20 Most Recent
Intel Chipset 56K V.92 PCI Data/Fax/Voice Modem with Speakerphone (INTCIAIE56) Questions & Answers
How much does it cost
You should give us more detail to work with but generally, 56K modem add-on cards can be had for a few dollars from China on eBay or from such sources as Newegg or TIgerDirect. Conexant is only one of several makers and most will use the same chipset.
If the Conexant chip on a main board has failed, you can generally remove it (disable) from your CMOS setup and use a plugged in card which are available for several different bus systems.
How can i use from speakerphone
1. Insert the card into the slot and check if the PC detects the hardware
2. Install the driver which came along with the hardware.
3. From your posting I only guess that you are having some issue with the drivers. If the driver which came with the hardware is not working then go with the defualt drivers. (Let the OS search a match for the hardware).
4. You can always go back and search for a good driver after this.
Modem driver
i want to down load free modem drivers for my pc
How long does the Intel i7-930 processor expected to last?
The best way to prolong life of a computer is to blow out dust from the case and cooling fins and power supply regularly, at least every year. That prevents overheating - a primary cause of component failure. Do not overclock.
Do periodic full disk backups and intermediate new file ones. Leapfrog between two external disks. They are cheap. Protect them from fire.
Laptops - same story,, do not block cooling holes by putting on a blanket while lounging. And turn off machine before blowing out dust. Do not use full PSI compressor air! maybe 20 PSI...
Intel D865GVHZ Motherboard won't boot into anything but will turn on
If your Intel D865GVHZ motherboard is not booting and you've tried replacing the CMOS battery, resetting it, reseating RAM, and changing the PSU, it may indicate a more serious hardware issue. You should consider checking the following:
1. Check the monitor: Ensure that the monitor is functioning correctly by trying it with another computer.
2. Check the connections: Verify that all cables, including the power and video cables, are securely connected.
3. Inspect for hardware failures: Check for any visible signs of hardware damage or loose components on the motherboard.
4. Test with minimal hardware: Disconnect all unnecessary peripherals (e.g., external drives, graphics cards) and leave only the essentials connected (CPU, RAM, power, and monitor) to rule out any conflicts or faulty hardware.
5. Try a different RAM: If possible, test with different RAM modules to rule out faulty memory.
6. Listen for beep codes: If your motherboard has a speaker, listen for any beep codes during startup, as they can provide clues about the issue.
7. Inspect the CPU: Check the CPU for any damage or bent pins, and ensure it's seated correctly.
If none of these steps resolve the issue, it's possible that your motherboard or other critical components may have failed, and you may need to consider a replacement or professional diagnostics to pinpoint the exact problem.
Smart response technology
Intel Smart Response Technology (SRT) is used for SSD caching to improve system performance. To use it successfully, here are some steps to consider:
1. SSD Compatibility: Ensure that your SSD is compatible with SRT. It should be a SATA SSD.
2. BIOS Settings: In the BIOS, set the SATA mode to RAID (not AHCI or IDE) before configuring SRT. Make sure your motherboard supports SRT as well.
3. Driver Installation: Before enabling SRT, install the latest RAID drivers provided by your motherboard manufacturer.
4. Backup: Backup your important data because enabling SRT involves data migration.
5. Enable SRT: In the BIOS, set the SRT mode to "Enhanced" or "Maximum" depending on your preference.
6. Initialize SSD: Initialize and format the SSD through Windows Disk Management.
7. Install Intel RST: Download and install the latest Intel Rapid Storage Technology (RST) driver and software for your chipset.
8. Enable SRT in RST: Open the Intel RST software and enable SRT. You should see an option to accelerate your HDD with your SSD.
9. Reboot: After configuring SRT, reboot your system.
10. Verify: Check if SRT is working by opening the Intel RST software. It should show your SSD as a cache for your HDD.
If you're encountering crashes or issues, it's essential to ensure compatibility and follow these steps carefully. If the problem persists, consider seeking assistance from your motherboard manufacturer's support or Intel's support, as it could be related to specific hardware or software conflicts.
How can I troubleshoot a slow computer performance?
The end part of your question makes it sound like an advert.Download and run the Free version of CCleaner. Remove TSR (terminate and stay resident) programs on start up. These are the programs that run in the background.Download CCleaner 6 For Free - Make Your PC Faster & Saferccleaner.comhttps://www.ccleaner.comClean Temporary Files, Optimize & Speed Up Your Computer. Download Now. The No. 1 Tool for Cleaning Your PC. Download CCleaner now. Browse Solutions. View Products. Multiple Payment Options...
The Green led on the motherboard is ON, and the Intel D915gav won't turn on even though it was working well the day before.
There are several possible reasons why your Intel D915gav motherboard won't turn on, even though the green LED on the motherboard is on. Here are some troubleshooting steps you can try:
- Check the power supply: Make sure the power supply is turned on and connected properly to the motherboard. Verify that the power cable is securely plugged into the wall socket or power strip and into the power supply unit. Also, check if the power supply is providing the correct voltage to the motherboard.
- Inspect the RAM: Check if the RAM is seated properly in the slots. Remove the RAM and re-insert it, ensuring it's seated firmly in place. You can also try booting with one RAM stick at a time to see if one of them is faulty.
- Check for loose connections: Check all cables, connectors, and wires to ensure they are properly seated and secured. Make sure there are no loose wires, frayed cables, or damaged components.
- Test the power button: If the power button on your computer is not working, the motherboard won't turn on. Try connecting the power button pins directly to the motherboard to see if it turns on.
- Clear the CMOS: Try clearing the CMOS memory to reset the BIOS settings. This is done by removing the CMOS battery for a few minutes, then re-inserting it and restarting the computer.
- Check the CPU: Make sure the CPU is seated correctly in the socket and that there is no thermal paste residue between the CPU and the heatsink. If there is, clean it off and reapply fresh thermal paste.
If none of these steps resolve the issue, it's possible that the motherboard or another component has failed and may need to be replaced.
