20 Most Recent Maytag MES5752BAW Slide In Electric Range Questions & Answers
Maytag convection precision touch control 800 electric oven not cooking evenly
Oven comes on and off intermittentlyor heats very little: If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem. OrWhy does it take the oven so long to bake? When the food is taking way too long to bake, it's probably a weak bakeignitor. Replacing theignitorusually fixes this problem, but you probably want to verify that theignitoris the problem before replacing it.Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it. On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat. OrOven safety valve needs to be checkedwith multi meter ohms / voltage ALSOTest the Burner Heating Element The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings. Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreakerpanelto avoid an electrical shock hazard. When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps. First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring. Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element. Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity. Test theresistanceof the heating element using amulti meter. Set the multi meterto the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be. To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced. The reason for my free advice is GOD is good! Why is the oven temperature incorrect? The oven temperature controlis usually controlled by a thermostat that uses a capillary and liquid filled bulb. When the bulb's liquid gets heated up, it expands and puts pressure on a diaphragm which opens and closes a switch that controls the gas to the burner. Just set the dial to what you need the temperature to be. Over time, it is possible for your thermostat to lose its calibration. Sometimes, the thermostat sensing bulb comes loose from the holder. If it is out of place, the thermostat may be getting faulty readings. If this is the problem, re-aligning the bulb properly will take care of this problem.Digital display models use a sensor to control temperature. If this is faulty, replace it. Other ovens use a mechanical system to control the temperature.On many models, you can adjust your oven thermostat using a small screwdriver. The adjusting screw is located on the thermostat valve stem. Remove the knob and you'll see the screw underneath it. You want to turn the oven on and run it through at least two cycles while watching a calibrating thermometer in the oven for high and low temperatures. Adjust the screw as necessary to fine tune the temperature.Some models don't have an adjustable thermostat, and you will have to replace the thermostat if you want to resolve the problem. The oven sensor:works with the oven control board to regulate the oven temperature. If there is an oven temperature problem, this sensor might be defective. The sensor can be tested by using an ohm meter. As temperature rises, the resistance measurement also rises. The manufacturer of the oven sensor determines the correct resistance,Oven temperature problems can be caused by other things,but this is one of the common causes. Beware on some models nowmost of these ovens they are electronic and they are integrated into the control itself some different sensor ohm readings at room temp. approx 16 ohms at room temperature and at 350?F it is 29~33 ohms. Read more: http://www.justanswer.com/appliance/5xrsf-ge-xl44-gas-oven-oven-ignites-even-when-oven.html#ixzz3YdtiPcn8 The reason for my free advice is GOD is good! oven temp probe location temp probe-undefined-undefined-0.jpg oven temp probe sensor probe-undefined-undefined-2.jpg oven temp control thermostat-undefined-undefined-5_0.jpg oven temp probe location temp probe-undefined-undefined-9.jpg
3/17/2020 6:01:43 AM • Maytag... • Answered on Mar 17, 2020
Oven door dirty between glasses
Usually there is a spot right before close that the door wool slip off the hinge. On some models you use a nail to hold it on place some have a special hinge. After that the door comes off and a few access gives you access to the inside panel
10/2/2014 1:23:11 AM • Maytag... • Answered on Oct 02, 2014
Oven will not heat up past 275 and takes over an hour to do so
sounds like your heating elements are going on it. call a repair man.
3/11/2013 11:12:48 PM • Maytag... • Answered on Mar 11, 2013
Maytag MER5552BAW stopped working while cooking last night.
othing Works, or the Oven / Range / Stovetop Works Only At Certain Times: 1. Home breaker flipped or the fuse blown? Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary. 2. Power cord plugged in? Grab the plug and wiggle to determine a good connection. 3. Power cord damage? Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires. 4. A clicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board. 5. 6. Even a bad relay door switch will hinder your oven from operating. If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse ++++ Oven Control Board The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven. Relay board: Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT. fuse location oven fuse_ranger_17-undefined-undefined-0.jpg fuse testing oven fuse-undefined-undefined-2.jpg fuse module with words-undefined-undefined-5.jpg oven relay board dacor-relay-board-92028-ap3851203_01_l-undefined-undefined-9.jpg
3/17/2020 5:29:34 AM • Maytag Cooktops • Answered on Mar 17, 2020
Maytag glass cooktop timer button broke through and now it doesn't work. Help please.
Use this link for answers to all your cooktop issues.
3/15/2019 1:17:10 PM • Maytag Cooktops • Answered on Mar 15, 2019
Maytag MER5552BAW stopped working while cooking last night. Was using the cooktop and the oven and all seemed to turn off at once. May have had water spill into on of the burners.
Go to your electrical panel and check the circuit breakers. If one is tripped it will be in a halfway position. switch off then on. If it keeps tripping you may have to call a repair man.
2/10/2019 5:43:22 PM • Maytag Cooktops • Answered on Feb 10, 2019
New Maytag MGC7430 gas cooktop leaks gas when lit
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
6/19/2017 1:56:49 PM • Maytag Cooktops • Answered on Jun 19, 2017
My Maytag glasstop burner popped loudly and I smelled burned wires. Water overflowed from a pan on the cooktop. Can it be repaired?
Sure. The wiring harness can be repaired or replaced as well as any damaged components.
8/29/2016 3:17:35 PM • Maytag Cooktops • Answered on Aug 29, 2016
0answers
I was wiping out my oven. It sparked. Now nothing
Tammy have you checked the circuit breaker at the electrical panel of your home. Do the panel lights come on? If they do and the rest is off then it will need service.
10/13/2013 9:37:21 AM • Maytag Cooktops • Answered on Oct 13, 2013
Oven panel displays F1
call or e-mail the company or the manufactor they can help.
3/11/2013 10:56:55 PM • Maytag Cooktops • Answered on Mar 11, 2013
Maytag no oven display and no oven control
You will need to replace the display assembly, the oven control board is part of it and it is burned out.
5/22/2012 11:19:35 PM • Maytag Cooktops • Answered on May 22, 2012
2answers
I have a Maytag performa Kitchen stove and all 4
is it gas?
if it is gas i would strongly suspect the spark module
12/20/2011 1:02:47 AM • Maytag Cooktops • Answered on Dec 20, 2011
I have a maytag gas stove model #MGR5775QDQ serial
You have a bad ignitor to your oven. Part number you should replace is 12400035. This should fix this problem. Just because it glows does not mean it work correctly, it works off of the flow of electricity rather then the glow of the ignitor.
Ignitor How to test How to change ignitor
Good Luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
8/29/2011 10:24:55 PM • Maytag Cooktops • Answered on Aug 29, 2011
2answers
The electronic lighter will not quit clicking.
Hello, Thank You for using FixYa. I will be helping you today. Did you clean the cook top or spill something? If the switches get wet they will click untill it drys out. If not then one of the switches failed and would need to be replaced. Its the switch that sits on the burner valve.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
7/19/2011 10:39:40 PM • Maytag Cooktops • Answered on Jul 19, 2011
Maytag MES5752BAW Slide In Electric Range Logo
Popular Tags
3 questions posted
Top Maytag Cooktops Experts
Paul Carew
Stan Ford
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Maytag Cooktops
  • Maytag Cooktops
Most Popular Question
maytag convection precision touch
  • Cooktops
