20 Most Recent
Sharp Actius MP30 Notebook Questions & Answers
Lost wireless capability
You need first to check if the wireless adapter is installed properly, Ricght click My computer>Properties>Hardware tab>Device manager>look for network adapter and check if the wireless adapter is listed if its there right click on it and go to properties and check the device status..
If the adapter is not showing under network adapter look for anything that says Unknown or other device and you that's where you can find a improper installed device you just need to install the driver for that.
Hope that helps........
Sharp actius mp30 hard drive replacement?
It is a standard 2.5" IDE laptop drive. You have to dis-assemble to mother board. Easy to do if you are comfortable with internals. You have to remove a million screws to get case apart. All visible on bottom, also internal pc card next to memory card has 2 screws. Don't forget back side hinge screws and edge screws on upper part of lower shell visible in back and when dvd/cd is pulled (2 bottom screws hold player in. The shell come apart easily little force no tricky pressure or lock taps. Where it hinges on back top side next to LCD screen lift gently straight up this is where it is most resistant. A few ribbon cables and 2 wire cables to disconnect. After lower case top is off a few screws holding mother board (arrows) needs to be removed to lift motherboard. Drive is connected to mother board by ribbon cable lift pry gently up to release it. Drive is held in by 4 screws. Good luck. If you do not want to do this just get a 2.5" usb drive. You can buy the drives and external case or by already made ones e.g. WD passport.
BTW I am looking for an actius mp-30 casing, mine has damage.
If you have any questions post to contact me
No Display from LCD
Try to find the button that tells the screen to come
on. This sticks sometimes on laptops. I always tell people not to
use canned air because it only blows dust around, but it could help your
problem. If you are okay with taking it apart you can find this button
and see if it is sticking. This is becoming a common problem with
laptops. I recently had a customer with this problem and it took me some
time to figure it out. It is usually around the hinge. Look at the
manual if you can't find it.
Sharp actius mc24
Do you know how to flash the BIOS? This could trigger it. Are you sure that it can accept the hard drive. Does the hard drive have jumpers on it? This should be on master if it does have one. Although not common on laptop hard drives it could have one.
Defective Fan
go to the youtube there so many video about disasemble of laptop...
Sharp HT-SB140 Sound Bar Internal PSU died
The Sharp HT-SB140 Sound Bar's internal PSU provides a DC output voltage of 19 volts. So you would need an external power supply that can provide a regulated DC voltage of 19V with the same or higher current rating as the original power supply.
When replacing the internal power supply with an external one, it is essential to ensure that the polarity of the output connector matches the polarity of the soundbar's internal PSU. The PW390-070 EF25 MF 1945 part number indicates that the power supply has a center-positive barrel connector. Therefore, you need to make sure that the replacement external PSU also has a center-positive connector.
It is also essential to make sure that the external power supply you choose can provide the same or higher power rating as the original internal PSU to ensure proper operation of the soundbar.
My Sharp xe-a506 register will not power on. Checked the power source and nothing.
If your Sharp XE-A506 register will not power on, there are a few possible reasons why this may be happening. First, check the power cord and ensure that it is securely plugged into both the register and a working outlet. If the cord is damaged or not properly connected, it may be preventing the register from receiving power.
If the power cord is in good condition and properly connected, the problem may be with the register itself. Try unplugging the register, waiting a few minutes, and then plugging it back in. This can sometimes reset the register and allow it to power on.
If the register still does not power on, there may be a problem with the register's internal power supply. In this case, it is best to contact Sharp customer support for assistance. They should be able to provide you with further guidance and help you troubleshoot the issue.
