20 Most Recent
Solis Maestro G385 Electric Burr Grinder Questions & Answers
What do you do when the grinding blade will not
Hi
With the bean hopper on, turn the grinder upside down. Rotate the bean hopper to loosen any grounds that might be holding the burr holder. Now remove the bean hopper and try again to remove the holder. Only the outer burr comes off, this way.
Cleaned the Solis Maestro grinder and re set it to
Hi
Your burr is not locked in. You need to remove the beans from the hopper. Remove the hopper. Remove the burr. Turn the grinder upside down over the trash can. Put the burr back in only make sure that the burr is down. Install the bean hopper and when you turn the bean hopper it should move the burr. Then you can adjust your grind. Make sure that the grinder is running is your going to a finer grind or you could break the grinder. You can turn it to a coarse grind any time.
Stalled... won't grind... makes no sound... it is 5 years old...
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
There are 4 slits on the outside edge.
Insert a screw driver into the grove and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the
motor. It is a thermal fuse and should be replaced by a qualified tech.
Maestro Burr coffee grinder stopped grinding
Hi
Remove bean hopper
Solis Palazzo will grind coffee but will not brew.
I get paid over $90 per hour working from home with 2 kids at home. I never thought I'd be able to do it but my best friend earns over 10k a month doing this and she convinced me to try. The potential with this is endless. Heres what I've been doing......
http://www.salarypay1.com
