20 Most Recent RCA RP5030 Digital Voice Recorder Questions & Answers
Is your Win7 64bit?
Maybe RCA can help you.
If it's a recent upgrade, contact Microsoft as well.
RCA RP5030... | Answered on Apr 28, 2016
Erasing selected file
You can delete a file by the following steps:
1. Select folder (A, B, C , D or )
2. Select file.
3. Press ERASE once and DELETE will blink on the screen.
4. Press and hold ERASE for 3 seconds to confirm deleting. (or press STOP to cancel erasing file)
Erasing all files in a folder
You can delete all files in a specific folder by the following steps:
1. Turn on the unit.
2. Select a folder (A, B, C , D or ).
3. In Stop mode, press FORWARD continuously until "ALL" appears on the display.
4. Press ERASE and "DELETE" will blink on the display.
5. Press and hold ERASE for about 3 seconds, all files in the selected folder will be erased completely (or press STOP to cancel erasing all files).
Tip: File numbers that come after erased one will be moved forward by one automatically.
See page 12 for more info: http://www.rcaaudiovideo.com/docs/common/RP5030/RP5030_OM.pdf
RCA RP5030... | Answered on Apr 16, 2016
Have you considered replacing the baterry to see what happens?
RCA RP5030... | Answered on Apr 20, 2014
I have a C-phone quick reference guide I could scan and email to you if it is the same kind of phone.
Let me know.
cynthia.culp@imail.org
RCA RP5030... | Answered on Mar 03, 2009
Manual is available for download here.
https://isupport.nuance.com/OA_HTML/ibuktl.jsp
RCA RP5030... | Answered on Feb 16, 2009
Mistakenly you deleted them, so no way to recover. Compare the 2 statements: "I found the place but they are all gone." "I couldn't find the place". Your situation is the former, so is not you failed to find the location where the files were. You knew the location.
RCA RP5030... | Answered on Feb 10, 2009
RP5030 u s e r m a n u a l
http://157.254.235.130/public/IB_RP5030_EN.pdf
RCA RP5030... | Answered on Nov 22, 2008
GHFYKFGKGUJGLUIHLIHLIUKLUKYFFY
RCA RP5030... | Answered on Nov 06, 2008
Solution for this problem is to Format the recorder. Step 1 is to turn on unit. Step 2 Press Erase " Delete will flash on the display. Step 3 Press and hold Rec for 3 seconds "Format" will flash on the display. Step 4 Press and hold Erase, the completed percentage will show on the display (formatting is now in progress). Step 5 After formatting is completed the remaining time will show on the display. You should now be able to record. Make sure that you hold the ERASE button in step 4 until Formatting shows 100% complete.
You should setup 2 different work types. Have the dictator select the work type prior to dictating the job. The higher priority work type should be sorted higher up in the pool script for Enterprise Express. If this is a Straight Talk, simply have the dictator select work type 2 (priority) and that job will come to you first. If you need help setting up a pool or a pool script please contact timtrent at hotmail dot com.
RCA RP5030... | Answered on Nov 03, 2008
refer to the 5032 at the RCA web page on how to format the memory.
RCA RP5030... | Answered on Aug 02, 2008
I have used Adobe Audition 1.0 - works great, you can filter noise & use equalizer.
RCA RP5030... | Answered on Apr 22, 2008
how's to erase my recorded?
RCA RP5030... | Answered on Mar 06, 2008
RCA RP5030 Digital Voice Recorder Logo
24 questions posted
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
need instruction manual recorder
  • Audio Players & Recorders
