20 Most Recent Ruud UAKA037 Air Conditioner Questions & Answers
2answers
I have a Ruud UAKA-037JAZ
Need furnace model number. It sounds like you're looking for a standing pilot. Your furnace might not have one. Very likely to have a spark ignition type system or hot surface igniter.
5/4/2018 4:12:23 AM • Ruud UAKA037 Air... • Answered on May 04, 2018
My Ruud silhouette II some times will not operate.
4 Blinks is an error code of a sticking pressure switch. A pressure switch is a safety, which in this case is being used to verify that your furnace is drafting properly. Yours in particular is sticking in the closed position even after the call for heat is satisfied. The control board checks to make sure the switch is open the next time there is a call for heat, and when it sees that the pressure switch is already closed even before the draft inducer motor comes on, it knows there is a problem....hence the error code. If you tap on the pressure switch, it may cause the contacts to open. Usually you will see a rubber hose attached to the pressure switch and 2 or three wires depending on what type of switch it is. You will probably have to replace the switch, but maybe this will get you thru the night. Hope this helps!
12/13/2017 1:29:10 PM • Ruud UAKA037 Air... • Answered on Dec 13, 2017
How can I find the age of a lennox A/C system from the model or sreial numbers?
you need the serial #
8/11/2015 2:33:05 PM • Ruud UAKA037 Air... • Answered on Aug 11, 2015
2answers
The inside unit turns on and the motor is working
Some fan in outdoor works only after pressure build up.
2/9/2015 5:29:33 PM • Ruud UAKA037 Air... • Answered on Feb 09, 2015
Heater will not start
If you are getting air conditioned air when you are supposed to be getting heat, the compressor is working but the valve that reverses the refrigerant flow for heat to be created could be stuck in the default postion which for a Ruud is air conditioning. There is also a special output on your thermostat to activate the heat cycle and reverse the valve.. Maybe that is not working and the cause of your anomaly.
10/11/2014 1:34:58 AM • Ruud UAKA037 Air... • Answered on Oct 11, 2014
Capicator on ac
what about it???????
9/1/2014 1:49:06 AM • Ruud UAKA037 Air... • Answered on Sep 01, 2014
How can I determine the age on my hvac system?
need the serial ##
8/19/2014 5:47:51 PM • Ruud UAKA037 Air... • Answered on Aug 19, 2014
Have a R-22 Rudd ait
If your home is 1300 square feet 1.5 tons is not going to cut it you should have at least 2.5 ton A/C unit. sounds like your system is to small. let me know if this helps you out.
4/20/2014 8:28:16 PM • Ruud UAKA037 Air... • Answered on Apr 20, 2014
Hello, I have a Ruud Acheiver AC unit that has been working for years but now will not start. I began trying to diagnose what may be the problem by first making sure the thermostat was set correctly.
Check the two wire going to the Condenser unit...make sure there is not a short. Your transformer seems fine.
12/7/2013 12:46:35 AM • Ruud UAKA037 Air... • Answered on Dec 07, 2013
WHERE IS THE LIMIT SWITCH
it in the furnace
11/24/2013 5:38:44 PM • Ruud UAKA037 Air... • Answered on Nov 24, 2013
Why wont my Ruud air conditioner turn on??
the compressor is shot.
10/17/2013 4:25:29 PM • Ruud UAKA037 Air... • Answered on Oct 17, 2013
Capacitor hook up
Fan wire go to the fan terminal, Commons for the fan and power supply go to the C or common terminal, Compressor wire goes to herm terminal
7/26/2012 1:43:46 AM • Ruud UAKA037 Air... • Answered on Jul 26, 2012
Is there a rest button for rheem 3 ton air handler
Must be a bad capacitor or a bad contactor.
I have some repair pictures:
OUTSIDE CONDENSER BLUES
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
7/23/2012 2:16:31 PM • Ruud UAKA037 Air... • Answered on Jul 23, 2012
Ruud UAKA037 Air Conditioner Logo
83 questions posted
Top Ruud Heating & Cooling Experts
john h
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Ruud Heating & Cooling
Most Popular Question
u replace fan board rheem fan
  • Heating & Cooling
