20 Most Recent Compaq P 1220 22" CRT Monitor Questions & Answers
My P1220 has the problem that when it goes to
NO PC stated, NO OS STATED, must we guess it all? the last running CRT monitor on earth fail 17 years old. how amazing, no:? lost the manual you did, google finds is if you had tried. the OSD menu, works. push mon. menu button turn off the sleep timer RTM always works why not do that. read the manual your MON is so old its before modern VESA spec sleep modes were invented, so it had this silly feature called the sleep timer, with clock yes has a clock too, crazy no? https://www.manualslib.com/products/Compaq-P1220-187767.html page 6pdf. tells me it does have vesa mode, sleep off the sync pins on the same page this old relic,has DDC modes but only work on moden PC< DDC uses a pin that was never used before on the VGA jack. that same page also states, DDC2Bi (plug and play) only works on MONItgor jack B.. so note tell me your PC or its video card model if used. or whaT this is (windows95.)>?' we cant help much can we. but you can test your monitor on another PC. if that fails, the monitor is bad but you must try both MON, rear VGA ports. if the PC was dead, i sure can be. youd have tried another barrowed monitor to prove that. easy.
10/17/2017 12:58:20 PM • Compaq P 1220... • Answered on Oct 17, 2017
0answers
My compaq monitor just start
hi,
Your monitor have problem with vertical deflection section. Can caused by the faulty vertical driver IC and faulty electrolytic capacitor it the vertical section or dry soldering in the pins of the vertical driver IC. When vertical section fails horizontal lines come on the screen. For testing the same you have to open the monitor and remove the main board. you can easily find out the vertical ic. just follow the four wire running from the deflection yoke ( coil on the crt neck) of which two will go to the horizontal section (normally red and blue wire) and two will go to the vertical section ( Normally yellow and green wire). Follow the yellow and green wire which will be connected to one of the socket in the main board. Follow the circuit track in the main board which will lead you to the vertical deflection section. There you can see one ic is fitted on a aluminium heat sink.Take a close watch in soldering of its leads. Dry soldiering can happen in its leads because its a component which will got to a temperature about 75 degree above at its normal working condition. if found any dry-soldering or not just resolder all the pins of that ic. then check the monitor. If problem remains then you have to relapse the ic.While replacing the ic try to relapse all the capacitors in that section. It will prevent from any further damage to the new vertical ic. if you need any more assistance feel free to contact me through fixya
6/9/2011 10:48:21 AM • Compaq P 1220... • Answered on Jun 09, 2011
Compaq p1220 crt monitor...no power dear, when
Did you try any other device on the same plug?
2/28/2011 8:19:25 PM • Compaq P 1220... • Answered on Feb 28, 2011
It does'nt power up..no light.....sometimes it
may be a dry solder in the power points...
2/28/2011 8:11:17 PM • Compaq P 1220... • Answered on Feb 28, 2011
Compaq P 1220. how to enter service mode (menu)
You don't need to enter the service mode, simply turn off sRGB (from one of the other menus) and you'll be able to change the color temperature.
9/20/2010 6:46:52 AM • Compaq P 1220... • Answered on Sep 20, 2010
Monitor moving on its own
On your physical monitor adjust the verticle and horizontal lengths to take up the full length of the screen. The CRT guns have to draw the exact location of your screen, so extending them to the edges will be easier on the guns. You can also try raising the refresh rate, although that probably wont fix it but it will help on your eyes. and if You have other options like convergence, focus, etc. Try messing with those.
2/9/2010 8:03:39 PM • Compaq P 1220... • Answered on Feb 09, 2010
3answers
When I hook up my moniter it does not work like other moniters.
ok sounds like you have a broken pin on your cable if you look in the end of the cable plug the part thet goes into the box but also check both ends if they are there
failing that take monitor to roof and heave ho away it goes
7/25/2009 6:05:42 AM • Compaq P 1220... • Answered on Jul 25, 2009
Compaq P1220
If that monitor is out of warranty, it's pretty much a throw away item. If you can find a "donor" monitor with a cracked CRT or case, you could probably swap the high voltage units and get it going again.
10/4/2007 12:09:09 PM • Compaq P 1220... • Answered on Oct 04, 2007
Compaq presario desktop SR1000 wiring diagram
You can download upgrading and servicing guide from COMPAQ PRESARIO SR1000 - DESKTOP PC MANUAL Pdf Download ' ManualsLib
4/24/2024 9:52:47 AM • Compaq Computers... • Answered 2 days ago
2answers
Compaq evo n115 boot from usb
Is is probably too old to take Win 10. Also, USB support normally starts once Windows is loaded. During Boot up, it looking for a hard drive or Bootable CD Media. By default, the notebook can start only from a bootable hard drive or bootable drive medium in the notebook. https://www.google.com/search?q=Compaq+evo+n115+boot+from+usb It is 21 years old!!
QuickSpecs
NTS Computers Technology BV https://www.nts.nl > pdf > Compaq_EVO_N115 Compaq Evo Notebook N115. DA-11059. World Wide - Version 7 - August 12, 2002. 1. Overview. What's New. • AMD Athlon™ 4 and Duron™ processors with PowerNow ... 15 pages..
4/20/2024 2:28:56 PM • Compaq Computers... • Answered on Apr 20, 2024
Where can I find the latest BIOS and drivers for a Compaq Evo N610c laptop
It is 22 years old and there is not support for the virus magnet that is called Windows XP!
COMPAQ N610C QUICKSPECS Pdf Download ' ManualsLib
ManualsLib https://www.manualslib.com > manual > Compaq-N610c View and Download Compaq N610c quickspecs online. Compaq OWNERS MANUAL Notebook N610c. N610c laptop pdf manual download. Also for: Evo n610c. Drivers https://www.google.com/search?q=compaq+evo+n610c+laptop+drivers+download 'Latest' BIOS Upgrade is 2004 (2 year support) https://www.google.com/search?q=compaq+evo+n610c+laptop+bios+upgrade+download https://www.google.com/search?q=compaq+evo+n610c+laptop+bios+upgrade ..
4/18/2024 2:40:38 PM • Compaq Computers... • Answered on Apr 18, 2024
2answers
My compaq 610 windows logo is stuck during booting and even if I want to format it. Any help?
Windows 7 should be the OS. If you go to safe mode, it should complete booting and then you can list the errors but I suspect there is a driver error. Maybe the wrong version in there.
4/17/2024 1:03:41 AM • Compaq Computers... • Answered on Apr 17, 2024
I was just donated a Compaq c769 us I wanted to know in it's day was it a good unit ad is it relable 2008 model. It's in pristine condition from what I see ordered power chord on line will check soft ware and functionality ounce it becomes available.
Hopefully it will still work with a new battery and power supply to charge it. They were quite reasonable back in 2008. Win7 software (no longer supported) and fairly fast.
4/16/2024 8:19:02 PM • Compaq Computers... • Answered on Apr 16, 2024
4answers
How to download whatsapp on laptop
As WhatsApp was originally designed for phones the process adn solution are not as straight forward as you might think, See the sites listed below: Download WhatsApp For Laptop PC Windows 8 1 8 7 Install Whatsapp http://fasttechbuzz.com/download-whatsapp-windows-8-1-7-pc-laptop-free/ download-whatsapp-for-windows-laptop-160x120.jpg If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
1/28/2024 5:02:48 AM • Compaq Computers... • Answered on Jan 28, 2024
Hp compac nx6110 drivelock HDD BAY password, reset
Hey readersFollow these steps to troubleshoot that issue. Warning -Please don't your that tip for illegal work . Its only for personal and training purpose. You can also follow my tip
12/16/2023 6:38:16 AM • Compaq Computers... • Answered on Dec 16, 2023
How do i verify my number on badoo
9/13/2023 6:38:32 AM • Compaq Computers... • Answered on Sep 13, 2023
10answers
Best antivirus for window-7 ultimate 64-bit
am sure it is eset nod http://www.eset.com/download
6/12/2023 9:49:33 AM • Compaq Computers... • Answered on Jun 12, 2023
2answers
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
11/22/2022 4:45:51 PM • Compaq Computers... • Answered on Nov 22, 2022
Compaq P 1220 22" CRT Monitor Logo
13 questions posted
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Computers & Internet
Most Popular Question
when hook up moniter not work like other
  • Computers & Internet
