20 Most Recent
Roland Vs2400CD Digital Workstation W/CD Recorder System Questions & Answers
Roland vs2480 wont come on it keep saying SUB SYSTEM CANT FIND OR NOT RESPONSE
This means the low-level part of the operating system is corrupted or missing. Simply try reloading the OS by putting the CD into the CD drive. If it does not allow an OS reload or if it fails, most likely the flash ROM which holds the basic part of the OS has been zapped and will require service. You can also try to replace the internal button battery inside that retains the memory.
Load Screen Freeze w/ Roland VS-2400
The hard drive needs to be replaced. You can contact their customer service as to how to do this. It is relatively pain free and inexpensive as well.
323-890-3741
My roland vs2400CD keeps getting stuck at the load
Hold the two buttons down above the slider on track #4 when turning the power on. You have something that is corrupt on your hard drive. This bypasses looking for a project to load up and just goes straight to the operating system.
When I turn on my
Have you tried to do a factory reset?
Hold SHIFT and press F4 (Utility). Press PAGE to get to page 3. Press F6 (PrmIni). Press F5. Press ENTER/YES
Roland VS 2480 v2 -
Hi, have you tried to do a factory reset?
Hold SHIFT and press F4 (Utility). Press PAGE to get to page 3. Press F6 (PrmIni). Press F5. Press ENTER/YES.
If the factory reset does not fix the problem i think you have to format the disk because it has a fragmented disk .......
Missing power cord.I need to
http://www.roland.com/products/en/VS-2000CD/specs.htmlHere you will find more about this recorder...I mean specifications and other stuff like that ..and if you pay attention it says clear that this unit is powering with a 12 V power adapter ..so ...take care and do not try to connect it in a 110 or 220 V regular power plug ..
It has a plug that has the power symbol ...and in there you have to connect a 12 V regular adapter ..
Lost f/x across all tracks prior to Mastering on Roland 2480cd
Double check that you haven't inadvertently muted or turned down the effect returns. Also make sure they haven't been inserted elsewhere as they wont work as post effects while inserted into a single channel. If you are using some effects, it will cancel the effect card's ability to use its second channel. (ex. mastering suite)
