20 Most Recent
Sony VAIO PC Desktop Questions & Answers
Sony VAIO VGC-RA810G Desktop overheats and
Following are the reasons for overheating, just take care of these things::- Clean the Processor fan, Heat Sink and other peripherals- Use High Speed fans- Use CPU Heat Sink Paste in the processor- Stop Overclocking your CPU- Make sure your Heat Sink is placed properly above the processor- Make sure your dint restrict the speed of CPU fan.- Use Additional Cooling Units- Shut down your computer at least two hour a dayFinally i will suggest you to get system utility program like PC Fresher. because it is a very useful tool that cleans your computer of temp files, history and cookies. Its also used to fix any registry errors that cause of overheating
One time cooling fan caused
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Forgot password for computer
You can remove or change the Window's User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD.
Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions.
There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram.
Click on one of these links todownload HIREN'S BOOTCD :-
http://www.hirensbootcd.net/
http://67.20.82.163/
I wiped off my computer keyboard and did npt
You might have put the computer into hibernate; have you tried pressing the power button? It should wake the computer up if it is asleep or hibernating. It is also possible that your monitor cable is unplugged.
My taskbar is too big
this issue might with screen resolution.
You can adjut this screen resolution by Right click on the desktop->Properties->settings tab. There you can find the screen resolution setting.
adjust that settings to 1024X768 and press Alt+A to apply.
After finishing this it will prompt you for confirmation and now you need to click on "Yes" so that this setting will save.
I want to switch it my monitor from HD15 Mode to
Assuming you have not already upgraded the system, you will need to add a video card with DVI output to your computer. You need a PCI-e x16 card and to make sure to either upgrade your power supply or choose a card that will not exceed the power supply's capacity. The original Power supply provided 305W (max.).
The alternative is to simply attach a DVI to VGA converter and stick with the on-board VGA only output but send it through the DVI port on the monitor.
I hope this helps.
(you should pay attention to heat issues if you add a video card; I've generally found that ATI cards run a bit cooler than nVidia cards for the same generation/performance.)
How do i fix my USB ports?
Try reinstalling the Drivers, Goto the Manufacturers Website, Pull Up the model and Find MOBO Drivers or if their is one for a USB Hub
Out of memory at boot up whats up?
You are loading too many TSR's ( Terminate and stay Resident ) Drivers and probably a lot of **** that adware and spyware have thrown into your start sequence.You can go to BIOS and change your Boot sequence to 1st CD 2nd Floppy 3rd HD. Put your original CD/DVD into the drive and boot. It will say " hit a key to boot from CD " hit a key. You will boot to operating system where you can go to " RUN " type SYSINFO and change some of the foolish things that are loading. Be aware, do not delete the lines, but put a REM; in front of the line. Just in case you needed that line you can take out the REM
Need drivers for video and audio for a Sony
Sony is the worst about updating drivers or keeping them on their support site. Keep this in mind for future purchases.
If you are running windows XP SP3 or higher you can pull the device ID's and Vendor ID's from the device manager. With those ID's you can goto www.pcidatabase.com and lookup the device and vendor id and see who made the sound and display adapter and what model it is.
Then you can goto the respective vendors website and download drivers directly. This doesnt always work depending on the hardware but it's a good place to start.
Good Luck
