20 Most Recent
RCA M4304 Digital Media Player Questions & Answers
How to take apart a rca mp3
use one of those triangle openers and gently open it like an iPod classic (use the tool on the outer dark gray piece)
Rca opal 4gb M4304-A has completely stopped functioning
Wow, I didn't realize so many people were having the same problem I was having. First try re-installing the firmware for it. Since your computer won't recognize it you will need to download the software, then you will have 2 boxes pop up. One is the install instructions and the other is the actual program install. You will have to hold down the play button on your player while you plug it into the computer. DO NOT RELEASE THE BUTTON UNTIL THE PROGRAM SAYS "INITIALIZING".
It should work fine once you do this. I spent 3 hours going through RCA's website before I came across this step.
When i turn my rca m4304-a on it says profile
We are having the sam eproblem with the asking to free up 20mb. Your solution (The player needs free memory space for building up the playlists: delete the amount of data off the player.
Connect to the computer and backup all the data from the player onto the computer.
Next delete some of the saved data from the player to free at least 20 MB of memory.
All support for the RCA M4304 on next page:..... Does not work for us. When we plug it into the computer all it does is show it usb connected but we cant get into player anymore to delete anything. Please advice
I have an RCA mp3
If the MP3 player battery is more than 3 - 4 years old then the battery could
be worn out. Rechargeable batteries have a finite number of charge and
discharge cycles and will lose their charge capacity over time, i.e.
won't charge to 100% and gradually the charge reduces until the battery
won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected
the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery
needs to be replaced.
