20 Most Recent
JVC Cybercam GR-DVL120 Mini DV Digital Camcorder Questions & Answers
LCD screen powers up but is bright white
TRY SEARCING THROUGH ALL YOUR MENU MODES. MY CAMERA IS DIFFERENT THAN YOURS BUT MOST CAMERAS IT HAVE AN ADJUSMENT MODE TO BRIGHTEN OR DARKEN YOUR DISPLAY ...
JUST A SUGGESTION NOT A SOLUTION
Image wont flip when the lcd panel is fliped
Justin,
The orientation switch for the LCD module is located on the horizontal shaft which supports the monitor. The switch can be damaged or break off inside the LCD cabinet and cause this symptom. Also, we have seen the harness rubbing against the metal bracket and tear which causes the signal to be lost which directs the microprocessor to invert the image. I hope this helps you.
Joe Weibel
CustomElectronics.Org
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
My GR_SMX730U VHS camcorder is eating the tape.It uses a PRO TC-30 casset.
that means the head is sticky or the takeup rollers are icky
take it apart . clean all the parts the tape touches with something thats strong but little water .
as for the head very carefull clean it when you get to the actual holes where heads are only use a proper qtip wetted . look it up or youll break them.
on the rubber rollers scrub them . then load the tape an watch it run.
its easy to fix this but you need a nice clean place an some small phillips , take pics of parts/screws if needed
