20 Most Recent
Frigidaire Freezer Refrigeration White Small Compact Chest Freezer Model FFC0723DW Questions & Answers
What are the instructions for defrosting my
well when i used to have to climb into super market freezers and defrost we used water from the tap it doesn't have to be hot so i would take freezer outside to do this as it might not be drained and if it does have a drain it would only take a minute amount of water which an element would heat up and burn off so empty freezer take outside wash out with water till all gone and to get rid of any smells was out with vanilla essence all fridgies i know and myself used this as it will clean out fridge smells, you then replace freezer back once all water has dried off especially electrical try not to get wet but if you can't help it, it won't matter just let dry or blow out with air compressor then replace freezer back to where come from run freezer for a while till temperature drops below zero then start to restock the more you put in it the longer it'll take to freeze, so just do little by little hopefully this has helped but its usually the only way to do this
There is freezer burn on chicken in plastic packages
Hello
Welcome to Fixya
My name is Huum,
You need to use good freezer bags and not just plastic bags in the freezer.
And use these products witin six months..
When you put food into a plastic container for the freezer.
you need to burp the container.
That means to hold it with two hands and with one hand raise the corner of the lit a tiny bit while with the other hand you press down on the center of the lid and close the corner quickly so as to have burped out most of the air in the container. a little like a vacuum packed container.
So less air is in the container to cause condensation inside which is the frost you are getting
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
My Frigidaire up right freezer is showing an error code "FF" and is beeping. What is the issue?
Hey friend, thanks for your inquiry!
Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
