20 Most Recent Hoover F5872-900 SteamVac Wet/Dry Vacuum Questions & Answers
REPLACE HOSE ON HOOVER H3000 FLOORMATE
For our H3000, the "water channel hose" was torn (15+ years later, still worth it to keep the SpinScrub going... however it appears the exact part w/ end pieces is no longer available). So, what's promising is that the old hose can be removed from the 2 end pieces -- found out that the "1.5 inch tubing" from Amazon is a bit too difficult to thread into. Looking for a more suitable size, perhaps 1.25 (OD - outer diameter) because of this. Many thanks, responses above are great -- here's a WEBSITE with fantastic PHOTO DETAILS step-by-step I came across... thanks everyone! https://www.educationdx.com/FLOORMATE-repair-cleaner-parts-2.html
6/28/2022 3:48:28 AM • Hoover F5872-900... • Answered on Jun 28, 2022
Hoover steam vac hose broken so I get no suction.
The entire hose has to be replaced. I beliive they run about 39.99
3/20/2019 3:29:26 PM • Hoover F5872-900... • Answered on Mar 20, 2019
0answers
F5878-900
Be the first to answer 3/13/2014 4:12:11 AM • Hoover F5872-900... • Posted on Mar 13, 2014Be the first to answer
When i put the top
the hoses and nooks and crannies need to be checked if it is plugged up from previous cleaning. Turn the machine upside down, sideways, look in the hoses with a flash light. do not run your machine if water has gotten into the motor. be careful and unplug the unit before you check all this out. hope this helps. There are smaller pipe cleaner brushes that can get up in the hose and pull out the grime that you can buy at your local hardware store.
8/16/2011 7:59:53 PM • Hoover F5872-900... • Answered on Aug 16, 2011
Hi, the cleaner is making
broken belt or dislodged belt on the roller unit. Check and replace belt, it's pretty simple to do but you will have to remove a few screws and a plate to get to the belt/rollers.
5/27/2011 3:56:30 PM • Hoover F5872-900... • Answered on May 27, 2011
I have lost my manual.. How can I obtain a new one?
You can download the complete instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
7/14/2010 4:08:59 PM • Hoover F5872-900... • Answered on Jul 14, 2010
2answers
Does not **** up the water
MAKE SURE THE LID IS SNAPPED AND SEALED! IT WONT **** ITS NOT SEALED . CLEAN OUT WERE THE WATER SUCKS IF DIRTY OR CLOGGED
5/23/2010 5:01:09 PM • Hoover F5872-900... • Answered on May 23, 2010
2answers
My hoover steam vac will not **** up the water on the carper.
the lid on the tank is not on properly or the duct/block that fits in the front of tank is missing..
5/14/2010 4:26:53 PM • Hoover F5872-900... • Answered on May 14, 2010
How do you clean the water intake compartment?
Hoover makes a nozzle cleanout tool just for this purpose cost is under $5. It can be purchased online at Hoover or from your local dealer. I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
4/22/2010 8:58:44 PM • Hoover F5872-900... • Answered on Apr 22, 2010
tip
How To Replace Turbine Gear in Hoover SteamVac's When Brushes Stop Spinning
When the brushes stop spinning on a Hoover SteamVac, it can be caused by several things. In order to diagnosis why your brushes aren't spinning, please view the diagnosis solution I have done on Fixya:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
If you have diagnosed your machine, and found that the internal receptacle is not spinning, then you'll now need to replace your turbine. This tip will explain in detail how you'll need to complete this repair.
Here's what you'll need to complete this repair:
- Hoover SteamVac Replacement Turbine Brush Gear (several different parts for different models)
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see-thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to un-clip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before you tighten the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
Chris J.
GoVacuum
My steam vac leaks cleaning solution from the
Where the water tanks fits into the body there is a valve that is suppose to keep the solution in place until the trigger is pulled. That valve has gone bad and will need to be replaced. To replace it, take the tank off, pop off the body handle housing with a flat screw driver, then take the two tubes that are gray color that are hooked to the valve, then slide the valve out and replace it with a new one and put everything back together and you should be good to go.
12/3/2009 4:47:11 PM • Hoover F5872-900... • Answered on Dec 03, 2009
Cleaning solution container release valve
The plunger valve on the clean solution tank can be replaced. there are a few parts to it, parts should be about $5 USD I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
10/28/2009 9:46:32 PM • Hoover F5872-900... • Answered on Oct 28, 2009
I can't find replacement tool caddy with tools for
retrieveimage.aspx?code=sm&model=36433167 http://www.hoover.com/parts/?category=carpetcleanertools The tools are available at this same site. Tool Caddy Keeps your Steam Vac tools organized. Model #: 36433167
Price:
$13.03
Quantity:
View Larger
retrieveimage.aspx?imageid=7991 retrieveimage.aspx?imageid=7993
9/16/2009 11:41:48 AM • Hoover F5872-900... • Answered on Sep 16, 2009
Hose to the machine split just above the connection
Not a fixable problem. You have to purchase a new hose assembly.
9/16/2009 11:35:19 AM • Hoover F5872-900... • Answered on Sep 16, 2009
Rotating brushes don't rotate
Check belt, may be broken or may have come off the brush bar and replace.
9/6/2009 9:46:38 PM • Hoover F5872-900... • Answered on Sep 06, 2009
Can you e-mail directions
go to Hoover.com, with the model number, you can download the manual right off the site
9/3/2009 7:58:40 PM • Hoover F5872-900... • Answered on Sep 03, 2009
Hoover F5872-900 SteamVac Wet/Dry Vacuum Logo
34 questions posted
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Hoover Vacuums
  • Hoover Vacuums
Most Popular Question
lost manual obtain new one
  • Vacuums
