20 Most Recent Pioneer DVR-107D DVD±RW Burner Questions & Answers
Maybe the DVD not support this speed!
Pioneer DVR-107D... | Answered on Feb 05, 2018
They have software you can download online to recover files from corupt cd-dvd iso buster is one you have to pay for it, And they are others, just do a search, on -- cd recovery
Pioneer DVR-107D... | Answered on Jan 04, 2016
remove it and and put it back again and set bios to default settings
Pioneer DVR-107D... | Answered on Jan 02, 2015
Is the disk your using homemade or a factory made disk? Some drives just won't read 100% of the disks inserted into them. Have you tried another installation disk to see if the problem persisits? Are you able to "SEE" the files on the disk using Windows Explorer? Can you copy those files to your hard drive? If yes, then try installing from the hard drive files instead of the disk. What OS are you trying to install?
Pioneer DVR-107D... | Answered on Jul 03, 2014
Tip
How to fix non working cd/dvd, shows in device manager with error code..
shove it We encourage you to use Tips and Tricks as a starting point for sharing your technical knowledge and know-how with other FixYa users.
on May 04, 2014 | Pioneer DVR-107D DVD±RW Burner
Try uninstalling software that uses the drive. You can also try uninstalling programs that you don't use by using something like revo uninstaller. Also you can try using a registry cleaner. After that you can try your drive again.
Pioneer DVR-107D... | Answered on Mar 20, 2014
This is my error in report viewer for my dvdrw in laptop.
dvdrw icon is hide and it can't read any disk dvd/cd.
PLEASE HELP ME! THANKFUL
" Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 39. "
Pioneer DVR-107D... | Answered on Jan 16, 2013
I have the same problem. Has anyone found a solution? I have an HP Notebook dv6700 with a Pioneer DVDRW [DVR-K17B ATA Device]. For the past few months I haven't been able to burn anything to disc. I can't find any firmware updates online. I'm not sure if I need to buy a new drive?
Thank you in advance for any feedback.
Pioneer DVR-107D... | Answered on Jan 15, 2013
Follow the below very carefully....it usually fixes these problems. If there are no upper filters, don't worry....just delete the lower filters or vice/versa...get rid of the filters....just follw the guide below. When you get to the registry entries below, the first one maybe the one you need to edit...just read the numbers carefully to make sure you get the right one....it is easier than you think...you can do it!!!
Windows Vista
  1. Click Start
and then click All Programs.
  1. Click Accessories, and then click Run.
  2. Type regedit, and then click OK.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  1. In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  1. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters
    only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  2. On the Edit menu, click Delete.
  3. When you are prompted to confirm the deletion, click Yes.
  4. In the right pane, click LowerFilters.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. Exit Registry Editor.
  8. Restart the computer.
Hello
Trying cleaning the lense with a DVD cleaning kit ,if that does not solve it then it will have to be replaced as this is a problem with the laser.
Some failing drives read but cannot burn others only read CDs and not DVDs and also burn to CD but no longer can burn to DVD and vice versa this is a common drive failure.
Pioneer DVR-107D... | Answered on Mar 01, 2012
download the drivers for this unit from manufactuers website and install them,then check your device manager again
Pioneer DVR-107D... | Answered on Nov 15, 2011
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps you
Pioneer DVR-107D... | Answered on Nov 07, 2011
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Pioneer DVR-107D... | Answered on Nov 05, 2011
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Pioneer DVR-107D... | Answered on Sep 01, 2011
This is common problem burning with a bad quality of discs. Try with better quality discs e.g Verbatim.
Pioneer DVR-107D... | Answered on Aug 06, 2011
if your computer came with a motherboard disc the sound drivers could be on it
Pioneer DVR-107D... | Answered on Jun 29, 2011
have you try disconnecting your dvd rom to your cpu and connect it again? have yo check your dvd cable that connects to your cpu mother board? this are the solution to escalate the problem thanks.
Pioneer DVR-107D... | Answered on May 28, 2011
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
Pioneer DVR-107D... | Answered on May 01, 2011
Pioneer DVR-107D DVD±RW Burner Logo
163 questions posted
Top Pioneer Computers & Internet Experts
Damen Wong
Damen Wong
Carmen Mikulic
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
DVR Pioneer
  • DVR Pioneer
Most Popular Question
dvd not read
  • Computers & Internet
