20 Most Recent Pioneer DVR-111D (DVR111DBK) DVD RW Dual Layer Burner Questions & Answers
WHEN I BURN A MOVIE IT WON'T SHOW UP ON DVD DISC
Sounds like it may have burned the movie file as a data DVD.
In other words, the file gets burned to the DVD just like a Word doc or spreadsheet would, rather than encoded as a movie.
You need to check what format you downloaded it in - it may need conversion before burning as a movie DVD.
You can run a quick web search for *** (your current file format - mpg, divx, etc.) to DVD and find a free utility for conversion.
Then your burning software should be able to burn it as a movie DVD, ready for your player.
3/3/2015 12:49:46 AM • Pioneer DVR-111D... • Answered on Mar 03, 2015
2answers
DVD-RW DVR- 111D repair manual
www.pioneer.eu/eur/products/archive/DVR-111D/media.html
10/3/2014 4:11:06 PM • Pioneer DVR-111D... • Answered on Oct 03, 2014
DVR-A18L series not detect for pentium 4 and
you may need to get a firmware update you should find it http://www.pioneer-dvdasia.com/Download_Firmware-Download.asp on this linkhope it works for you
10/21/2013 10:16:46 AM • Pioneer DVR-111D... • Answered on Oct 21, 2013
6answers
DVD-RW not recognising blank disk
If the drive reads commercial CDs and DVDs and your software is configured correctly then I would suspect media or the drive itself. 1) Buy a good optical drive cleaning kit, clean and retest. 2) Buy some of the DVD media the manufacturer recommend and run tests with that since they will suspect the media as well. Also make sure you purchase media that is certified for the recording speed of your drive as well. Physically check both sides of the blank disk for gouges or scratches. When you run your test don?t assume every piece of media you have is good. I?ve had as many as three in a row fail to be recognized before I get a good one. Yep, this even happens with the top of the line brands on occasion. 3) Check your burning software and make sure you have the right drive set to be the target drive. If you have multiple optical drives on your PC don?t assume you know the correct drive letter, test it. Sometimes things change without you knowing?? 4) You can also try putting the drive in another PC (if you have that option) on the off chance something weird is going on with the cabling, power or controller. I also had a rash of users with this type of problem a few years ago. Most of the incidents were solved by using name brand media such as HP, Maxell or Fujifilm. They were buying the really cheap, no name brands from the campus store (paying premium prices to boot). Three other users actually had defective burners which took some time to isolate since the problems were sporadic. To be honest I actually had to fib to get the manufacturer to take them back but once the new drive was installed the problems never reappeared.
7/15/2011 9:12:34 PM • Pioneer DVR-111D... • Answered on Jul 15, 2011
When I insert a blank
Go into your system profiler. Make sure the DVD is showing up. Click the DVD and check what disks it can use and make sure the disks you are using are compatible.
Best of luck, Jim
5/1/2011 5:17:08 PM • Pioneer DVR-111D... • Answered on May 01, 2011
I have the pioneer dvd-rw
HI,
This is gonna be a bit complicated since were going to access your registry, but just follow all the steps and it will be much easier
>Click on START
>Type REGEDIT on the search bar on START Menu
>Expand HKEY_LOCAL_MACHINE
>Expand SYSTEM
>Expand CurrentControlSet
>Expand Control
>Expand Class
>Click {4D36E965-E325-11CE-BFC1-08002BE10318}
>Look for the Upper Filters / right click on it / click on Delete
>Look for the Lower Filters / right click on it / click on Delete
>Restart PC
>Try you CD / DVD ROM
If nothing happens, click on this link then click on RUN and follow the steps, then restart computer and try to run a disc again, if still nothing happens, theres a possibility that the problem is with the hardware side or the media player that you are you using...
Hope this will help...Your response is very much appreciated...
2/6/2011 10:39:34 PM • Pioneer DVR-111D... • Answered on Feb 06, 2011
My pioneer dvd burner wont burn dvd dl+R discs
use +- dvd
12/22/2010 12:12:51 AM • Pioneer DVR-111D... • Answered on Dec 22, 2010
0answers
I cannot burn cds or
you won't never burn a dvd if the room doesn't say "dvd rom rewriteble"
10/21/2010 10:46:12 PM • Pioneer DVR-111D... • Answered on Oct 21, 2010
Pioneer dvr 111d unable to write CRrw of heigher
This could be the actual CD/DVD/DVDDL/RAY disc that you are using, try using an app called imgburn to see the medias fastest speeds.
6/2/2010 6:16:51 PM • Pioneer DVR-111D... • Answered on Jun 02, 2010
Why does my dvd burneer keep failing when burnning
1'st thing I look for is a "firmware update" for it.
http://www.pioneer.eu/eur/products/archive/DVR-111DBK/media.html
4/28/2010 6:40:24 PM • Pioneer DVR-111D... • Answered on Apr 28, 2010
3answers
I have upgraded my pc.The 2 CD-DVD RW dr ,do not play or record
I advice you to remove one driver and look whether the other is working. Check both the drives this way. Once you find them working, you can get back to your old system, that is, how it is now. This is not based on any logic, but it may work as your problem may be that your newly upgraded system got confused with the two drivers.
4/13/2010 6:05:50 PM • Pioneer DVR-111D... • Answered on Apr 13, 2010
2answers
I've just upgraded my pc from XP to Windows 7
Install the sound driver :P check your sound card name and make a search on google like this one : <sound card name> driver
2/25/2010 7:27:13 PM • Pioneer DVR-111D... • Answered on Feb 25, 2010
2answers
Dvd drive problems
If the drive is recognised then you do not have a problem with the drive. You might have a problem with the zone (Dvds films ).
12/30/2009 5:37:47 AM • Pioneer DVR-111D... • Answered on Dec 30, 2009
3answers
I am attempting to update my dvd-rw 111d drivers,
Hello there jeverts.
Here's your geek-steer ...
You're classically describing a very common trouble. In fact, common enough that Microsoft has published a KnowledgeBase (KB314060) article concerning it. Accomplishing the actions detailed there should "FixYa" up.
Good luck, and please do post back ...
  • to let me (and interested others with similar trouble) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig)
12/20/2009 12:07:58 PM • Pioneer DVR-111D... • Answered on Dec 20, 2009
My drive is listed as DVD-RW-DVR-lllD, but when I
Try burning a disk, and taking the burnt disk to another computer, to see if the other computer recognizes the media as being a DVD disk.
10/28/2009 3:45:46 PM • Pioneer DVR-111D... • Answered on Oct 28, 2009
Please help me my driver dvd rw dvrtd08rs on my
Anyone still having this problem, I downloaded this link from a French troubleshooting site: http://docxp.mvps.org/b1n/DisparitionCD.inf save it to your desktop, right-click and select "Install" then lo and behold, the drive reappears. By far the simplest fix I've found.
8/30/2009 11:53:13 AM • Pioneer DVR-111D... • Answered on Aug 30, 2009
No spin up
did you adjust the jumper settings for corresponding master or slave position?
3/10/2009 4:22:07 AM • Pioneer DVR-111D... • Answered on Mar 10, 2009
2answers
Pioneer DVR-111D DVD RW regional lock
Yes you can when playing the DVD on a computer, there are softwares that switch your DVD-ROM region to suit your DVD and so you can play it, well before i give you links to the site providing such a software let me first check the legality of such softwares.
2/11/2009 10:31:20 PM • Pioneer DVR-111D... • Answered on Feb 11, 2009
Pioneer DVR-111D (DVR111DBK) DVD RW Dual Layer Burner Logo
66 questions posted
Top Pioneer Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
DVR Pioneer
  • DVR Pioneer
Most Popular Question
ve just upgraded pc from xp windows 7
  • Computers & Internet
