20 Most Recent
Lenovo ThinkPad SL400 Notebook Questions & Answers
Display goes off after few seconds
Possibly you have an overheating GPU or CPU problem. If you can do it, then disassemble the laptop and:
- Clean up everything (use canned air),
- Replace the cooling pad or cooling paste of GPU (if applicable) and CPU,
Reassemble the laptop.
Before you disassemble this laptop, you can check the air inlet, air outlet and the fan, and clean them up using canned air. I hope it solve the problem.
I have one Lenovo ThinkPad SL400 Notebook os win
In Skype's preferences, it allows you to configure your microphone(s). I would check here to make sure it's working properly from within Skype. It's possible that you just have it muted. If it doesn't show up here, fire up Device Manager and look for the microphone there. If everything looks good in both places, it's probably a network issue, maybe you should try something other than Skype?
My product microphone is not working while talking in skypee
Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver Open skype go to tools from the drop down list select options scroll to audio settings you can make a free test call before you try to make a call Make sure the microphone is using the same as your computers audio you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also Click start control panel sounds and audio devices audio and also voice its the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick also select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume Make sure the box for microphone has a tick in it
My original of this battery is dead, I want to get a replacement of this battery
If you are buying a replacement battery, remember two things, 1 get the EXACT power specs DC Volts and Amps. 2 Beware of inexpensive batteries, sometimes they don't work well with your laptop. Search the Lenovo website for a idea of what Lenovo charges. Do a little research on the website you intend to buy from, reviews of customers for instance. Good Hunting.
My laptop's care button dosn't
Welcome to Fixya
The lenovo care button was built to restore the computer back to the factory state if in any case you will be experiencing software problem with your computer and you want to restore it from the original state. If this button will not function for no reason then then only person that can help you is the Lenovo repair department. You can send in the computer to lenovo depot repair and have them re-image the harddrive so that the Care button will be reinstalled.
Thank you for using FIxya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
After i restore my Laptop
You may want to check your video card. This can happen if something is corrupted in the driver files, a reload of the Os may be in order.
I can't install bluetooth driver
i)Download System Update drive from lenovo web.
ii)Install it till complete.
iii) Complete ii) then go control panel, set view by large icon then to run Update and Drivers
iv) Follow steps till install Power Management for SL series till complete
v) Use Fn+F5, you able to see bluetooth icon at that moment
Good Luck!
My Lenovo Thinkpad SL 400
Hi kingston_koa,
Getting different colors with vertical strips are common effects of broken LCD/screen. Broken LCDs needed to be replaced. With this one, the best thing that I can recommend you is to contact Lenovo specially if your machine is still under warranty. They offer free repair and parts replacement depending on your warranty coverage.
Hope this will help you.
Thank you for using Fixya.
