20 Most Recent Sony VAIO VGN-N130G/W Notebook Questions & Answers
sounds like the fan in your laptop is failing or is damaged, when you run graphic intensive applications and the fan turns on is that then you hear the noise if so it is your fan and you should see about getting it replaced because the components in your laptop will over heat and stop working.
Sony VAIO... | Answered on Nov 30, 2018
See this forum post. or this one.
You can uninstall the Vaio VSC Vaio survey program from the control panel>programs & features list. If you want to keep the survey program sony put on your system, but don't want it to run, remove it from the startup list.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Hi, I wrote my opinion to fixya, telling them that I do not think your ban is a good decision, and that I do not agree. In the past I have sent them three complains about your solutions, but I never asked or suggested any ban or similar measure.
I do not think my complains had influenced the decisions taken by fixya, but just in case I wrote them a message stating that the complains were not minimally suggesting such a measure as a ban.
by the way, if the ban had been determined only by bad solutions (I am sure more experts, including Ekse reported more abuse), then you can ask a reintegration promising them to improve the level of service.
try it with toggle keys it may be work
Sony VAIO... | Answered on May 03, 2017
Have you checked to ensure the WiFi switch is turned on? The computer with the red X is typically to let you know that connection is off (or in the case of the port that there is no hardline). Basically the 2 computer are one hardline, one wifi. Make sure the WiFi switch is on. It is usually a physical switch on the front for Sony laptops.
Sony VAIO... | Answered on Jan 06, 2015
try double clicking the icon
Terry
Sony VAIO... | Answered on Nov 12, 2014
Get that from Sony's web site.
Sony VAIO... | Answered on Feb 01, 2014
Contact Sony WEB site support, they can supply a recovery CD.
Sony VAIO... | Answered on Dec 17, 2013
First, please confirm that your laptop has Windows 8. If so, we need to know what password it is you have forgotten. Is it the password the one for Windows 8 where you have a mostly blue screen and a white box in the center for your password?
Sony VAIO... | Answered on Sep 25, 2013
i wouldnt say you doing anything wrong it just myt not be able to read other ones have you tryed it on anything els
Sony VAIO... | Answered on Dec 05, 2012
What OS are you running on your machine???
If your have XP installed then you can update the drivers from your device managernselectt device right click and update.
If you don't have the disk then let the wizard find the correct drivers for you,point the wizard at the c drive or search the internet with windows assistance.
Have yoiu had any updates upgrades or device changes???
This sometimes effects them too.
Remove & reinstall ist the only way sometimes,,,,,
A format may take care of this issue also so back up your stuff and start again
Hope this helps ,please rate me thanks
Sony VAIO... | Answered on Nov 28, 2012
Get a can of compressed air or an air compressor and clean out all the vents and fans. You can also use a vacuum with a hose attachment to clean it. You also might want to get a laptop cooler.
Sony VAIO... | Answered on Aug 19, 2012
So far I see no problem. For some reason. you chose to boot Windows in safe mode. During that boot mode, the screen goes black and starts displaying lines of text detailling all the drivers it is loading. At the end of the process Windows will run in safe mode.
Try rebooting normally or rebooting to the last good configuration that worked.
If there are problems please be more specific.
Sony VAIO... | Answered on Jul 07, 2012
The button must be defectedYou will still be able to raise and lower the volume within windows. Seeing that this is a fairly new laptop and should be under warranty, you should contact Sony and they will give you the information how how to replace that component.
Sony VAIO... | Answered on Nov 17, 2011
Sadly, RGB cannot carry sound. In order to hear the laptop sound on the television, You'll need to get an 1/8" headphone connector to RCA (White and Red plug) cable and connect it to the same input as the video is plugged in.
Sony VAIO... | Answered on Aug 24, 2011
Sony VAIO VGN-N130G/W Notebook Logo
221 questions posted
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
sony vaio
  • Computers & Internet
