20 Most Recent HP PSC 500 All-In-One Printer Questions & Answers
Prints vertical lines crooked
You should be able to go into the print driver settings and do a print head alignment. That should cure the problem.
1/15/2018 9:10:50 PM • HP PSC 500... • Answered on Jan 15, 2018
Follow this link to HP.com website and download from there http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=58710&lc=en&cc=us&dlc=en&lang=en&cc=us
4/19/2014 7:36:02 PM • HP PSC 500... • Answered on Apr 19, 2014
Every time I try to start my hp psc 500 it prints
The best way is to re-install your printer driver by downloading the latest driver from your printer`s manufacturer`s website. And make sure to un-install all old drivers.
10/1/2013 2:03:09 PM • HP PSC 500... • Answered on Oct 01, 2013
My PSC 500 print does not have ethernet port to connect to router
There are USB printer servers you can buy. The one I am using is a D-Link DP-301U. You can get one off e-Bay for less than $40 including postage.
2/2/2013 3:43:08 AM • HP PSC 500... • Answered on Feb 02, 2013
I cannot access the exsisting print cartridges to replace them on my hp psc 500 printer
HiPlease note that the print cartridges can only be accessed when the printer is on.
  • Turn the printer on.
  • To access the cartridges,open the cartridge access door on the front of the printer and right above the paper output tray.
  • The cartridge carriage moves to the center so you can access it.
  • On the top of each cartridge is a latch,lift it.
  • You need to grasp the handle at the top of the cartridge pull forward and lift it up to remove.
Hope it helps.
2/23/2012 10:18:53 AM • HP PSC 500... • Answered on Feb 23, 2012
0answers
Is HP PSC 500 Printer compatible with Dell Inspiron 9300 Laptop ?
that printer uses what is known as a serial cable. The software uses 2 way communication through this and if you try and use a USB to serial it will not be able to communicate back. you may want to try this website for more information
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu01068&lc=en&dlc=en&cc=uk&lang=en&rule=30286&product=58710
11/10/2011 8:00:29 PM • HP PSC 500... • Answered on Nov 10, 2011
[email protected] old cable will not
Hi jonselmore,
I would like to clarify if you're using this type of cable?
This is the USB Printer Cable for HP PSC 500. You can obtain it by visiting this link.
Hope it helps.
Thank you for using FixYa.
9/15/2011 12:57:34 PM • HP PSC 500... • Answered on Sep 15, 2011
Hallo, I have two questions: 1. Exactly
1. You need a parallel cable.
2. The power adapter is 18V 2.23A
5/7/2011 10:30:15 AM • HP PSC 500... • Answered on May 07, 2011
Al conectar la maquina por puerto usb con sistema
Saludos aparentemente el problema esta es que el scanner no tiene drives para el windows 7. Te sugiero que vuelvas a la pagina de HP y trates de bajar con el sistema opertivo d Vista ya que este es el mas cercano al sistema que usas. Trata de sacar el programa en tu computadora , vuelves a instalarlo. Suerte!!!
2/5/2011 4:06:14 PM • HP PSC 500... • Answered on Feb 05, 2011
I have a new dell
You will need the original disc that came with your printer.
If you do not have the disc, simply go to HP's main website (www.HP.com) and click on the 3rd tab, which is "Support & Drivers." Find your product and download the drivers for it. Save them to your desktop and once the download is complete, click on the icon(s) and follow the on screen instructions.
Good luck.
1/21/2011 4:45:42 AM • HP PSC 500... • Answered on Jan 21, 2011
HP PSC 500 makes loud
The carrier shaft is probably dry. Use sewing machine oil or 3 in 1 oil and put a couple drops on either side of the carrier, move is back and forth a couple times then power on. While in there, clean the pick roller with a damp cloth and rub the rollers horizontally
11/25/2010 9:59:08 PM • HP PSC 500... • Answered on Nov 25, 2010
I need a replacement cord for the scanner plug
I would try Ebay.com or your local Goodwill computer store, if you have one.
8/7/2010 4:48:02 PM • HP PSC 500... • Answered on Aug 07, 2010
Popular Tags
68 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
new dell
  • Office Equipment & Supplies
