20 Most Recent Danby 16.7 cu. ft. / 473 liter Upright Freezer DUF1700W Questions & Answers
My freezer leaks water and it all go to the bottom of the freezer,i think the hose is plugged,but when i pull on it,it won,t budge.help.
Use a steamer or a turkey baster to force warm water through the tube
10/14/2016 3:03:53 PM • Danby 16.7 cu.... • Answered on Oct 14, 2016
DAEWOO FR-661NW GETS HOT
Just a thought i would check if there. Is it possible an ice build up around the fan could be stopping it from turning?
1/25/2014 5:24:17 AM • Danby 16.7 cu.... • Answered on Jan 25, 2014
The compressor stpped working -
Hi KarenTry following this linkhttps://www.danby.com/registration.phpthen you can fill out all the other info they will want, it's a pain, but as far as I know it's the only wayRegardsGordon
6/16/2011 8:15:43 PM • Danby 16.7 cu.... • Answered on Jun 16, 2011
Top part thaws food
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
4/21/2010 7:42:07 AM • Danby 16.7 cu.... • Answered on Apr 21, 2010
Can I put my Danby upright freezer in the garage?
It is always best to keep these types of equipment in the 60-80 degree ambient.
9/26/2009 2:57:41 AM • Danby 16.7 cu.... • Answered on Sep 26, 2009
Noise Problem
Is it a frost free freezer ? if it is it sounds like the evaporator fan motor making the noise
8/29/2007 5:15:15 PM • Danby 16.7 cu.... • Answered on Aug 29, 2007
The blue temperature light and the green light is flashing on my danby deep freezer. Why is this?
One of these is a power light. It typically remains on while the freezer is in use. No light means either a blown bulb or no power. The other is associated with the thermostat. But it does NOT indicate that freezer temperature is appropriate. Flickering appears to indicate the bulbs are simply failing. The bulbs are neon, I think, and are not cheap. Some might try replacing such with LEDs. I have seen comment that the bulbs are not long lasting. www.manualslib.com has numerous danby freezer manuals but I do not know your model. Have a look.
11/19/2020 2:02:29 AM • Danby Freezers • Answered on Nov 19, 2020
2answers
4.7 cu ft chest freezer dead
7/18/2020 9:57:46 PM • Danby Freezers • Answered on Jul 18, 2020
I can’t open the lid on my Danby Premier 5.5 cu ft freezer
Is there a lock? Otherwise, it could be frozen to the top if there was liquid water that refroze. Warm it up with a hairdryer around the lid rim.
11/5/2019 2:51:43 AM • Danby Freezers • Answered on Nov 05, 2019
Danby upright freezer DUF808WE - quit working overnight after 5 years of operation and it has no indication of any type of operation. neither cold nor hearing any motor sound. Please advise.
If compressor not running at all, it’s either a power supply problem, or a thermostat / control board
1/10/2019 9:53:25 PM • Danby Freezers • Answered on Jan 10, 2019
I have a Danby DUF808WE upright freezer. It works for a while (days/weeks)then stops. If I wack it on the top it starts up again and runs again. What do you think the problem is?
In that model the Temperature Control often is the culprit. When the freezer gets very cold it shuts off. The because it is not running it gets warmer and will start to work again. I would perhaps focus on the Temperature Control.
8/22/2018 3:35:58 PM • Danby Freezers • Answered on Aug 22, 2018
I have a small upright Danby freezer and it seems that only the right front foot, screws up and down for leveling. the left foot seems to be stationary. How do I go about leveling this unit?
both feet screw in and out so use spanners to loosen of the lock nut or pliers to move the rusted thread A spray of wd-40 may help
7/12/2018 1:18:15 AM • Danby Freezers • Answered on Jul 12, 2018
Does a Danby 5 cu ft chest freezer have a drip pan? If not, how can I get rid of the rotten meat smell?
The drip pan on any freezer collects ice melts from the evaporator during the defrost cycle. Most of them are mounted on the compressor and use the compressor waste heat to evaporate the water. If there is rotten meat smell in the drip pan it means there is also rotten meat smell in the evaporator coils and fins. It's almost impossible to get "stuff" out of the evaporator fins unless you take the unit apart. This means you will probably have to remove and replace the refrigerant plus evaporator and the entire process could take two 8 hour days or more. Alternately, after you completely wash it out you can try placing a pan of hot water in it and run it empty. The steam will condense on the evaporator and freeze. Then defrost it . Hopefully this will wash some of the funk away. You might have to do this several times. If that doesn't work then cost wise the unit is junk. Suggest in future wrap your meats in freezer bags or other water/air tight containers in case power goes off. Monitoring your freezer is a must to catch issues before smelly spoilage can set in.
2/4/2018 2:53:44 PM • Danby Freezers • Answered on Feb 04, 2018
We bought Danby freezer yesterday,its plug in, the red and the gtreen lights are shining but didn't freez, no any cool inside the box, why please??
Considering you just purchased this unit, you should call the manufacture to get warranty service on it.
10/23/2017 11:59:33 AM • Danby Freezers • Answered on Oct 23, 2017
How many amps does a 5.5 cu ft danby freezer use. Start up and running amps.??
easiest way to do this is look at the label on the compressor. I usually lists RLA. FLA is usually 5 to 7 times the RLA. For example, if RLA is 3.0, the the FLA is 15-21 amps. FLA is actually LRA for about 2 seconds.
10/1/2017 11:53:18 PM • Danby Freezers • Answered on Oct 01, 2017
I just got an older Danby freezer,,,,model dcf 480, type zs 1401,,,,my question is,,,what is the orange switch in front for?,,,on witch side should it be?,,,thanks
the switch my be a temperature monitor switch. the alarm is set to -10f to let you know that there is a temperature problem.
9/12/2017 6:43:42 AM • Danby Freezers • Answered on Sep 12, 2017
Danby 16.7 cu. ft. / 473 liter Upright Freezer DUF1700W Logo
8 questions posted
Top Danby Freezers Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Thomas Perkins
Thomas Perkins
Are you a Danby Freezer Expert? Answer questions, earn points and help others
View Most Popular
Danby Freezers
  • Danby Freezers
Most Popular Question
freezer leaks water all go bottom
  • Freezers
