 512
022
2/4/2012 9:40:53 PM • Logitech Harmony... • Answered on Feb 04, 2012
Locked in safe mode
Hi. Here is how to get your remote out of safe mode.
1. Connect your remote to the computer.
2. Launch the Harmony Remote Software, and log in.
3. Click "Downloads" at the top and click "Firmware"
4. The remote will go through the firmware update.
5. Select "Yes", and click NEXT to update the remote.
Voila! Hope this helps.
12/31/2011 1:19:11 PM • Logitech Harmony... • Answered on Dec 31, 2011
Getting the System 1 Error:
Hi. Sadly I have some bad news for you. "System error 1" on a Harmony remote means that there is a hardware failure in the memory module of the remote. This can not be fixed by updating the firmware. When I contacted Logitech about this issue in the past, they replaced my remote because it was still in warranty, I would advise getting in contact with them to get it sorted out.
7/28/2011 5:37:13 PM • Logitech Harmony... • Answered on Jul 28, 2011
Put in new batteries
Hi. Safe mode is just the remote protecting itself from either a power surge or corrupt firmware. All you need to do to get the remote out of safe mode, is update the firmware.
1. Launch the Harmony software and log in to your account. 2. Connect your remote to the computer. 3. Click on the downloads link at the top of the page. 4. Click firmware. 5. Once the firmware is done updating, update the configuration by clicking "Update Remote."
Hope this helps
7/27/2011 3:46:02 PM • Logitech Harmony... • Answered on Jul 27, 2011
I had to change the batteries three times
I think there is a bridge on/in the battery terminal. When a battery bridges, it becomes hot.
Remove the batteries from the remote. Get a screw driver and carefully disassemble the remote without breaking or damaging anything.
Check the battery terminal and make sure there is not bridge.
When I say bridge, I mean positive (+) and negative (-) touching together together which is not suppose to be.
Make sure no part is touching each other, assemble the remote and try again.
I hope you understand the point I am trying to make.
Good luck.
2/22/2011 7:51:40 PM • Logitech Harmony... • Answered on Feb 22, 2011
My logitech harmony 670 remote no longer
my harmony has a help feature on it have you tried walking through that? if not then after that try to reset the tv within the remote software then try again ok :) good luck with it
12/21/2010 2:35:39 AM • Logitech Harmony... • Answered on Dec 21, 2010
My remote will not go off of safe mode
have you contacted Logitech support and asked them after searching for over a hour i can not find anything to do with safe mode for Logitech Harmony® 670 LCD Remote Control
8/29/2010 7:11:30 AM • Logitech Harmony... • Answered on Aug 29, 2010
Replaced batteries in Harmony 670. Does not work shows "Safe Mode
Update the firmware:
- Launch the software. - Connect the remote. - Click "Downloads" - Click "Firmware." - Update the remote.
That will get the remote out of safe mode.
7/18/2010 6:14:27 PM • Logitech Harmony... • Answered on Jul 18, 2010
Lost directions to set up
Hi. To set up your harmony remote, you will need to download the software. To do this, visit http://logitech.com/myharmony and click "Downloads."
6/26/2010 7:16:05 PM • Logitech Harmony... • Answered on Jun 26, 2010
Where to find lcd screens for Harmony 676 remote
Logitech does not sell the screens of the remote unfortunately. If I were you I would go on eBay and buy a second hand remote cheap for the screen. I did that one time and it worked out great!
6/13/2010 7:20:46 PM • Logitech Harmony... • Answered on Jun 13, 2010
Logitech Harmony 670 LCD Remote Control Logo
104 questions posted
Top Logitech Televison & Video Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Televison & Video
Most Popular Question
put in new batteries
  • Televison & Video
