20 Most Recent
HP Compaq Presario S3000nx (DC475A#ABA) PC Desktop Questions & Answers
Need help with downloading a
download it from here ftp://ftp.hp.com/pub/softpaq/sp26001-26500/sp26412.exe
if you found this useful please vote for me
9/29/2011 9:24:25 PM •
HP Compaq...
Answered
on Sep 29, 2011
I was given a presario S3000NX with all power
1. for what you describe could be the sound card cable from the DVD or CD ROM
not sure without a physical look at the cable. there should be a black connector either at the
top corner of the mother board or by the pci slots that the connector is placed.
If you have a sound card mounted in a PCI slot then there is a connector on that board
for this cable.
I hope this helps. Have great day!
10/8/2010 12:02:36 AM •
HP Compaq...
Answered
on Oct 08, 2010
I just installed a new hard drive and the computer
it should move / ask for the next cd with in a 15 min. And or you should be seeing some sort of file movement.
Is sound like it's not likeing the new drive. It might be to big for that system.
Please leave comment and review.
2/25/2010 1:37:57 AM •
HP Compaq...
Answered
on Feb 25, 2010
I installed 2 new banks of 512 MB RAM in my COMPAQ
Your bios may need to be flashed so your motherboard with recognize the ram. It also may be fixed by adjusting the speed of the ram in your bios settings. Be carefull and read about doing both of these procedured in your mainboard manual( should be able to get a manual from the compaq site if you do not have one).You can mess up your computer real good if things are set or flashed wrong. Good Luck
11/22/2009 2:55:40 AM •
HP Compaq...
Answered
on Nov 22, 2009
Computer having touble booting up
Try going into safe mode (VGA mode) and see if this works. If you cannot go into safe mode you may have a problem with your video card. Also if you set your resolution too high for the monitor, you will get this problem. If you have another computer and remote desktop is enabled on your problem PC try to Remote Desktop in from the working comptuer and change the resolution settings to a lower setting on the problem computer.
9/6/2009 9:33:07 PM •
HP Compaq...
Answered
on Sep 06, 2009
Out Of Range Virus?
i think you need to format your computer
i hope i can solve your problem
8/26/2009 9:57:57 AM •
HP Compaq...
Answered
on Aug 26, 2009
Modem problems
try to tell an supplier of the modem or from the pc.
The modem maybe cant support the pc.
Peace!
8/25/2009 5:57:08 PM •
HP Compaq...
Answered
on Aug 25, 2009
Setting up a Compaq Persario S3000Nx
First you need to check if all the items are available.
Don't worry about connecting as the cords will connect to the correct socket only.
NOTE: Connectors may vary by model. Printers, network connectivity, and other accessories
should be connected only after computer setup and registration are complete.
I have attached the link for the manual to be viewed online to guide you.
http://h10032.www1.hp.com/ctg/Manual/bpb13187.pdf
If you need further assistance do contact me.
1/11/2009 4:16:16 PM •
HP Compaq...
Answered
on Jan 11, 2009
Computers' power light is blinking and will not power on
This normally means that the computer is in standby mode all you need to do is press the power button. If this does not work then hold the power button in for about 10 seconds until the computer turns off then wait a further 10 seconds and turn back on and boot normally.
Please let me know it this works and please rate me. Once you booted normally set the power options within control panel not to go into standby.
Cheers J
1/1/2008 9:16:12 PM •
HP Compaq...
Answered
on Jan 01, 2008
What the *#^&** does "Out of Range" mean?
Hi Sapphire9,
The monitor that gives the ?out of range? error is telling you that it cannot work at the resolution/color setting the computers video card is set for. What you need to do is set the computers video cards screen resolution to something generic like 1024 X 768 first (Start, settings control panel, click on the display icon, click on settings tab on box that appears, screen resolution slider bar is in the lower left corner) then switch the monitors.
Let us know how it goes and please don?t forget to rate this post.
2/28/2007 7:34:57 AM •
HP Compaq...
Answered
on Feb 28, 2007
Compac presario CQ62
Hello
Most laptop or PCs, has a combination keyboard pressing keys, that invoque the restore routine.
usually F11 or F10.
others has DVD, check and see what you have of these two.
in the first one, you recover from a disk partition the whole OS.
Bios update fore presario 8000
Its all about go to HP page, and bios updates, the instructions are there too!
but be aware you have to be more specific on model, and BIOS dates.
Compaq presario sr5350f pc and i keep gtting windows is shutting down everytime i click the help button
You may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs). A. If your computer will boot and you can operate it ok... Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. B. If your computer won\'t boot, or can\'t operate properly after boot... Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.Good luckG
