20 Most Recent Lenovo ThinkPad X60s Notebook Questions & Answers
Neeed lenovo thinkpad x60s bios' password
A bios password is set by the administrator. If this is not your computer, then there is no help for you. A bios password is not default information. You can disable most bios passwords however by either removing the CMOS battery or changing out the jumper(advanced knowledge to do this) but I will not divulge such information as I'm assuming this is not your computer.
4/24/2014 1:20:38 AM • Lenovo ThinkPad... • Answered on Apr 24, 2014
Restore factory settings
you need to go into my computor and go to setting's and reset it to factory setting's..
1/22/2014 12:55:44 PM • Lenovo ThinkPad... • Answered on Jan 22, 2014
My lenovo x60s has no disk drive so that i can
Use another pc to extract/copy all the files from the install disk of the printer to an USB memory stick, put that stick in the Lenovo and run the setup.exe file - this is the installer for the driver and all the rest.
4/13/2011 8:46:42 AM • Lenovo ThinkPad... • Answered on Apr 13, 2011
My laptop lost sound when I reistalled windows xp.
Check on the net, if still cannot solve the problem, maybe the sound chip malfunction
5/20/2010 1:43:21 PM • Lenovo ThinkPad... • Answered on May 20, 2010
How to fix my lenovo x60s y key
normally when a key pops off it can be resnaped back into place with very little effort. locate where it came from and just press it back down into place.
11/11/2009 8:11:19 PM • Lenovo ThinkPad... • Answered on Nov 11, 2009
SL500 does nothing when power
remove the battery large. then run on AC pack only #1 top failure of all mobile PC is that battery, so unplug it then test with AC pack only. work now.? and all vents must be clean, end to end. not just fan. there i no fuse it uses current regulator, imagine genius magic electronics fuses that never blow out, and bingo. OK big battery out, an RTC coin cell fresh. then fan blows. next is BIOS, do the BIOS screens work if not the mobo is dead. have 2 RAM stick on the 2 slots>? try one at a time run the PC with all modules removed, (options) remove hdd? remove, dvd drive. think like this. Get bios working first learn that modules can short, and when they do the power regs shut down. so we unplug all things to the mob, until only 1 ram and cpu remains. see? (this is called power overload fault isolation tactics) even the screen only can be dead, you never mention text showing you can test the mobo with external screen via that rear (?)_ VGA jack what if that worked, did you learn something here, sure. this pc has tons of modules to pull, even bluetooth. wifi, sound and more. if you look at all parts inside or sold by ebay, bingo. lots
8/14/2018 12:52:53 PM • Lenovo ThinkPad... • Answered on Aug 14, 2018
2answers
Screen lock
It helps to know what device model and OS you are using though the following steps for changing from pattern lock to slide are for Android OS 4.0 (Ice Cream Sandwich):1. Unlock your Android device2. Find the Applications menu and select "Settings"3. Under the "PERSONAL" group, select " Security"4. Under "SCREEN SECURITY" group, select "Screen Lock"This will ask for the security pattern first.5. The options for screen lock will appear, select "Slide" and you are done!Hope this helps.
3/14/2017 5:21:09 AM • Lenovo ThinkPad... • Answered on Mar 14, 2017
How can I activate the camera?
2/16/2016 4:15:32 PM • Lenovo ThinkPad... • Answered on Feb 16, 2016
G500 how reach bios setting
Just press "delete" "F2" or "Escape" keys imediately then you power on your computer. (Key depends on your pc model)
1/8/2016 7:24:01 PM • Lenovo ThinkPad... • Answered on Jan 08, 2016
HOW RESET BIOS PASSWORD TOSHIBA M11
Try this http://www.wikihow.com/Clear-BIOS-Password
1/8/2016 7:18:55 PM • Lenovo ThinkPad... • Answered on Jan 08, 2016
Lenovo ThinkPad X60s Notebook Logo
Popular Tags
8 questions posted
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad Lenovo
  • ThinkPad Lenovo
Most Popular Question
neeed lenovo thinkpad x60s bios password
  • Computers & Internet
