20 Most Recent GPX PD808B Portable DVD Player with Screen Questions & Answers
2answers
GPX portable DVD model PD808B - wrong region message
Turn on power. Open lid. Enter 9735 with the remote and press 'enter', you can now choose between regions on the screen. Select the desired region unlock and press 'enter'. This works well!
Benony Jonsson
11/5/2019 7:13:08 AM • GPX PD808B... • Answered on Nov 05, 2019
2answers
GPX PD808B dvd player has no picture. its all white.
portable DVD's encounter that problems more often.because of its folding action,the flat wire connecting the screen to the DVD board breaks and causes no picture.try to open it up and check it or bring to a tech.
5/9/2018 1:26:11 AM • GPX PD808B... • Answered on May 09, 2018
0answers
Gpx portable dvd player will not play videos comes up err disk
The error disc usually means a dirty or bad optical pickup in the unit--DVD are more complex than CD etc and blu ray even more so.
5/24/2012 10:39:45 PM • GPX PD808B... • Answered on May 24, 2012
3answers
Gpx pd750w don't show movies on the usb stick what
I have tested mpg, avi, wmv and no luck yet.
3/7/2012 8:10:42 PM • GPX PD808B... • Answered on Mar 07, 2012
Will not load DVD will state DVD erro but won't
im sorry but your dvd laser has gone the only thing i can advise is wipe it with isoprpal alchohol wipes ie sterile wipes but if not working its the laser im sorry i hope this has helped
1/15/2011 11:24:56 PM • GPX PD808B... • Answered on Jan 15, 2011
D200B DVD player. It's
this is either a video driver error caused by out of date drivers or trying to display something your computer does not have the capacity for if you meet the min system requirements and your drivers are up to date try displaying other programs to make sure that you find the same lines if after updating drivers you still have lines either the monitor or graphics card has burnt out
10/25/2010 2:13:52 AM • GPX PD808B... • Answered on Oct 25, 2010
How long to recharge dvd p[layer?
Max battery recharge about six hours.Old baterry inside like a 1 or 2 years olds.Should plugin charger and chagres 8 hours to max like a new battery.
8/7/2010 11:10:20 PM • GPX PD808B... • Answered on Aug 07, 2010
Light in front turns green then red and stops.
Well it seems that the problem must because of the battery, may the it's time to change the battery of your player.
How old is your DVD Player?
Is this Player works in charging mode (when charger is plugged to it)? If yes then sure you need a new battery for your Player. Please reply for further help or information........
Good Luck!!
Thanks
7/29/2010 9:09:10 PM • GPX PD808B... • Answered on Jul 29, 2010
My GPX PD808B portable DVD
Well first of all you can please follow the below steps -
1. First of all clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
2. Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
3. Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
4. Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab. Please post comments for further help or information........
Good Luck!!
Thanks
7/25/2010 7:31:14 PM • GPX PD808B... • Answered on Jul 25, 2010
My GPX PD808 Portable DVD Player
The reason the DVD player shows no disc is because the laser?lens is either weak or dirty.
If it is weak, i requires replacement,
to replace it,
get the appropriate screwdriver,
Unscrew the compartment underneath the player,
carefully detach the panel and remove the old lens and replace it with a new one.
Carefully fix the panel back and close the compartment.
Test it with a DVD.
If it is dirty, then all you have to do is to clean it with a DVD lens/laser cleaner.
6/12/2010 9:28:38 PM • GPX PD808B... • Answered on Jun 12, 2010
0answers
Audio no picture
do you get a splash screen when there is no Disc playing ( something that says something like DVD VIDEO). If not and the scren is just always black then it sounds like the backlighting circuit has failed
3/18/2010 12:50:06 PM • GPX PD808B... • Answered on Mar 18, 2010
Wat kinda of videos can u c on it with a usb or
the usb port is used to view pictures and videos off a computer or camera using the correct format
1/20/2010 3:32:15 AM • GPX PD808B... • Answered on Jan 20, 2010
The screen is white and
Ihave the same problem and someone else posted that because it gets folded alot a flat wire may have broke.
12/8/2009 12:05:50 AM • GPX PD808B... • Answered on Dec 08, 2009
When I put in a dvd the screen says loading then says no dvd
normaly in this condition the laser pick up is defactive first you clean the pick up with cd cleaner if problum solved ok other wise you have to change the pick up from any otherized service shop
12/3/2009 2:09:12 PM • GPX PD808B... • Answered on Dec 03, 2009
Problem whith the screen
good
11/30/2009 6:25:15 PM • GPX PD808B... • Answered on Nov 30, 2009
GPX PD808B Portable DVD Player with Screen Logo
Popular Tags
40 questions posted
Top GPX Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • GPX Televison & Video
Most Popular Question
gpx pd750w dont show movies usb stick
  • Televison & Video
