20 Most Recent
Compaq Presario Cq-62 15.6 Laptop Lcd Led Screen Questions & Answers
Laptop heats up a lot
Please check your laptop internal fan. If it is working then try to place your laptop on flat surface and check the problem.Please don't place on bed or irregular surface. Laptop need air to cool. Thank you for asking on fixya
When I move the lid of my laptop the screen messes up
it seems the wire that used to connect between display circuit and motherboard connector has got problem. So please check each wire and also reconnect the connector which connect to the motherboard of your laptop.
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
