20 Most Recent
Canon CLC 1180 Copier Questions & Answers
Canon CLC 1180 Copier Error Code: E071 0007
E071 / E072 / E073
Transfer Frame Connector
Poor Contact due to toner scattering around Transfer Connector
Replace Connector FG6 0948
TD Cleaner assy
Motor M8 being overloaded. Drive shaft from motor goes through long plastic bearings these were getting clogged with toner and oil
clean drive shafts
Transfer driver PCB
Static discharge onto transfer driver from peeling off old TD sheet too fast
Replace Transfer Driver PCB (FG6 - 2579) Remove old TD sheet SLOWLY to prevent problem.
Problem for Canon CLC 1180
• The operation of a fan (indicated by detail code) is faulty. • The CPU PCB is faulty. • The DC driver PCB is faulty
0001 The electrical unit fan (FM8) has stopped to rotate in error check fans for dirt and it is ok
Error e020/04e0 for clc 1180
You need to Reset Code From Function_Clear_Err_OK. Check Dens_K in Display_Dens if it is to less i.e. bellow -2.5 Check Whether Black toner is present in hopper or replace Black developer
How do i reser error code e005 0100
How to clear fixing web counter after replacement of fixing web roller: E005 Error Code
[ Case in the field ]
Field Remedy
Execute the following service mode items.
1. COPIER > COUNTER > MISC > FIX-WEB
2. COPIER > COUNTER > DRBL-1 > FX-WEB
Error code E061
Solution :
When the front door was closed, it was not opening the laser shutter all the way. That is why the problem was intermittent. Adjust laser shutter and front door actuation for proper operation.
