20 Most Recent
Olympus Camedia C-480 Zoom Digital Camera Questions & Answers
How to correct RUNTIME error
Please elaborate on the description of your problem.
The more information you provide, the more specific and accurate our solutions can be.
I see no reference to a RUNTIME error related to your Olympus C-480 camera online or in the users manuals.
Is RUNTIME a word you are seeing on your cameras screen or on your computer while running software related to your camera?
How can I turn off
The write protect is usually a small micro switch on the memory card. Pull it out and make sure the switch is not locked. It's located on the edge of one side of the card..
Removal of write protection
Sounds like you will need to format the internal memory of the camera. This will permanently erase all the data from the memory and then you will be able to use it again. To format the memory: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the memory can be used again.
Camera mode dosn't function. Play mode functions.
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced.
Olympus will charge a flat rate repair fee for this product. The cost is $105 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Trying to transfer images
The best solution is to obtain a card reader.
Apart from anything else it will save a fortune on battery power.
Are you connecting the camersa direct to computer or via a hub?
and how many other USB devices are hooked up and running?
All relevant- reduce these and see what hapens
Olympus Camedia E10 won't power on with AA NI-MH batteries but works fine with AA ALKALINE, what can I do?
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Make sure your rechargeable batteries are all good. One defect in a set is killing for the whole set
Don't use barrettes from different sets or brands together.
I had one brand good NiMH batteries and a very expensive charger from the same brand. The charger destroyed all my rechargeable (more than 60 now). When I first discovered the batteries were dropping out, I stopped using the charger, but it did not prevent all batteries to die in the following months. Every time on dropped out I had to change the set. I tried using up the others by grouping the ones with the same Ri, but not longer then a few months and I had a box full to trow away.
Never use a quick charger, capable of charging them within an hour or faster. Us a charger that indicates the Ri is still low enough, so you can see what batteries are bad.
Check you are using a charger for NiMH batteries.
I would try another set (new) because buying Alkaline is also not cheap.
I used 2700 mAh and later 2600 mAh rechargeable, all dead now. since a few weeks I'm now using 2300 mHh from another brand, costing 1/5 of the "best" I had before, and they are doing great. I won't charge them with the quick charger.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
How to use zoom on c-860L
This 14 year old camera, does not have a zoom lens. It has a 5,5 mm lens, giving it a angle of view of about a 35 mm lens of a Full frame camera. However, you should be able to zoom digital 2 times.
I can't find a manual, to help you on this, but the quality will be the same as cropping into a frame on your computer. So if you do put the pictures on a computer, you also can "zoom" in to the parts you want. Be aware a 1 megapixel camera, does not offer that much of detail.
