20 Most Recent
Lanzar (MAXP154D) 15'' 2000 Watt Dual Voice Coil Subwoofer Driver for Small Enclosures Car Speaker Questions & Answers
There are 4 connectors on each side of the
Problem with the Lanzar 15'' 2000 Watt Dual Voice Coil Subwoofer Driver for Small Enclosures Car Speaker.
how do i wire it so i can put the sub in the box so i can connect it to my amp?
7/28/2014 6:28:34 AM •
Lanzar...
Answered
on Jul 28, 2014
How do wire my 15'' to 1ohm
If each voice coil is rated at 2-ohm, then wire it in "parallel". This will make a 1-ohm total load.
amp pos. out to coil 1 pos. to coil 2 pos.
amp neg. out to coil 1 neg. to coil 2 neg.
If the they are dual 4-ohm, the rating would be 2-ohm in parallel.
7/28/2014 6:21:35 AM •
Lanzar...
Answered
on Jul 28, 2014
Will it get so loud my car falls apart eventually
The car falling apart is a NO. But if you want a lot of Boomy Bass, then make sure to make a ported box for your sub woofer and give it the power it needs. If i knew the exact model i would tell you the size of box and amount of power you would need to amplify it.
dreamsystems
2/10/2011 8:27:12 AM •
Lanzar...
Answered
on Feb 10, 2011
How do you bridge a
use a decent wire (same gauge as you would use to connect it to your amp) and connect it between the "+" pole of one coil and the "-" pole of the other coil. use the 2 other poles to connect the speaker to the amp. Have a nice day!
12/14/2010 6:37:18 PM •
Lanzar...
Answered
on Dec 14, 2010
How do you wire up a dual voice coil lanzar 15 for
Hello dexterchapma,
The only way to wire a single 4ohm DVC sub to present a 4ohm load is to just connect one voice coil. If you wire the coils in parallel, you get a 2ohm load. If you wire them in series, you get an 8ohm load. But it will work great with just one voice coil. Or if you really want to use both voice coils, and your amp isn't stable at 2ohms, wire the voice coils in series and present an 8ohm load to the amp. It'll work fine, it just won't deliver quite as much power.
Hope this helps.
6/28/2009 6:16:54 AM •
Lanzar...
Answered
on Jun 28, 2009
Wiring a sub with duel voice coil
In short yes. And is very common even has its own term called bridged. Taking two channels and making them one. I would hope that you are running a cap. that's going to put out a lot of power and stress on your battery
2/10/2009 1:35:13 AM •
Lanzar...
Answered
on Feb 10, 2009
