20 Most Recent Hotpoint HTWP1000MWW 3.3 cu ft Top Load Washer Questions & Answers
It says demo on it
You can ususally take your Hotpoint washing machine out of DEMO MODE by holding down both the ON/OFF button and the START/RESET button at the same time for about 3 seconds.The display should then indicate D OFF.If this procedure does not work for your particular machine, then please just comment back and be sure to include the exact model number of your washer next time so we can provide the appropriate procedure for your appliance. Good luck.
2/14/2024 5:16:13 PM • Hotpoint Washing... • Answered on Feb 14, 2024
Hotpoint dishwasher FDYF 11011p Fault F01
Certainly! Here's a concise response for the forum discussion: To clear the Hotpoint dishwasher FDYF 11011p Fault F01, you can follow these steps:
  1. Power Reset:
    • Turn off the dishwasher and unplug it.
    • Wait for about 10 minutes.
    • Plug it back in and restart.
  2. Check Door Lock:
    • Ensure the door is securely closed.
    • Check for any obstructions in the door lock mechanism.
  3. Inspect Wiring:
    • Examine the wiring for any visible damage.
    • If you're comfortable, check the connections and reseat them securely.
  4. Temperature Sensor:
    • Fault F01 may be related to the temperature sensor. Verify its condition and connections.
If the issue persists, it's advisable to consult the Hotpoint dishwasher manual or contact customer support for further assistance. Hope this helps!
12/4/2023 5:26:16 PM • Hotpoint Washing... • Answered on Dec 04, 2023
Hotpoint washing machine going into pause mode
The first thing to always try is disconnecting it from the mains plug overnight. Then in the morning press and hold the power button for 60 seconds. Then plug it back in. The is a Power Reset on a machine that has an electronic mainboard. Does water enter the machine? My guess is that the water inlet valve may have failed. It waits, no water comes, so it times out. There are a few things to check there, make sure there is water in the pipe, make sure the strainer screens are clear in the hose connecter on the back of the machine. No model details given but there is help in the link. https://www.google.com/search?q=Hotpoint+washing+machine+going+into+pause+mode
11/10/2023 1:53:50 AM • Hotpoint Washing... • Answered on Nov 10, 2023
Hotpoint WML730 washing machine - Can I replace original motor with a different numbered motor?
Doing things like that seldom works, but if is is cheap, try it. Your motor is here including new from Whirlpool. Welling electronic control motor HXGM1L.52 https://www.google.com/search?q=Welling+electronic+control+motor+HXGM1L.52 ..
8/11/2023 11:12:09 PM • Hotpoint Washing... • Answered on Aug 11, 2023
Hotpoint WML730 washing machine keeps tripping the main fuse box? Revised FOUND MY OWN SOLUTION
The washer tripped the breaker once and OR after the breaker was reset it ran additional loads with no problem then it tripped the breaker again. Intermittent problems are always difficult to diagnose because the problem usually doesn't occur when you're making the checks. If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run additional loads. if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle. If you have access to a clamp on amp meter, see the image below, then you can check the amp draw of the washer. The washer normally will draw about 10-15 amps at start up and about 5-8 amps while running. The house breaker for you washer should be rated at 20 amps. If the washer is running and drawing less than 20 amps and the breaker trips then if can be a weak house breaker. Mid cycle the washer is most likely draining or spinning and if the bearing or pump locks up then the washer may draw additional amps to try to start and trip the breaker. The key to this problem is what the amp draw of the washer is when the house breaker trips. To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty. If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet. If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets. Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and  HYPERLINK "http://www.youtube.com/watch?v=MFsvLiuTniU" replacing the lid switch is probably a worthwhile idea, as it is cheap and easy to replace. By the way my advice is free cuz God is good! door switch jumper-undefined-undefined-0_3.jpg outlet test -undefined-undefined-1.gif test4badmotorwindings4-undefined-undefined-2.jpg doorswitch bypass-lid-switch-unplug-undefined-undefined-3_3.jpg
8/4/2023 5:00:00 PM • Hotpoint Washing... • Answered on Aug 04, 2023
Model # HTW240ASK5WS HOTPOINT WASHER AGITATOR NOT WORKING CORRECTLY
Cogs possibly bad.. Check this article..... https://www.fuseami.com/how-to-fix-hotpoint-washer-that-wont-agitate/ Parts link and 877 Tech help #. https://www.appliancepartspros.com/search.aspx?model=htw240ask5ws&page=3 Another Parts house and 800# Tech Help. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/47-95-2297136-/New/Hotpoint-Washer-Won-T-Spin-Or-Agitate-HTW240ASK5WS I would give the above guys @ repairclinic call before throwing parts at it. Their very helpful..either one of them. . Repair clinic or appliancepartspro. I'm not accociated with either of them. I've just used them for repairing appliances in some rental units and my house and they've always been helpful. Best to you
7/14/2023 12:06:11 PM • Hotpoint Washing... • Answered on Jul 14, 2023
Hello I've got a Hotpoint WML520 washing machine. I've changed the door electrical switch a few times due to it keep melting. Does anyone any ideas why it keeps happening? Thanks.
They melt due to high resistance across the solenoid and contacts. My only thought it that they were not genuine OEM replacements and were copies on eBay or Amazon and sourced in China. also follow the wires back to the control board and clean the contacts there. https://www.google.com/search?q=hotpoint+wml520+door+switch I can only find one other incidence of a door lock melting and it is here on Fixya. https://www.fixya.com/support/t29905283-ve_got_hotpoint_washing_machine_model https://www.google.com/search?q=hotpoint+wml520+door+switch+melting+problem ....
7/14/2023 12:27:25 AM • Hotpoint Washing... • Answered on Jul 14, 2023
2answers
Hotpoint WMF 740 timer stuck on 1 minute but washing takes hours to finish
Typical Landlord comment. It is a totally electronic machine. They a power reset. Pull the mains plug when you go to bed, press and hold the power button as you plug it back it back in. Here is the manual if you need it. https://www.manualslib.com/manual/71052/Hotpoint-Wmf740-G-A-K.html ..
3/12/2023 9:26:51 PM • Hotpoint Washing... • Answered on Mar 12, 2023
2answers
WHERE IS CONDENSER FILTER ON Aquarius Hotpoint wdal 8640
in front of door
2/20/2023 8:25:26 PM • Hotpoint Washing... • Answered on Feb 20, 2023
I am currently having issues with my Hotpoint WDAL 8460 Aquarius washer dryer whereby it is leaving a lot of clothing fibres/dust all over our clothes after the wash cycle and the drying cycle. Have o
I have a wdal8640, after a while the condenser pipe gets all fluffed up. Remove the lid, the cross bar and unscrew the metal heating unit. You're looking for the plastic tube that bends down the back of the machine. There's a ring holding it on at the bottom, once you've undone that and worked it over the prongs on the filter it should lift straight out. Give it a good rinse and remove any stuck lint (mine was a solid block that I had to break up before I could get it out), clear the filter whilst your in there and stick it all back together. Don't forget to reattach the water pipe to the top corner!!!
2/20/2023 8:20:07 PM • Hotpoint Washing... • Answered on Feb 20, 2023
I have a Hotpoint WML730 washing machine. Put it on - the cycle began. I think at the spin point there was bang - the machine had jumped 10 inches. Turned off and on - nothing happened...
Based on the description, it seems that the control PCB module is a possible cause of the issue with your washing machine. Checking for any signs of burnout on the PCB would be a good next step. However, keep in mind that handling electronics can be dangerous and if you're not comfortable or familiar with the process, it's better to seek the help of a professional.
2/14/2023 2:45:20 PM • Hotpoint Washing... • Answered on Feb 14, 2023
Hotpoint FDL 9640P U.K. Washer Dryer problem. Start/Pause button flashes every 3-4 secs.
That sounds like you are on Pause or Delayed Start. Try Pressing and holding the button. You can also try disconnecting from the mains for 5 minutes. When in doubt, read the manual :>D START/PAUSE button with indicator light: starts or temporarily interrupts the wash cycles. N.B. To pause the wash cycle in progress, press this button; the corresponding indicator light will flash orange, while the indicator light for the current wash cycle phase will remain lit in a fixed manner. If the DOOR LOCKED indicator light is switched off, the door may be opened. To start the wash cycle from the point at which it was interrupted, press this button again. and also ! If the START/PAUSE indicator light (orange) flashes rapidly at the same time as the function indicator light, this indicates a problem has occurred (see "Troubleshooting"). https://manualzz.com/doc/50330217/hotpoint-fdl-9640p-uk-instruction-for-use ..
2/11/2023 11:51:55 PM • Hotpoint Washing... • Answered on Feb 11, 2023
How do I reset fault code F6 on a Hotpoint NSWM943CWUKN washing machine
Yes it is a door lock issue. Check all the connections again and follow the wire back to the control board. https://www.google.com/search?q=fault+code+F6+on+a+Hotpoint+NSWM943CWUKN What does F6 mean on Hotpoint washing machine? F06 - Door lock fault. Issue: Washing Machines door cannot be opened or closed / when the door is closed the machine the programme will not start. Advice: If your washing machines door will not close, please check for any obstructions in the door lock.
Washing Machine Error Codes - Hotpoint Service
2/10/2023 7:46:57 PM • Hotpoint Washing... • Answered on Feb 10, 2023
Hotpoint wf540 rinse hold and on/off light flashing
if the machine is old the front panel need to be service.Probably the front panel is experiencing partial contact with he control buttons.
1/19/2023 10:47:45 AM • Hotpoint Washing... • Answered on Jan 19, 2023
Hotpoint FDEU 9640 washer dryer - stops during dry cycle with all LEDs flashing amber
If your Hotpoint FDEU 9640 washer-dryer is stopping prematurely during the dry cycle with all the LEDs flashing amber, it could be caused by a few different issues:
  1. Check the filter: Make sure the filter is clean and not blocked. A blocked filter can cause the machine to stop working properly.
  2. Check the venting: Make sure the venting system is clear and not blocked. A blocked vent can cause the machine to overheat and stop working.
  3. Check the heating element: If the heating element is faulty, it can cause the machine to overheat and stop working.
  4. Check the thermostat: If the thermostat is faulty, it can cause the machine to overheat and stop working.
  5. Check the control board: The control board controls the various functions of the washer-dryer. If it is faulty, it can cause the machine to stop working.
  6. If none of the above steps work, it is possible that the machine has a more serious problem that requires professional service.
It is important to refer to the user manual or contact Hotpoint technical support for further assistance and specific troubleshooting steps for your washer-dryer model. It is also important to make sure the machine is not plugged in before attempting any troubleshooting steps. It is also important to note that it is not safe to use a multimeter to test any of the heating element or thermostat
1/17/2023 6:51:02 PM • Hotpoint Washing... • Answered on Jan 17, 2023
Replace bearing Hotpoint aqualtis aqd970f 69 eu
It is possible to replace just the bearing on your Hotpoint Aqualtis AQD970F 69 EU washing machine, however, it can be a difficult and time-consuming task. The best course of action would be to consult the manual for instructions on how to replace the bearing, or watch a YouTube video that specifically relates to your model. You may also be able to find the necessary parts on websites such as Amazon or eBay. However, it is advisable to get the help of a professional technician to do the job if you are not comfortable with performing the repair yourself.
1/17/2023 4:36:47 AM • Hotpoint Washing... • Answered on Jan 17, 2023
Hotpoint washing machine my washing machine key sign keeps flashing machine not working
How to remove the Key Symbol or Lock symbol off a Washing Machine.:watch video.!!!
1/10/2023 9:40:19 AM • Hotpoint Washing... • Answered on Jan 10, 2023
Hotpoint HTWP1000MWW 3.3 cu ft Top Load Washer Logo
3 questions posted
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
hotpoint wml730 washing machine replace
  • Washing Machines
