20 Most Recent HP DeskJet 690c plus InkJet Printer Questions & Answers
Printing Dillema
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
6/26/2009 12:02:54 AM • HP DeskJet 690c... • Answered on Jun 26, 2009
2answers
How to reset HP ink ADVANTAGE 3515 Printer
Hello. First of all I would like to wish everyone a Happy New Year! I recently bought a HP Deskjet Ink Advantage 3515 printer. The printer works fine (prints, scans and copies). There is only one problem with it. It returns me an error when I'm shutting it off. This happens very often but not always, it is kinda annoying. The error is displayed as: ERROR CODE 0X02B7C2ED SM_MODULE C (the error is also shown on the image). I tried to Google the problem but without effects. I don't know what could be the problem. Can someone help me please, because I have no idea what could be the issue. Thanks for any replays.
2/3/2022 11:51:08 AM • HP DeskJet... • Answered on Feb 03, 2022
2answers
How do I fix an Hp deskjet 4615 not printing black?
If you are using a Windows PC, search for devices and printers. Once you find the printer, right click on it, go into printing preferences and you should find a tab in there that will all you to disable color. If you want to be able to print in both and black will not print, make sure your black ink cartridge is not empty or that it is properly installed.
7/29/2021 7:19:59 AM • HP DeskJet... • Answered on Jul 29, 2021
2answers
I need a printer driver for a HP Desk Jet ink advantage 3835 that works with Apple Mac 10.6...pleease
Go to this website. http://support.hp.com/us-en/product/HP-DeskJet-Ink-Advantage-3830-All-in-One-Printer-series/7172328/model/7172329/drivers/ Click check now and it should download the best driver for you. If not use step 2 and find the driver you need.
6/13/2020 7:10:21 AM • HP DeskJet... • Answered on Jun 13, 2020
COVER OPEN IN HP DESKJET F2430
check it`s sensor
5/15/2019 8:49:34 PM • HP DeskJet... • Answered on May 15, 2019
My printer cutting text from the right side when printing .HP deskjet 2050 J510
Check the paper size settings to match the loaded paper. This would happen (for example) if you have loaded A4 paper but your driver is set to print on letter format. Letter is wider than A4 by 6mm and while the printer is trying to print near to the right side, assuming the paper is wider, part of the ink goes on the paper support. Other reason may be the paper size in the document is set to be larger than the loaded paper format and driver prints only what can be fit on the loaded paper.
4/23/2019 10:06:27 AM • HP DeskJet... • Answered on Apr 23, 2019
I have error 0xc19a0023 in my printer hp deskjet 3520.I replaced new cartridge but it isn't correct.What should I do?
1) Open the printer cover and wait till the carriage moves towards the middle. 2) Force press the printer's Power button to turn it off. Remove the power cord from the back of the printer. 3) Remove the print cartridges and place it on a small sheet with the nozzle plate facing upward. 4) Slightly wet a cotton swab with distilled water. Clean the face and edges of the face cartridges with the swab. 5) Wipe the underside of the print cartridge cradle walls using a swab. Reinsert the print cartridges. 6) Close the printer cover. Connect the power cord at the backside of the printer.
11/28/2018 8:16:26 AM • HP DeskJet... • Answered on Nov 28, 2018
2answers
How do I scan multiple pages to one file using a deskjet 2512 printer/scanner
On the control panel, select scan to computer and choose PDF. If you are using the sheet feeder, it will scan all pages and create one file with them all. OR If you're using a scanner glass, i.e. one page at a time, when the first page finishes scanning, you will get a message asking if you have another - answer YES and follow the instructions (basically that means place next page on scanner glass and hit OK/Continue). Rinse and repeat until you've scanned all pages then answer NO. You should find a PDF file in your HP Scan Folder usually named "scan.pdf" unless you've changed the settings. (If there is/are already scanned files in that folder, they will have consecutive numbers, e.g. "scan001.pdf" "scan002.pdf" etc
10/11/2018 10:24:24 AM • HP DeskJet... • Answered on Oct 11, 2018
I have a HP Deskjet
www.hp.com/support enter printer model and number and run diagnostics with your printer connected to your PC or Laptop.
2/22/2018 3:54:54 PM • HP DeskJet... • Answered on Feb 22, 2018
Im using HP Deskjet 3900
Possible cable problems. Also mine shows offline if the power button on the printer is off
2/3/2018 7:09:10 PM • HP DeskJet... • Answered on Feb 03, 2018
I have installed an HP Deskjet 3520 as default
I have had this happen in windows operating system. It was caused by a corrupt user profile. You can try control panel users accounts. Try modifying the user account type like changing the permissions and windows should re save the user profile . then change it back to what it was. or look at https://neosmart.net/wiki/corrupt-user-profile/
1/31/2018 12:26:42 AM • HP DeskJet... • Answered on Jan 31, 2018
Cannot install printer driver hp deskjet f380
If you are unable to install the driver software check if there are any driver files that have not been removed from your computer (this might have been installed during the incomplete installation). Also, check if you are installing the correct driver and if you have selected the correct operating system. Open Change device Installation, and then select the Change device installation settings Control Panel setting. In the Device Installation Settings window, select the option to automatically download the driver. Get ready for driver installation by connecting your printer to the computer with a USB cable or through your local network. Open Devices and Printers and select your printer's name, if it is not listed, then add your printer to the list. You can also download the driver software from our website. Double-click the downloaded driver file, click Run and the installation will begin. Follow the on-screen prompts to complete the installation. The driver software can also be installed from the driver CD. Load the CD in the drive and begin the installation. You can choose between Custom install and Easy install. It always better to install all the features. Follow the on-screen instructions and install the driver. Check if you can Print a document after the installation. If you are unable to Print, then follow the troubleshooting procedure or call our tech support for assistance. Guideline to install the HP Printer Drivers visit https://goo.gl/wPGPzp
12/27/2017 4:10:45 AM • HP DeskJet... • Answered on Dec 27, 2017
HP DeskJet 690c plus InkJet Printer Logo
Popular Tags
1 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
printing dillema
  • Office Equipment & Supplies
