20 Most Recent
Canon imageRUNNER C2620 Color Copier Questions & Answers
Canon Imagerunner C2620 stuck in warmup
you must read your troubleshooting section instruction manual If you do not have download www.fitness.manualsonline.com or www. retrevo.com or www.manualsfactory.com or www.2manuals.com or www.eserviceinfo.comsee the diagram .God bless you
5/10/2012 4:12:44 PM •
Canon...
Answered
on May 10, 2012
We have an imagerunner c2620
Did you replace worned out unit with new one?
If Yes, check the connectors of sensors and connectors from fixing unit to copier.
Did you remove all protective sheets from new fixing unit? Check that nothing is in paper path way or that sensor flapers arent broken.
Leave an email, and I can send you the service manual.
9/21/2011 9:24:46 AM •
Canon...
Answered
on Sep 21, 2011
My ir 2620 wont finish
It maybe out of toner, sometimes the lite don't come on...nothing works perfectly all the time
8/20/2011 8:22:46 PM •
Canon...
Answered
on Aug 20, 2011
How do I set the
Call for service & maintenance
Gaurav Pahuja
9811139117, 9990258388
Delhi & NCR
8/5/2011 5:58:18 PM •
Canon...
Answered
on Aug 05, 2011
How do i reconnect the
The network connection indication is that the copier is not on network. Bad port, Cable, bad circuit board. Need to figure out what needs to be replaced. Check that the IP address for the copier is correct and agrees with the port address for the print driver
6/15/2011 7:43:17 PM •
Canon...
Answered
on Jun 15, 2011
Changing Image Size
It may sound silly, but it may work. When you inlarge the LTR page, is it cut off? Try placing the page to be copied or enlarged on the copyboard glass going in the LTR-R direction.. Good Luck
6/24/2010 1:43:22 AM •
Canon...
Answered
on Jun 24, 2010
Monthly copy count
If is not selected to mountly report ,you don`t can obtain the report.Exist one aproxim. solution:make a calculation if you change the toner amd the numbers of copy in this day and obtain the result aproximat.
9/10/2009 9:00:37 PM •
Canon...
Answered
on Sep 10, 2009
It's not so much of
touch additional finctions then common setting then touch the one tray designation then select were you want it to go for each function
12/17/2008 1:45:17 AM •
Canon...
Answered
on Dec 17, 2008
