20 Most Recent Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Questions & Answers
3answers
Lost operating instructions - need basic
If you go to www.Hoover.com, , on the lower left you will find a link to download manuals. Put in your model as instructed.
10/9/2023 12:30:04 AM • Hoover SteamVac... • Answered on Oct 09, 2023
Tank Cap is stuck
I had the same problem. I was able to use two butter knifes (using dull edges) to 1. pry up cap slightly and 2. pull gasket over lip of cap
I then worked the gasket off by lifting the cap right behind where I was removing the gasket.
Once the gasket was off, I was able to remove the cap easily.
I then put the gasket back on, undamaged, and could use like normal.
The difference between the lock and unlock position is only around 20-30 degrees.
11/5/2020 5:30:24 PM • Hoover SteamVac... • Answered on Nov 05, 2020
3answers
Hoover spin scrub 50 leaking from bottom
Uh, may I encourage everyone to check the trigger under the handle...we went through taking the whole thing apart and it was just that the trigger was stuck in the open position, which poured the water out continually!
1/2/2020 3:20:08 AM • Hoover SteamVac... • Answered on Jan 02, 2020
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
5/26/2019 8:20:58 PM • Hoover SteamVac... • Answered on May 26, 2019
How do you check a fuse on Hoover FH 51200 and replace the switch
There is no internal fuse, trouble shooting guide is referring to your home's power..There are no electrical parts available. You will have to return to service center. Page 25 https://tti.a.bigcontent.io/v1/static/FH51200_Hoover_User_Manual
1/4/2019 7:26:37 PM • Hoover SteamVac... • Answered on Jan 04, 2019
Hoover Runabout steamVac -No return in Recovery Tank
There is a duct in the front of the water recovery tank that you remove to install the upholstery hose. If this duct is missing or not installed properly you will have no suction
11/13/2017 12:05:41 AM • Hoover SteamVac... • Answered on Nov 13, 2017
Hoover spinscrub
It may be soap residue not rinsed from the carpets. You may also have something in the brushes causing the lines.
9/22/2017 9:22:13 PM • Hoover SteamVac... • Answered on Sep 22, 2017
I have a hoover f5861-900 steam vac. the trigger
The plastic clips in the handle that hold the trigger may be broken. Take the handle apart and inspect this area closely
9/19/2017 2:04:00 AM • Hoover SteamVac... • Answered on Sep 19, 2017
3answers
Replace suction hose on Hoover steamvac agility cleaner Model F6215-900 The replacement hose is no longer available online or from Hoover. The water in carpet is not suctioned up due to broken hose.
Sears has it in stock : http://www.sears.com/hoover-90001079-48434083-hoover-air-hose-lower-agility/p-SPM7556800308?prdNo=1&blockNo=1&blockType=G1 Sears com
9/7/2016 1:40:58 AM • Hoover SteamVac... • Answered on Sep 07, 2016
I think the trigger on my upholstery hose is
The most common issue with this is the white nozzle tip broken. sometimes it comes out. it still could be the trigger. take it to a shop and they can tell right away. the trigger is spring loaded, you should feel tension. I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
6/27/2016 4:07:31 PM • Hoover SteamVac... • Answered on Jun 27, 2016
While I was trying to clean my couch, I could not get solution to flow through the hose, but it leaked out all over the carpet under the scrubber instead going through the hose
It sounds like one of the hoses that supplies solution has either ruptured or come disconnected and is running out through the machine. Disassembling it is the only solution to check for that problem.
3/22/2016 4:31:20 PM • Hoover SteamVac... • Answered on Mar 22, 2016
Nothing on hoover
if you haven't use distilled water then your hose is stopped up or a plug somewhere, you will have to have it professionally serviced
12/5/2015 2:35:40 AM • Hoover SteamVac... • Answered on Dec 05, 2015
I have a Hoover H-28267003, I need the spect for the double swicht
That part has been discontinued. You should take it to your local vacuum repair shop to have it diagnosed. If the switch is actually at fault they can most likely help you with an alternate switch. It may not be the switch , so buying one would be a waste of money.
7/6/2015 12:49:21 PM • Hoover SteamVac... • Answered on Jul 06, 2015
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
615 questions posted
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Hoover Vacuums
  • Hoover Vacuums
Most Popular Question
help boyfriend took apart hoover
  • Vacuums
