20 Most Recent Danware NetOp School for Windows 3.0 Upgrade - 1 Teacher and 30 Students (N30C7030U) Questions & Answers
How to install rockmelt browser when error 0x80072ee7
Yahoo Has Acquired Rockmelt, Apps To Shut Down On August 31st
11/25/2013 6:17:33 AM • Danware NetOp... • Answered on Nov 25, 2013
Please i ask you this but not about of your
You're probably either "trolling" for underage children, or are a "scammer" trying an "identity-theft" scheme.
5/28/2010 5:10:15 PM • Danware NetOp... • Answered on May 28, 2010
Hello how are you doing today
im doing just fine and you ?
5/5/2010 8:31:13 PM • Danware NetOp... • Answered on May 05, 2010
How to solve 76^2-75^2+74^2...............+1^2
= 152
4/20/2010 5:55:41 AM • Danware NetOp... • Answered on Apr 20, 2010
When i try to upgrade
Hi, if you are trying to upgrade from one version to the newer one of avg, well either way when you install in the setup you will need to clik advanched avg setting and at the bottom you will update clik on that it will give you 3 chooses proxy, dial-up or url I always choose url
1/28/2009 7:49:24 PM • Danware NetOp... • Answered on Jan 28, 2009
Enquire
Resolution Suggestion One:
# Test your Internet connection to Windows Update.
A simple solution but one that works in many circumstances!
Test to determine if your Internet connection is preventing you from reaching the Windows Update Web site. To do this, visit the following Microsoft Windows Update Web site to determine if you can download the Iuident.cab file:
http://windowsupdate.microsoft.com/v4/iuident.cab
If a file download dialog box appears, the problem is not with your Internet connection. Click Cancel. If you cannot connect to this link, and you receive a "Page Cannot Be Displayed" error message, your Internet connection is preventing you from reaching the Windows Update site.
I TRY THIS OPTION AND I HAVE NO PROBLEM
Resolution Suggestion Two:
# Reconfigure or update your firewall program.
Reconfigure or update your firewall program so that Windows Update is not blocked, and then try to update your computer again by using Windows Update. For information about how to reconfigure or update your firewall program, see the documentation that was included with the program, view the Help files for your program, or contact the manufacturer's technical support department.
e.g It my mean Opening TCP/IP 443 in both directions for this process: %windir%\system32\svchost.exe
I DONT HAVE A FIREWALL PROGRAM.
Resolution Suggestion Three:
# Remove Windows Update entries from the HOSTS file.
To remove Windows Update entries from the HOSTS file, follow these steps:
-Click Start, point to All Programs, point to Accessories, and then click Notepad
-On the File menu, click Open.
-In the Files of type box, click All Files.
-In the Look in box, locate the following folder:
C:\Winnt\system32\drivers\etc\
-Double-click to open the hosts file.
-Remove any lines that contain entries for Windows Update (http://v4.windowsupdate.microsoft.com).
-On the File menu, click Save.
-Close Notepad.
I have seen the 0x80072EFD error resolved by this tip many times...
HERE I AM... I DON'T HAVE A HOSTS FILE... I NEED TO STOP HERE
AND SOLVE SOMETHING?
WHAT HAPPEN WITH THE NEXT SUGGESTIONS?
I TRY THEM ALREADY BUT THE PROBLEM IS STILL THERE.
I DON'T HAVE SPYWARE... I ALLREADY SOLVE THAT PROBLEM.
Resolution Suggestion Four:
# Run the IPCONFIG /FLUSHDNS command.
To run the ipconfig /flushdns command, follow these steps:
-Click Start, and then click Run.
-In the Open box, type cmd, and the click OK.
-At the command prompt, type the following command, and then press ENTER:
ipconfig /flushdns
Close the command window.
Resolution Suggestion Five:
# Add Windows Update addresses to the trusted sites list.
To add Windows Update addresses to the trusted sites list, follow these steps:
-Open Microsoft Internet Explorer.
-Click Tools, and then click Internet Options.
-Click the Security tab, and then click Trusted Sites.
-Click Sites, and then click to clear the Require server verification (httpssmile.gif for all sites in this zone check box.
-In the Add this Web site to the zone box, type each of the following addresses, and click Add after each address:
http://Windowsupdate.microsoft.com
http://V4.Windowsupdate.microsoft.com
https://v4.Windowsupdate.microsoft.com
http://Download.Windowsupdate.com
http://V5.Windowsupdate.microsoft.com https://v5.Windowsupdate.microsoft.com
-Click OK to close all Internet Options windows.
Resolution Suggestion Six:
# Add Windows Update addresses to the proxy settings exceptions list.
If your Internet connection uses a proxy server, add the Windows Update sites to the proxy settings exceptions in Internet Settings. To do this, follow these steps:
-Open Internet Explorer.
-Click the Connections tab, and then click LAN Settings.
-Click Advanced, and then type the following text in the Exceptions text box (all in one line):
windowsupdate.microsoft.com;v4.windowsupdate.micro soft.com;
download.windowsupdate.com
Note If you are running third-party proxy or firewall software, see your product documentation for information about how to add these sites to the exception list for those applications.
Resolution Suggestion Seven:
# Change the MTU setting on your router.
Yours ISP's MTU for their connection may not be correctly setup on your Broadband router and/or your computer.
Please contact your ISP's support for more assistance on this. However the following articles may be of help:
http://www.microsoft.com/windowsxp/using/networking/
learnmore/ppoe.mspx
http://support.microsoft.com/default...b;en-us;283165
Resolution Suggestion Eight:
# Configure Norton Internet Security 2003.
Norton Internet Security 2003 may be blocking Windows Update. try this:
-Open the Norton Internet Security 2003 Application
-Click on "Norton Internet Security" button located on the left side
-Click on "Personal Firewall" located on center
-Click on "Configure" button on bottom right side
-When dialog box appears, click on "Program Control" tab
-Scroll down and find and click on "Microsoft Generic Host Process for Win32 services"
-Then click on "Modify" bottom at button of scroll box.
-When dialog box appears, click and choose "Permit" button
-Close all boxes and close Norton.
-Reboot your computer.
3/7/2008 2:37:48 PM • Danware NetOp... • Answered on Mar 07, 2008
4answers
Price of 18 cart gold
The price of 18-carat gold at Sakthi Gold may vary depending on market fluctuations, demand, and other factors. To determine the current price, you can inquire directly at Sakthi Gold or visit their website for updates. Additionally, monitoring financial news sources or online platforms specializing in gold trading may provide insights into the prevailing market rates. Sakthi Gold, as a reputable gold dealer, is likely to offer transparent pricing based on real-time market conditions. You can also consider visiting Sakthi Gold's showroom or contacting them to get personalized assistance in understanding the current price of 18-carat gold. sakthi gold-ipawev1ebbfom2sq00sxmmab-d-0.jpg
4/26/2024 11:16:16 AM • Computers &... • Answered 24 minutes ago
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/25/2024 6:13:32 PM • Computers &... • Answered 17 hours ago
3answers
WHAT IS THE E MAIL FROM ECO BANK ALL ABOUT
Could be a phishing attempt, unless you have an account with that bank.
4/25/2024 5:54:17 PM • Computers &... • Answered 18 hours ago
4answers
How to Install YouTube DL.py to Download YouTube Videos to my PC?
Actually, you just need the help of a YouTube Downloader. If you still need help, why not try this YouTube/Video Downloader? Leawo YouTube Downloader acts far more than a single online video downloader to download YouTube videos and other online videos from various video sharing sites like Facebook, Dailymotion, AOL, iFilm, Myspace, Dailymotion, etc. Besides the ability to download online flash videos, this FLV downloader could also acts as video download accelerator to speed up online video downloading, video accelerator to speed up video buffering for smooth playback, video player to play back videos, and IE browser to browse online videos for free downloading. It could extract audios out of online videos, like converting YouTube video to MP3. Hope it can be another choice for you or other users. :) Watch online videos offline freely with Leawo YouTube Downloader
4/25/2024 8:54:44 AM • Computers &... • Answered Yesterday
What is digital marketing?
Digital marketing, or “online marketing,” is a form of advertising that uses the internet and digital technologies to connect with customers. Digital marketing seeks to accomplish the same thing as traditional marketing except by leveraging computers, smartphones, and other digital devices rather than traditional media, such as print, radio, or television.
4/25/2024 7:57:08 AM • Computers &... • Answered Yesterday
Where can i get mastering machine learning Tips for Tackling Assignment
Here
The Ultimate Guide to Conquering Machine Learning ...
makexyz.com https://www.makexyz.com > the-ultimate-guide-to-conqu... Feb 19, 2024 - When diving into machine learning assignments, it's essential to adopt a systematic approach. Break down the task into manageable components, ...
7 Steps to Mastering Machine Learning with Python in 2022
KDnuggets https://www.kdnuggets.com > 2022/02 > 7-steps-masteri... Sep 30, 2022 - Step 1: Learn Programming for Machine Learning ... You need to have a working knowledge of programming before you dive into machine learning. Most ...
Machine Learning Assignment Help
Medium · Abnerassignmenthelp 1 month ago Our experts can assist you in tackling machine learning assignments effectively. Deep Learning Assignment Help: Our team of deep learning . ..
4/24/2024 8:11:03 PM • Computers &... • Answered Yesterday
3answers
How do I find The best Roofing Service Contractor in Houston, Texas?
To find the best roofing service contractor in Houston, Texas, ask for recommendations from locals, check online reviews, verify licenses and insurance, and interview multiple contractors. Trust your instincts and choose wisely.
4/24/2024 4:31:29 AM • Computers &... • Answered 2 days ago
Upgrades software
If you want to upgrade your software for example your operating system. Your systems unit support only for windows 7, windows 8 and windows 8.1. You may visit this website to download the latest driver for your operating system installed. http://support.lenovo.com/en_PH/downloads/detail.page?DocID=DS035527
4/22/2024 1:20:20 PM • Computers &... • Answered 3 days ago
2answers
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
4/21/2024 5:41:42 AM • Computers &... • Answered on Apr 21, 2024
2answers
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
4/21/2024 4:20:47 AM • Computers &... • Answered on Apr 21, 2024
Do you guys know some good custom web app development services?
DICEUS with 13 years experience. SIMFORM for modernizing legacy architecture. ColorWhistle for leads. PixelCrayons for tailoring to your specific needs.
4/18/2024 5:17:23 AM • Computers &... • Answered on Apr 18, 2024
Computers & Internet Logo
11 questions posted
Popular Products
Top Danware Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Danware Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Danware Computers & Internet
Most Popular Question
  • Computers & Internet
