20 Most Recent Ruud UAPA042 Air Conditioner Questions & Answers
Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
7/15/2011 11:46:32 PM • Ruud UAPA042 Air... • Answered on Jul 15, 2011
I have a 2 ton central unit for my upstairs. It is
Hello, it could be that the unit is slightly undercharged and has a small leak. Usually when the cooling is needed the most the ac wont be able to keep up with the heat load as you mentioned.
7/15/2011 3:13:11 PM • Ruud UAPA042 Air... • Answered on Jul 15, 2011
RUUD Silhouette II UGLH-15EARJR not always coming on
It sounds like there may be an issue with the ignition system of your RUUD Silhouette II UGLH-15EARJR furnace. Based on your description, it appears that the furnace is not always coming on correctly. The blower comes on, but after 30 seconds, you hear a click, and the far-right flame comes on, but it goes out after 5 seconds. Eventually, throughout the day, all the flames come on, but they don't come on the first time. This problem could be caused by several issues, including a malfunctioning ignition system, a problem with the flame sensor, a dirty or clogged burner, or a problem with the gas valve. To troubleshoot this issue, I would recommend checking the following:
  • Check the flame sensor and make sure it's clean and properly aligned with the flame
  • Check the burner and make sure it's clean and free of debris
  • Check the gas valve, it could be stuck closed or malfunctioning
  • Check the thermocouple, it could be faulty
  • Check the control module, it could be malfunctioning
It's important to note that gas appliances are complex systems that require specialized knowledge and skills to troubleshoot and fix. If you are not comfortable working on these issues, it's best to call for professional help, as it may require specialized knowledge and skills to troubleshoot and fix the problem.
1/18/2023 3:28:47 PM • Ruud Heating &... • Answered on Jan 18, 2023
Ruud standing pilot furnace burners won't ignite?
You need to clean the pilot its blocked when it burns yellow .No heat in it.
1/15/2023 9:10:10 PM • Ruud Heating &... • Answered on Jan 15, 2023
Ruud silouette furnace model number UGLJ-07EAUER had the control board replaced 24 hrs later the blower does not kick off once runs continuously.
Your fitter didn't fix the original issue it would seem. That is the problem with fitters, they cannot repair things.
11/16/2022 8:10:48 AM • Ruud Heating &... • Answered on Nov 16, 2022
Where is the pilot light for RUUD Furnace model UGAC-045C
The pilot light for RUUD Furnace model UGAC-045CJB is located on the control panel.
11/5/2022 12:56:30 PM • Ruud Heating &... • Answered on Nov 05, 2022
My Ruud Achiever 90 Plus MDL: UGRA-09EZAJS is 17 years old. Runs fine but wonder if I should replace the blower motor and go to a variable speed motor
The variable speed DC motors you describe do use less power but cost 14 times more too, not worth it especially with you motor running!
10/23/2022 10:17:34 PM • Ruud Heating &... • Answered on Oct 23, 2022
2answers
Electricity dropped momentarily; AC no longer cools
Open the main breaker for 5 minutes and see if the unit resets. Momentary power fluctuations can cause odd behavior, especially in older units. This could also have been the final jolt that killed a failing capacitor.
9/17/2022 3:01:26 AM • Ruud Heating &... • Answered on Sep 17, 2022
RUUD AC, what dual round capacitor do I need?
Check out the link. replace by shape and contacts. https://www.google.com/search?q=RUUD+Achiever+10%2C+replacement+capacitor Compressor https://www.google.com/search?q=copeland+zr34k1-pfv-230+capacitor Fan Capacitor https://www.google.com/search?q=Emerson+Model+K55HXJKL-2918+capacitor Or contact Rudd direct, we aren't they
Capacitors - Ruud Replacement Parts
https://parts.ruud.com > category > ru-capacitors Dual Oval Capacitor - 55/10 uF, 440 VAC, 1.970 x 3.670 x 5.750 (max.) in. .....
8/9/2022 5:29:16 PM • Ruud Heating &... • Answered on Aug 09, 2022
3answers
Help me replace Ruud Achiever 12 contactor?
https://homesteady.com/how-8185688-replace-ruud-ac-contactor.html
8/5/2022 9:29:40 PM • Ruud Heating &... • Answered on Aug 05, 2022
Have old Ruud heat pump 10 seer model # UPKA-031JAZ serial #6389 & my start capacitor has stopped doin it's job. What is the replacement part number please
You can get an aftermarket replacement as long as the ratings are the same. I keep a spare for my unit and its saved me several times over the years.
As to your question, it looks like the part number is 43-23204-04. Looks like several options for those specs on Amazon.
7/25/2022 8:37:32 PM • Ruud Heating &... • Answered on Jul 25, 2022
2answers
I got no nameplate info on an older RUUD system late 1990's and blower motor is not working also specs are not readable. How do I know what size motor to use?
First off how do you know the motor is bad? Have you checked for voltage, the capacitor, the relay? The motor itself will have a data plate telling you horsepower/voltage/rpm/shaft size.
6/26/2022 6:47:02 PM • Ruud Heating &... • Answered on Jun 26, 2022
Ruud Ultra U96V furnace that won't shut off
have you checked and tested the relay for overheating or sticking on when the problem occurs
4/19/2022 12:35:29 AM • Ruud Heating &... • Answered on Apr 19, 2022
2answers
Where is the flame sensor on the Ruud Silhouette ll Gas Furnace
Right at the end of the pilot light.
11/7/2021 6:18:04 PM • Ruud Heating &... • Answered on Nov 07, 2021
Ruud UAPA042 Air Conditioner Logo
4 questions posted
Top Ruud Heating & Cooling Experts
john h
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Ruud Heating & Cooling
Most Popular Question
2 ton central unit upstairs
  • Heating & Cooling
