20 Most Recent Nikon Coolpix P2 Digital Camera Questions & Answers
Howl canI transfer photos from Nikon coolpix P2 to my hp computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
9/23/2014 4:25:35 PM • Nikon Coolpix P2... • Answered on Sep 23, 2014
My nikon coolpix p2 camera says this memory card
Have you formatted the memory card? When you buy a new memory card, you must go in your camera's menu and find the "format memory" selection and perform the format function. Once formatted by your camera, it should work.
6/8/2014 6:59:49 PM • Nikon Coolpix P2... • Answered on Jun 08, 2014
3answers
I have a Nikon coolpix P2. I have a SD card in it
You should try some photo recovery software to rescue the pictures on your SD card, here are some you may rely on. Both programs can also recover videos and music.
Photo Recovery Software (for Windows)
Mac Photo Recovery Software (for Mac OS X)
Be careful: Before your pictures are recovered, do not attempt to save more files to the memory card in case the original files(your pictures) are overwritten.
10/14/2013 2:02:39 AM • Nikon Coolpix P2... • Answered on Oct 14, 2013
Nikon p2 lens erros lens won't open
This link can find details about everything you can try to fix it without sending it to a repair shop: Fixing-lens-error-on-digital-cameraHope helps.
8/15/2012 5:01:36 PM • Nikon Coolpix P2... • Answered on Aug 15, 2012
2answers
Recently, I have been experiencing trouble with my
Hello - from what you said - it sounds more like a sensor problem in the camera.
If the screen looks OK while sizing up a picture , then 'click' Image is stored on sensor which is read as one LARGE matrix of dots and stored into memory.
If the white lines start at this point - ie. viewing the picture while in camera and then after download.
Then, the problem started at the sensor.
I just did a (www.goggle.co.uk) and did a search for problems - and NONE apart from Wi-Fi connections to Windows7 -- all reviews were great.
I would connect Nikon to see what they recommend . -- Ray
7/11/2012 7:12:45 PM • Nikon Coolpix P2... • Answered on Jul 11, 2012
Pics wont transfer any longer
Having gone over two months without a response to my query, I assume my suggestion to use a card reader solved the problem.
10/20/2011 10:31:12 PM • Nikon Coolpix P2... • Answered on Oct 20, 2011
White lines across clicked images.
yes that it
9/18/2011 5:41:49 PM • Nikon Coolpix P2... • Answered on Sep 18, 2011
2answers
I need to transfer photos
Turn the computer on and wait for it to start up. After confirming that the camera
is off, connect the UC-E6 USB cable (provided with your camera) as shown below.
Check to be sure the connector is in the correct orientation and insert the
plug straight. Do not insert or disconnect it forcibly. Connect the camera directly
to the computer; do not connect the cable via a USB hub or keyboard.
Turn on your cameram,be sure to select Mass storage before reconnecting the camera.
Or you can transfer your photos using an card reader ...
5/7/2011 8:13:04 AM • Nikon Coolpix P2... • Answered on May 07, 2011
I've been trying to transfer my photos from my
PictureProject was retired years ago, replaced by Nikon Transfer and Nikon ViewNX. You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
4/10/2011 3:28:59 AM • Nikon Coolpix P2... • Answered on Apr 10, 2011
My computer does not have
You might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
4/7/2011 6:26:22 AM • Nikon Coolpix P2... • Answered on Apr 07, 2011
I have a red blinking
Hello - It just means that your date/time has to be setup in the menu. It probably lost the time when you switched out batteries.
Turn the dial on the top of your camera to Setup and a Setup menu will appear. Go down to Date and set the date and time. when your finished move the dial back to the normal (image of camera) setting.
Thanks for using Fix Ya!
Mikeyaf
3/16/2011 3:26:36 AM • Nikon Coolpix P2... • Answered on Mar 16, 2011
When i take pictures,horizontal lines appear and
From what you said - it sounds more like a sensor problem in the camera.
2/11/2011 12:43:53 PM • Nikon Coolpix P2... • Answered on Feb 11, 2011
I want to transfer pictures
You should be able to take the memory card out of the camera and insert it in the computer in a card reader slot. If your computer does not have these card slots you can get a card reader at a computer store and hook it up with a USB cord. try someone like radio shack to see if you can get a new cord for your camera, they have many different types and adapters to chose from.
11/14/2010 8:50:59 AM • Nikon Coolpix P2... • Answered on Nov 14, 2010
Lens error message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
11/9/2010 4:44:35 AM • Nikon Coolpix P2... • Answered on Nov 09, 2010
I canot clear the profile in the camera to add a
Go into the menu and find "reset" and follow the on-screen instructions to return to factory default settings
11/3/2010 8:30:53 PM • Nikon Coolpix P2... • Answered on Nov 03, 2010
HOW do I transfer my pics from camera to macbook?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use a photo cataloging program, such as Nikon Transfer for Apple iPhoto.
10/11/2010 4:29:05 PM • Nikon Coolpix P2... • Answered on Oct 11, 2010
My Nikon dig camera need
1) Can you try another PC ? (Could be a USB fault)
2) Could be you need another battery (Nikon EN-EL8)
3) Can you charge it by means other than a USB port ?
Here's a handy web site :-
http://www.retrevo.com/s/Nikon-P2-Digital-Cameras-review-manual/id/200dj489/t/1-2/
9/21/2010 8:31:49 PM • Nikon Coolpix P2... • Answered on Sep 21, 2010
Nikon Coolpix P2 Digital Camera Logo
32 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
need transfer photos
  • Cameras
