20 Most Recent
NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive Questions & Answers
Driver 2616425
Contact Nexxtech on the web. Look for Support/Downloads/drivers.
1/4/2019 7:47:41 AM •
NexxTech...
Answered
on Jan 04, 2019
How to open case
Contact Nexxtech on the web. Look for Support/Downloads/Manuals.
1/4/2019 7:35:56 AM •
NexxTech...
Answered
on Jan 04, 2019
Cant delete or put files
You will have to be the computer administrator to change
any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the
guest account if you have made one click on the administrator this may vary depending on which operating
system you have
click start click to open on my computer you should see your
hard drive usually C: right click select properties there will be an array of
options select the security tab option then advanced make sure you have full
control in windows 7
click start control panel user accounts click on the
administrators account if you have made one or you will have to create one in
windows XP
USB drives can be write-protected by modifying the
StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to
open the find dialogue box and type "usb device" or
"driverdesc" to open usb mass storage device or type "usb mass
storage device" in the search windows. And right click on it and delete.
This will set the policy value to 0. then insert your usb device. It will work
fine.
# Remember: do not delete any unknow files in the registry as this will make
some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
5/9/2011 10:47:47 PM •
NexxTech...
Answered
on May 09, 2011
Nexxtech 3.5" Hard Drive Enclosure (NHDE35)
I'm not saying this will solve all problems, but it solved it for me. I am running Vista and got this to work following someone's instructions from another forum.
The slot in the enclosure that you plug the hard drive into has one set of holes fewer than the hard drive has pins. This means you can plug the hard drive in two ways "left" and "right" if you will. I had to plug my hard drive in so that the unused pins were farthest from the power cable that plugs into the hard drive.
Incidentally this made the screw holes line up better, too.
2/27/2011 11:37:30 PM •
NexxTech...
Answered
on Feb 27, 2011
My Nexxtech nhde35 ext. hard
Seems most likely that the drive enclosure has failed, since swapping to a different HD made no difference. If so enclosure will have to be repaired, or replaced.
1/6/2011 12:20:52 PM •
NexxTech...
Answered
on Jan 06, 2011
NEXXTECH NX2
If this is a new drive, you will need to format it before it will show up in My Computer.
To do so, start by right-clicking on My Computer, then choose Manage from the menu. Click on Disk Management, you should see a list of drives in your system. Your new drive will show up as unallocated space, right-click on that and choose New Partition, choose the size of the partition you want, and choose to format it.
Once the partitioning and format process is complete, the drive should show up in My Computer under a new drive letter.
9/11/2010 4:29:37 PM •
NexxTech...
Answered
on Sep 11, 2010
Open hard drive enclosure
(I found your question because I had the same question. Decided to go for it.)
The aluminum top and bottom covers are held in place by the indentations on the sides which fit into channels on the plastic chassis inside.
I used a flat knife blade to gently pry by the front end of one side until the cover moved moved slightly out of the channels, then switched to the other side. Once I had it started, I was able to just lever the cover off by grasping the front corners and swinging it up in the reverse motion of the installation procedure.
Caution: Prying too hard or far at once will bend the covers and or nick the plastic chassis extrusion.
Good luck
8/11/2010 4:05:49 PM •
NexxTech...
Answered
on Aug 11, 2010
How do i get a new hard drive to recocgnize the
Connect the external storage
Click Start
Right-mouse click My Computer
Click Manage
Click Storage
Click Disk Management
Check to see if there is a "healthy" partition covering the disk-space of the external storage device.
6/24/2010 4:19:33 PM •
NexxTech...
Answered
on Jun 24, 2010
I have nexxtech portable kit with a hard drive in
Try your NexxTech on some other computer, to verify that it still works.
Try some other USB port on your computer.
Try some other USB device into the same USB port that you are trying to use for your NexxTech, to make sure that your computer's USB ports are working correctly.
Check that Windows 7 has loaded the device-drivers for your USB 2.0 ports on your computer's motherboard.
5/14/2010 2:25:46 PM •
NexxTech...
Answered
on May 14, 2010
Computer recognises usb connection briefly and
This generally means you have a failed USB controller board or a failed drive inside the enclosure.
Try removing the hard drive from the shell and transferring it into a new external enclosure. If this works you're done, if not the fault is in the drive. I can offer you some advice on DIY methods or direct you to a professional lab near you if you provide your location.
Hope this helps FixYa,
Crankstart
3/24/2010 1:29:02 AM •
NexxTech...
Answered
on Mar 24, 2010
NHDE35 Enclosure
Posted by Decoder1 on Feb 25, 2009
I also had a problem with XP not recognizing the hard drive. The USB Mass Storage Device was reporting a Code 10 (Device cannot start). Ryockey provided the solution in that the drive pins can be offset by one set when connected to the interface. Be careful to get the pins aligned correctly, it worked for me. I also have my drive jumper set for Master. Thanks Robert!
Randy
P.S. I am using a Seagate 250 GB HD 7200.7 Ultra ATA
2/25/2009 12:54:49 AM •
NexxTech...
Answered
on Feb 25, 2009
HARD DRIVE ENCLOSURE RECOGNITION BY MY PC PROBLEM
Had the same problem today. I finally noticed that the pin bay on the enclosure was large enough to allow the pins to be offset by one pin set. The open pins were hidden by wires. Once I carefully aligned the pins, everything worked fine.
Robert
2/25/2009 12:31:16 AM •
NexxTech...
Answered
on Feb 25, 2009
