20 Most Recent Roland DR-30 Microphone Questions & Answers
Roland DR-30 Mic - how do you use it?
If the mic is a dynamic microphone, you would need a small mixer. The line input is a high level input and the mic level needs to be boosed. We here at Pro Line Music have small mixers 215-736-8055
1/5/2010 10:41:30 PM • Roland DR-30... • Answered on Jan 05, 2010
I have a Roland BK5 no sound in speakers or headphones it has new ribbon cables everything working fine except the sound
Make sure the speaker setting is set to "Normal" or "ON." If the speaker setting is set to "OFF," try setting it to "Normal" or "ON". The following may be available on your instrument. - Normal: The speaker will sound only if headphones are not connected.
11/1/2023 6:13:49 AM • Roland Audio... • Answered on Nov 01, 2023
No sound from Roland E80 speakers
well it needs service, using the service manual ,tools and skills' so get it service by a shop. not told at all how the kbd is connected and to what. just he word speakers told? use the left rear, speaker line out L/R fails> (if yes bad external amp speakers or if using the internal speakers those are actually bad both? then the speakers inside are bad or the amp that drives the 2 are bad inside, we test those to find this out. inside speaks use inside speakers amps the to jack 1/4 inch inch are not amps, those are line out jacks. 100mV signals that only an external amp can juse, directly my guess, is the internal amp is bad. it needs service, by an electronic tech, as that is what it is. or blown fuse inside or things directly related to just the amp inside.
7/4/2022 6:49:57 AM • Roland Audio... • Answered on Jul 04, 2022
My Roland BK3 has no sound; i can hear the faint power sound through the speakers;the display is perfactly working but no sound coming out
Have you tried a different output cable? I know, it seems simple, but it's often the problem. If you have and the problem remains, I suggest calling the manufacturer to see if there is a known problem. Many manufacturers have a website & service number for resolving problems with their products.
10/7/2021 3:17:01 AM • Roland Audio... • Answered on Oct 07, 2021
I need help installing a Roland VT-4 to my computer as well as a Rode NT1 microphone connecting to that. The Rode microphone will need to get power through the Roland VT-4.
Hello Christian, to establish a connection order, we will go from the microphone to Roland and Roland to the computer first, you connect the Rode microphone to the Roland, through a cable with Cannon type connectors (XLR), the female connector to the Rode and the male connector to the Roland Mic input of the rear panel, you have to enable the Phanton key, in the front of Roland Then you have to connect a USB to USB cable, from the USB connector on the back panel of the Roland to a USB port on your computer This would be the connection sequence, then to use it, turn on the Roland first and then the computer and when you finish using it, first the computer and then the Roland I send you the link to download the user manual, there you will find more options for operation I hope you find it easy to arm and interconnect your Rode with your Roland and your computer Greetings Franco Dosil Hola Christian, para establecer un orden de conexi?n, iremos del micr?fono al Roland y del Roland a la computadora primero, conectas el micr?fono Rode al Roland, a trav?s de un cable con conectores tipo Cannon (XLR), el conector Hembra al Rode y el conector Macho al Roland entrada Mic del panel trasero, tienes que habilitar la llave de Phanton, en la parte delantera del Roland Luego tienes que conectar un cable USB a USB, desde el conector USB en el panel trasero del Roland a un puerto USB de tu computadora Esta seria la secuencia de conexi?n, luego para usarlo, prendes primero el Roland y despu?s la computadora y cuando terminas de usarlo, primero la computadora y despu?s el Roland te env?o el link para que descargues el manual de usuario, ah? vas a encontrar mas opciones de funcionamiento Espero que te resulte f?cil el armado e interconexion de tu Rode con tu Roland y tu computadora Saludos Franco Dosil https://www.roland.com/global/support/by_product/vt-4/owners_manuals/21fab44d-24a9-428d-9623-9f58bc8db97a https://www.roland.com/global/support/by_product/vt-4/owners_manuals/7e0e40e5-4765-453e-b7e5-6b6eeb96a876 https://www.roland.com/global/support/by_product/vt-4/owners_manuals/00163e4e-893f-4528-a979-6d523149c23a https://www.roland.com/global/support/by_product/vt-4/owners_manuals/bb691ff4-8efe-4243-9d14-b316fcbb3fa7
5/13/2019 8:29:09 PM • Roland Audio... • Answered on May 13, 2019
Roland VGA-7 Amplifier I am having an issue
That should fix it
2/5/2018 11:06:20 PM • Roland Audio... • Answered on Feb 05, 2018
0answers
Roland DR-30 Microphone Logo
1 questions posted
Top Roland Audio Players & Recorders Experts
 Grubhead
Grubhead
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Roland Audio Players & Recorders
Most Popular Question
roland dr 30 mic use
  • Audio Players & Recorders
