20 Most Recent Ruud UAKA042 Air Conditioner Questions & Answers
I want to know if this will be good for a mobile home
Not the inside part. Must be made for Mobile home!
3/6/2016 5:24:08 PM • Ruud UAKA042 Air... • Answered on Mar 06, 2016
I need to know if the Ruuduaka-042jaz 3.5 is good for a mobile home
The outside unit will work,but not the matching furnace! you have to have a specific manufactured home furnace, because off Co
3/6/2016 5:22:47 PM • Ruud UAKA042 Air... • Answered on Mar 06, 2016
I have infinity system and it is not blowing cold
check thermostat and breakers. need 240 volts a.c. and 24 volts a.c at outside unit.
8/17/2015 9:21:23 PM • Ruud UAKA042 Air... • Answered on Aug 17, 2015
Upka 035jaz
match original loosen mounting bracket if necessary to read its mfd. rating.
8/17/2015 4:41:37 PM • Ruud UAKA042 Air... • Answered on Aug 17, 2015
Ruud achiever photos Jakob 042-jaz
thermostat, outside unit bad contactor. inside unit fan relay.
8/17/2015 3:32:03 PM • Ruud UAKA042 Air... • Answered on Aug 17, 2015
How do i know what capasitor to use for replacing
it has to be the same value in mfd. as the existing cap.
8/12/2015 9:01:11 PM • Ruud UAKA042 Air... • Answered on Aug 12, 2015
Rheem RPGB-37JAS. I purchased Defrost Control Kit
C- is common/ground of the board FM transformer
R-is 24 volts to the board FM transformer
B- is to energize reversing valve for heat from thermostat.
D- energizes the electric heat in defrost mode.
Y-comes from the thermostat and energizes the compressor and condenser fan motor by pulling in the contactor.
6/21/2015 5:40:46 AM • Ruud UAKA042 Air... • Answered on Jun 21, 2015
High pressures real low and low pressure is good What is wrong.
It could be inefficient compressor. If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_70df8fb57a5e233e
2/24/2015 12:27:48 PM • Ruud UAKA042 Air... • Answered on Feb 24, 2015
replace the contacts,,,,
11/25/2014 8:15:54 PM • Ruud UAKA042 Air... • Answered on Nov 25, 2014
74 psi on the suction side of a 1/12 ton 2 -22 home condenser unit ok?
the psi on your unit will fluctuate ...dirty filter will cause it to be lower'' high humidity will cause it to be higher,,, the perfect scenario is 95 outside, 75 inside with 50 percent humidity,,, then it should read 68 psi which is a 40 degree coil temp. only when these conditions are perfect will your psi be 68psi
11/25/2014 8:14:18 PM • Ruud UAKA042 Air... • Answered on Nov 25, 2014
Why are my high pressure real low and low pressure is good on my r-22 heat pumpWhat is wrong.
high side is dependant on outside air temp.... or could be a restriction in high side line
9/1/2014 1:40:58 AM • Ruud UAKA042 Air... • Answered on Sep 01, 2014
5answers
AC unit runs inside but not outside! help
check breaker thermostat set cooling auto call for service.allso get it cleaned both coils.. Tom
5/9/2014 11:13:17 PM • Ruud UAKA042 Air... • Answered on May 09, 2014
Outside unit wont start
compressor probably out. check connect at outside breaker box.
10/17/2013 4:21:22 PM • Ruud UAKA042 Air... • Answered on Oct 17, 2013
Is ruud heat pump model upka-042jaz a single or multiple stage pump?
I NEED THE MAKE AND MODEL OF THE T-STAT TO HELP YOU
DID HE CHANGE ANY WIRING?
9/2/2013 11:41:48 PM • Ruud UAKA042 Air... • Answered on Sep 02, 2013
2answers
Outdoor fan motor will not
Hello, if you try to spin the motor by hand or with a stick and it starts then the problem is a bad capacitor, if it does not start then the motor is shot.
7/15/2011 12:11:20 AM • Ruud UAKA042 Air... • Answered on Jul 15, 2011
Ruud UAKA042 Air Conditioner Logo
Popular Tags
59 questions posted
Top Ruud Heating & Cooling Experts
john h
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Ruud Heating & Cooling
Most Popular Question
infinity system not blowing cold
  • Heating & Cooling
