20 Most Recent
Pioneer (DVR-K16) DVD RW Dual Layer Burner Questions & Answers
I have presario v6500 Notebook
you have gone backwards in operating system and it is possible that the driver for the notebook is not compatible for win xp
as win xp is no longer being supported by microsoft it is better to stay on vista or install win 7 as all downloads are now orientated to the later operation systems
7/22/2017 10:23:40 AM •
Pioneer...
Answered
on Jul 22, 2017
Pioneer DVR-K16D driver?
www.findmysoft.com/drivers/Vaio-VGN-BX394VP-Pioneer-DVR-K16-Update-1-10-firmware-driver.html , free download your driver cd in the above website
1/25/2014 1:07:04 PM •
Pioneer...
Answered
on Jan 25, 2014
Hello, I have prblem regarding
Hi rafikuss
It is required to use a cable corresponding to U-ATA66 (80-wire conductor cable).
If this isn' t the cause , test with other manufacturer's dvd's .
Hope this helps ,
Best rergards ,
fanaudi .
8/27/2011 8:53:22 AM •
Pioneer...
Answered
on Aug 27, 2011
My dvdrw dont recognize Dual
are these the only dvd's that cant be read?? Click start control panel
administrive tools,computer management,device manager scroll down cd-dvd rom
drives you might see a yellow question mark ? right click you will have options
to update driver,roll back driver,or select properties general troubleshoot,
select driver click to reinstall drivers click update driver or uninstall
then reinstall if this does not fix the problem it might be a registry problem
if you cant see your disk drive in windows explorer
Close all open
programs
Click on
Start, Run, and type regedit and press
Enter
Click on the plus signs (+)
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column.
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug
them back this should activate the found new hardware wizard or
you might have to uninstall
then restart your computer then reinstall your DVD/CD then reinstall the driver
for this device
if your computer came with
a motherboard disk the drivers could be on it
click start control panel
administrive tools computer management device manager scroll down cd dvdrom
drives if you see a yellow question or exclamation mark?! or a red x
right click you will need to update the driver
or
select properties general troubleshoot, select driver
hope this helps
8/3/2011 9:16:55 PM •
Pioneer...
Answered
on Aug 03, 2011
I have uninstalled and reinstalled
make sure that the dvd-rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this dvdrw then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
only do the registry check if you cant see the drive/s in windows explorer/my computer
or it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps
2/6/2011 11:15:49 PM •
Pioneer...
Answered
on Feb 06, 2011
Pioneer DVD R/RW drive DVR-K17LA not reading
Normally no drivers are needed for CD drives other than the ones built into Windows. It might be a dirty lens that is causing the trouble. When the tray opens on a laptop CD drive the lens is exposed and can get touched or exposed to dirt. Try gently cleaning it with a cotton swab to brush off the lens. If the problem continues, the laser may have worn out and is too weak to read now. You can find replacement drives online, or use a USB plug-in external drive.
1/3/2011 8:14:00 AM •
Pioneer...
Answered
on Jan 03, 2011
Does my sony vaio have
Please post the Exact Model # of the Computer.<br /><br /><a href="http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=FAQ&PRODTYPE=1">Please click here to for the instructions to find the model # of the Computer.</a><br /><br />Then, click the "<b>Detect My Model</b>" button on the page.<br /><br />Still not found..then..click the below link..<br /><br /><a href="http://esupport.sony.com/US/perl/support-info.pl?info_id=264">http://esupport.sony.com/US/perl/support-info.pl?info_id=264</a><br /><br /><br /><br />
8/25/2010 5:02:09 AM •
Pioneer...
Answered
on Aug 25, 2010
Region code
windows allow 5 changes but to mod this install DVD GENIE, it will kill the regions
7/27/2010 4:17:24 PM •
Pioneer...
Answered
on Jul 27, 2010
My sony laptop can not read pioneer dvd rw dvr k16d
Try the dangerous brothers on google they have all firmwares check carefully that match your dvd, this is at your own risk, but usual vaio should come with a back up cd where you can roll back your drivers
7/27/2010 4:15:12 PM •
Pioneer...
Answered
on Jul 27, 2010
My pioneer laptop dvd rw dvr k16 ra has the same
gustav94I have the same dvd player and had the same problem, I just couldn't read my data cds and it was so frustrating windows kept telling me the cds with data were blank, i searched thoroughly over the net for an answer but most involved registry mods or flashing the firmware which could bog your dvd for life.
I was about to give up and get a hammer and whack the computer when i decided to get a dry cotton bud and gently wipe the laser lens of the dvd player, and guess what?
my good old data cds were being read!!!
kudos to classics.
7/27/2010 4:07:22 PM •
Pioneer...
Answered
on Jul 27, 2010
