20 Most Recent HP DeskJet 550c InkJet Printer Questions & Answers
Will not print even thought
Like the above poster said. Clean your print head and check your ink if they are installed properly. If everything still fails. You can always try to hard reset your printer.
9/12/2012 3:16:52 AM • HP DeskJet 550c... • Answered on Sep 12, 2012
Hp deskjet 550c trying to
Use my published guide to install the latest drivers for all computers on the network. It is entitled
How to Install the latest drivers for Hewlett Packard Printer!!!
The drivers need to be installed on all computers in the network.
Then once the drivers are installed all you need to do is to navigate to the Windows control panel and double click printers and faxes on the computer that the printer is connected to.
Now right click the your printer and select the option Sharing, this will allow you to share the printer on the network.
Click the lower circle to share the printer.
Then when you print from another computer on the network, be sure to select this shared printer as the printer to print to, or set this shared printer as the default printer by right clicking the printer and selecting the option to set as default printer.
Please be sure to rate this session.
Take care!
damnor01
6/1/2011 4:14:35 PM • HP DeskJet 550c... • Answered on Jun 01, 2011
Hi, I have just ordered an
For your printer HP DeskJet 550c there is no Windows 7 driver available, just Win XP and Windows 3.0 http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=au&lang=en&product=60939
As for the router, if it is already set up and working, you won't need to do anything on it as it will work as before. You probably will need to set your HP computer to obtain an automatic IP address from Network Preferences and plug the Ethernet cable in to get the IP from the router. Even if it's not set up, you can set it up and it will work with no problem with the new system.
As for Money 95 that program definitely won't run on Windows 7 64 bit, but you can try following these instructions to make the program work http://www.fixya.com/support/r7392842-windows_compatibility_issue_older
12/29/2010 11:53:49 PM • HP DeskJet 550c... • Answered on Dec 29, 2010
Middle light blinking message says paper
Look for any small rips of paper caught in a sensor back there. There are little "fingers" that the paper runs over and its all timed. if one of those sensors are jammed with something or sticky, error messages.
9/22/2009 6:06:01 AM • HP DeskJet 550c... • Answered on Sep 22, 2009
2answers
How to reset HP ink ADVANTAGE 3515 Printer
Hello. First of all I would like to wish everyone a Happy New Year! I recently bought a HP Deskjet Ink Advantage 3515 printer. The printer works fine (prints, scans and copies). There is only one problem with it. It returns me an error when I'm shutting it off. This happens very often but not always, it is kinda annoying. The error is displayed as: ERROR CODE 0X02B7C2ED SM_MODULE C (the error is also shown on the image). I tried to Google the problem but without effects. I don't know what could be the problem. Can someone help me please, because I have no idea what could be the issue. Thanks for any replays.
2/3/2022 11:51:08 AM • HP DeskJet... • Answered on Feb 03, 2022
2answers
How do I fix an Hp deskjet 4615 not printing black?
If you are using a Windows PC, search for devices and printers. Once you find the printer, right click on it, go into printing preferences and you should find a tab in there that will all you to disable color. If you want to be able to print in both and black will not print, make sure your black ink cartridge is not empty or that it is properly installed.
7/29/2021 7:19:59 AM • HP DeskJet... • Answered on Jul 29, 2021
2answers
I need a printer driver for a HP Desk Jet ink advantage 3835 that works with Apple Mac 10.6...pleease
Go to this website. http://support.hp.com/us-en/product/HP-DeskJet-Ink-Advantage-3830-All-in-One-Printer-series/7172328/model/7172329/drivers/ Click check now and it should download the best driver for you. If not use step 2 and find the driver you need.
6/13/2020 7:10:21 AM • HP DeskJet... • Answered on Jun 13, 2020
COVER OPEN IN HP DESKJET F2430
check it`s sensor
5/15/2019 8:49:34 PM • HP DeskJet... • Answered on May 15, 2019
My printer cutting text from the right side when printing .HP deskjet 2050 J510
Check the paper size settings to match the loaded paper. This would happen (for example) if you have loaded A4 paper but your driver is set to print on letter format. Letter is wider than A4 by 6mm and while the printer is trying to print near to the right side, assuming the paper is wider, part of the ink goes on the paper support. Other reason may be the paper size in the document is set to be larger than the loaded paper format and driver prints only what can be fit on the loaded paper.
4/23/2019 10:06:27 AM • HP DeskJet... • Answered on Apr 23, 2019
I have error 0xc19a0023 in my printer hp deskjet 3520.I replaced new cartridge but it isn't correct.What should I do?
1) Open the printer cover and wait till the carriage moves towards the middle. 2) Force press the printer's Power button to turn it off. Remove the power cord from the back of the printer. 3) Remove the print cartridges and place it on a small sheet with the nozzle plate facing upward. 4) Slightly wet a cotton swab with distilled water. Clean the face and edges of the face cartridges with the swab. 5) Wipe the underside of the print cartridge cradle walls using a swab. Reinsert the print cartridges. 6) Close the printer cover. Connect the power cord at the backside of the printer.
11/28/2018 8:16:26 AM • HP DeskJet... • Answered on Nov 28, 2018
2answers
How do I scan multiple pages to one file using a deskjet 2512 printer/scanner
On the control panel, select scan to computer and choose PDF. If you are using the sheet feeder, it will scan all pages and create one file with them all. OR If you're using a scanner glass, i.e. one page at a time, when the first page finishes scanning, you will get a message asking if you have another - answer YES and follow the instructions (basically that means place next page on scanner glass and hit OK/Continue). Rinse and repeat until you've scanned all pages then answer NO. You should find a PDF file in your HP Scan Folder usually named "scan.pdf" unless you've changed the settings. (If there is/are already scanned files in that folder, they will have consecutive numbers, e.g. "scan001.pdf" "scan002.pdf" etc
10/11/2018 10:24:24 AM • HP DeskJet... • Answered on Oct 11, 2018
I have a HP Deskjet
www.hp.com/support enter printer model and number and run diagnostics with your printer connected to your PC or Laptop.
2/22/2018 3:54:54 PM • HP DeskJet... • Answered on Feb 22, 2018
Im using HP Deskjet 3900
Possible cable problems. Also mine shows offline if the power button on the printer is off
2/3/2018 7:09:10 PM • HP DeskJet... • Answered on Feb 03, 2018
I have installed an HP Deskjet 3520 as default
I have had this happen in windows operating system. It was caused by a corrupt user profile. You can try control panel users accounts. Try modifying the user account type like changing the permissions and windows should re save the user profile . then change it back to what it was. or look at https://neosmart.net/wiki/corrupt-user-profile/
1/31/2018 12:26:42 AM • HP DeskJet... • Answered on Jan 31, 2018
HP DeskJet 550c InkJet Printer Logo
Popular Tags
11 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
will not print even thought
  • Office Equipment & Supplies
