20 Most Recent
Wacom Intuos3 6X8 USB with Pen&Mouse [ PTZ630 ] (127137) Questions & Answers
Cursor is shaky in up down motion
Is this an optical mouse? Does it have a laser on the bottom of it
instead of a ball? Sometimes hairs or dirt particles can get stuck on
the lens and cause behavior like you are describing. If so, try
turning the mouse over and if you have some compressed air you can use
it to try to clean the lens. If you don't have compressed air, try
blowing on the lens or gently wiping it with a cloth. and for more info contact http://tinyurl.com/m7ghqz
Skipping and Shaking cursor
There is a problem with the compatability of your tablet and your monitor. You either have to change your monitor to a different refresh rate or simply move your tablet abit further way from your monitor. If possible, you could change your tablet to "single mode" (depending on your tablet).
Skipping cursor
I once had that problem on a Toshiba and it turned out to be related to the battery. Try removing it and using the cord and see if that helps.
Wacom pen
Sorry, but I haven't found a solution. Please let me know if you do.
My Wacom Intuos Pen & Touch has stopped working
Using Windows? Open up the Device Manager by right-clicking "This PC/My Computer" and select "Manage". On the left pane, click "Device Manager". Depending of the version of Windows you're running, the tablet could be listed under "Portable Devices" or "Mice and other pointing devices".Once you see it, move that window off to the side so you can still see the entry for your tablet. Now use the tablet as normal until it stops working. If it disappears from the list, you've probably got yourself a wiring/hardware problem. (My tablet's cable eventually developed a bad USB cable from years of moving around/use).Since the tablet itself still recognizes you after it stops responding on the screen, wondering if you may have updated the software/drivers lately (even by accident by clicking an "OK" dialog by rote...) - try "rolling back" the driver to an earlier version. If this is really new, any chance you could use Window's Restore function to go back a snapshot or two to when it did work fine? Always back up your important files (say, documents/designs etc) to another drive before doing anything. Good Luck!
