20 Most Recent Logitech Harmony One Advanced Universal Remote with Color Touch Screen Questions & Answers
Tv wont go to hdmi1 and is stuck on dvd.
I think what is happening with your tv is it does not see the signal. If there is no signal going to the tv it will not let you select the source you like, in this instant HDMI 1. What you probably need to go do is look at you dishtv set top box and go to that box's menu and enable hdmi output. Hope this helps.
4/14/2020 2:04:48 PM • Logitech Harmony... • Answered on Apr 14, 2020
0answers
Watch netflix
3/1/2016 11:09:22 AM • Logitech Harmony... • Answered on Mar 01, 2016
3answers
My Harmony One won't charge. It's in its cradle.
I recently had this same problem. The remote displayed a "low battery" warning and could not be used, so I left it on the charger overnight and the next morning, it still had no charge. Everything seemed to be fine (and I verified that it was making good contact with the charger), but it wouldn't charge.Finally, I pulled out the battery to see if there was any obvious problem. There didn't seem to be, but when I put the battery back in, the remote suddenly started working (and showed about a 75% charge).So far, it seems to be working (and charging) correctly since then.
1/26/2016 6:42:47 PM • Logitech Harmony... • Answered on Jan 26, 2016
Why won't it charge right? Is it the battery that needs to be fixed or replaced?
replace battery, is a cheap fix
12/15/2015 2:51:55 AM • Logitech Harmony... • Answered on Dec 15, 2015
2answers
Error code 054 on the harmony one
Hmm I havent heard of this before. Did you try updating the firmware on the remote?
1. Remove the battery, press and hold the 'OFF' button, and re-insert the battery. The screen will display 'Safe Mode!', or the 'Activities' button will be lit.
2. Connect your remote to the computer.
3. Launch the Harmony Remote Software, and log in.
4. Click "Downloads" at the top and click "Firmware".
5. The remote will go through the firmware update.
6. Select "Yes", and click NEXT to update the remote.
What exactly does the error message say?
5/11/2015 11:39:52 PM • Logitech Harmony... • Answered on May 11, 2015
How can i change the buttons on logitech one. they are getting worn out
The best solution is to get a new one, the buttons are not considered a user replaceable item. Try these links for a replacement: Harmony Ultimate Home Home Automation Remote Roomie Remote iPhone and iPad Universal Remote Control for Home Theaters Your search for universal remote returned the following
3/3/2015 1:55:15 AM • Logitech Harmony... • Answered on Mar 03, 2015
How do I adjust color on my Sony tv with Shaw universal remote?
Take your Shaw remote control, and follow the instructions on the back. If that does not work, telephone Shaw, and ask for technical support for TV. Once it is setup, press the TV button on the Shaw remote control, and press the MENU button. That should show the TV's "setup" menu.
3/2/2015 5:38:06 AM • Logitech Harmony... • Answered on Mar 02, 2015
2answers
Can I replace a broken lcd display on my harmony one
I think yes, take a look on amazon for replacement: Harmony Ultimate Home Home Automation Remote. Wish you best of luck. Bill
1/11/2015 7:30:27 AM • Logitech Harmony... • Answered on Jan 11, 2015
I have a Sony bravia tv and. Harmony 1 universal remote. How do I turn on closed captioning?
The problem with universal remotes is that they are just that - universal. They are good at doing all the normal things that TVs do, but often cannot or do not have the programming to do the subtle things that the manufacturer's remote can do.
12/31/2014 5:12:31 AM • Logitech Harmony... • Answered on Dec 31, 2014
2answers
No sound on tv chanel
hi, no sound with tv but have picture, also have lost sky but works on other tv with a tv link, tv make LG Lh3000
11/20/2014 6:56:54 PM • Logitech Harmony... • Answered on Nov 20, 2014
I do not want to use my logitech any more, how do I disconnect it
You can repair it. The infrared emiting diode is dead, replace it with a new infrared diode. You can buy it in electronic components shops. Regards.
9/2/2014 8:48:38 AM • Logitech Harmony... • Answered on Sep 02, 2014
Can harmony touch work in country with 220 volt. Does it control the home theatre lights also
Hello, Your Logitech remote should be able to work on a 220 volt system so ling as the AC adaptor that plugs between the wall and the charger is rated 110-220v. Unplug it from the wall an read what it says on the outside. In should say "Input 110-220v" to be safe to put on a 220 system. If it is only rated 110v input power, you may need to purchase a universal power adaptor in order to provide power to the charging cradle. Another solution is to buy a "power transformer" which is a box that plugs into the wall and steps down the voltage and provides an outlet that can be used to power multiple 110 devices. What ever you do, do not plug in a 110v only device into a 220v circuit. If you do, it will "fry" the electronics rendering them useless, but it could potentially even start a fire. With regard to your lighting system, the Harmony will emulate just about any remote controlled system that uses an IR signal. You may just need to program that device into your remote. Since you will not always want lights on or off during a movie, I would teach the remote the the audio systems * key is the same IR command as your lighting system. That way you can control the lights at the push of a button, independent of that activity.
4/1/2014 9:31:10 AM • Logitech Harmony... • Answered on Apr 01, 2014
Randomly restarting
If you wish to get more codes and other details check: http://electrohelponline.blogspot.com/ http://electro-medical.blogspot.com/ Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
1/19/2014 7:10:44 AM • Logitech Harmony... • Answered on Jan 19, 2014
Battery is swollen and cannot be removed from remote
contact harmony they have been replacing some of these remotes for the battery problem
12/6/2013 2:25:34 AM • Logitech Harmony... • Answered on Dec 06, 2013
2answers
Safe mode!
I can help you with your Harmony One Remote Control.
Replacing the firmware in your Harmony One is the way to get it out of Safe Mode.
To help you make sure the firmware update is successful:
  1. May I suggest you make sure you are running the latest Harmony Setup Software (V 7.7.0).
  2. Replace your remote's batteries with fresh ones. It is important the remote has sufficient, unvarying power when updating firmware.
I hope that helps.
______________________________________________
Harmony One Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
10/27/2013 6:57:32 PM • Logitech Harmony... • Answered on Oct 27, 2013
Logitech Harmony One Advanced Universal Remote with Color Touch Screen Logo
223 questions posted
Top Logitech Televison & Video Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Televison & Video
Most Popular Question
watch netflix
  • Televison & Video
