20 Most Recent
GPX D1816 DVD Player Questions & Answers
No valid disc
your not using a good disc. use a regular disc and no blue rays
Lost remote no audio
You can get the player with the remote brand new at amazon.com for $29.99
Otherwise you can pay GPX $10 for a new remote or you can go to remotes.com and get one.
Ebay is also recommended.
I just found your remote at remote.com as well
DVD Player D1816 shows Wrong Regional Disc message
Many DVD players are preset to one region and if you use a DVD destined for any other region, the player will refuse to play. Some players have the option to change this to universal mode. Check your player's manual if yours has this facility.
Yes. You can play VCD movies and and Audio CDs on most players.
Wrong regional disc
Hello mperona,
The reason you are receiving this message is due to the region settings on your dvd player. Dvd players use region settings to allow them to only play dvd's from certain parts of the world. Your dvd player's region settings do not match the region code of the dvd disc.
The only way is to make your dvd player multi region....you will need to post the make and model of your dvd player so I can search for a solution that will work.
Thank you for choosing Fixya!
Disk region incorrect message pops up
It's not the dvd; it's your player. I'm answering my own question. I did a search and found a code that needs to be set into my dvd player. So do a google search asking "wrong region" and the name of your dvd player. Someone is sure to have hacked through the problem and is more than willing to tell you how to fix it. Worked for me! Why does this even happen?
What is the code for a gpx dvd player d1816
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
