20 Most Recent Sharp Actius RD10 Notebook Questions & Answers
0answers
NEED REPLACEMENT BATTERY
Do a google search for the battery using the model number on the battery.
11/19/2012 4:26:27 AM • Sharp Actius... • Answered on Nov 19, 2012
Skype ver is 5.1.0.112. my
This sounds like a network problem and not a computer problem
Try again with someone else to verify
4/20/2011 4:04:23 PM • Sharp Actius... • Answered on Apr 20, 2011
Wants to install reboot disc
If you're looking to reinstall your operating system, you need to first turn on your computer and put the disc in the CD-ROM drive.
Then, turn your computer off. Turn it back on with the disc inside, and it should give you an option to "boot from disc" or something similar. Choose that option, and it will guide you through a step-by-step procedure to reinstall the operating system. This may take quite a while.
3/21/2011 9:30:04 PM • Sharp Actius... • Answered on Mar 21, 2011
How to find a battery
The p/n is printed on the battery label. Just search that part on ebay or google, you'll probably get a lot of results. You could also send an email to sharp if you don't have the original battery to obtain the P/N
12/30/2010 10:17:13 PM • Sharp Actius... • Answered on Dec 30, 2010
2answers
Ram type for Sharp Actius Pc-RD 10 notebook
My Frenn Don't Bother Yourself, Issues With Your Laptops Doesn't Worth That. Use The Link Below For Your Laptop's Specifications..
http://laptops.alege.net/comments/5893/
You Need To Contact Manufacturer Of The PC To Buy The Parts ..
7/5/2010 3:35:04 PM • Sharp Actius... • Answered on Jul 05, 2010
My ACER Aspire 5573ZN is not giving sound
Quite a few things to try
  1. The Volume is down or muted - Look at the system tray - righthand bottom - look for a speaker icon and click to see if muted or down.
  2. Start>control panel> sound - see if anything is muted
  3. Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type devmgmt.msc - look for sound devices, click on the + sign make sure a sound device is listed
  4. Re-install the sound driver from the Acer Support site for that machine here http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
  5. This should be a direct link to the realtek driver - XP & Vista - NO driver listed for windows 7 http://global-download.acer.com/GDFiles/Driver/Audio/Audio_Realtek_6.0.1.5413_VistaX86.zip?acerid=633638854618740888&Step1=Notebook&Step2=Aspire&Step3=Aspire%205570Z&OS=V10&LC=en&BC=Acer&SC=PA_6
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
3/31/2010 1:41:24 PM • Sharp Actius... • Answered on Mar 31, 2010
Sharp Actious RD10 notebook power supply pin out diagram
You will get a better response if you pay for the expertise we have to offer!
6/24/2008 8:55:28 PM • Sharp Actius... • Answered on Jun 24, 2008
Automatic shut down
ur registry files may corrupt please reinstall OS
9/29/2013 2:31:49 PM • Sharp Actius... • Answered on Sep 29, 2013
Sharp HT-SB140 Sound Bar Internal PSU died
The Sharp HT-SB140 Sound Bar's internal PSU provides a DC output voltage of 19 volts. So you would need an external power supply that can provide a regulated DC voltage of 19V with the same or higher current rating as the original power supply. When replacing the internal power supply with an external one, it is essential to ensure that the polarity of the output connector matches the polarity of the soundbar's internal PSU. The PW390-070 EF25 MF 1945 part number indicates that the power supply has a center-positive barrel connector. Therefore, you need to make sure that the replacement external PSU also has a center-positive connector. It is also essential to make sure that the external power supply you choose can provide the same or higher power rating as the original internal PSU to ensure proper operation of the soundbar.
2/22/2023 5:48:36 PM • Sharp Computers... • Answered on Feb 22, 2023
What does error code d stands for in sharp photocopier at m 205 and what's the solution?.
Error code D on a Sharp photocopier at M 205 indicates a problem with the drum unit. To resolve this issue, you will need to replace the drum unit. You can purchase a replacement drum unit from an authorized retailer.
1/29/2023 8:34:51 AM • Sharp Computers... • Answered on Jan 29, 2023
My Sharp xe-a506 register will not power on. Checked the power source and nothing.
If your Sharp XE-A506 register will not power on, there are a few possible reasons why this may be happening. First, check the power cord and ensure that it is securely plugged into both the register and a working outlet. If the cord is damaged or not properly connected, it may be preventing the register from receiving power. If the power cord is in good condition and properly connected, the problem may be with the register itself. Try unplugging the register, waiting a few minutes, and then plugging it back in. This can sometimes reset the register and allow it to power on. If the register still does not power on, there may be a problem with the register's internal power supply. In this case, it is best to contact Sharp customer support for assistance. They should be able to provide you with further guidance and help you troubleshoot the issue.
12/10/2022 12:46:39 AM • Sharp Computers... • Answered on Dec 10, 2022
2answers
I need the serial number for my sharp copier/printer model number MX C402sc
You will only find that information on the original box it came in, or on the original sales invoice. Other than that, a Sharp engineer might be able to hook up a laptop to it and read it from the EPROM (its programmed memory, the one you are fighting) inside the printer.
11/10/2022 4:09:47 AM • Sharp Computers... • Answered on Nov 10, 2022
Please where is the edit button on sharp zq-520
The E key functions as the Edit key apparently and you press the 2nd key located at the bottom left. https://www.manualslib.com/manual/546173/Sharp-Zq-520.html?page=9#manual
11/8/2022 6:03:03 PM • Sharp Computers... • Answered on Nov 08, 2022
Sharp MX-M356N - CE-00 error.
The fusing unit is defective. Replace the fusing unit.CODE CE-00CE-00CE-00CE-00CE-00CE-00CE-00CE-00CE
11/5/2022 8:01:18 PM • Sharp Computers... • Answered on Nov 05, 2022
Sharp mx-m310 error code F9-10
Find out what the code means and repair the fault .
8/11/2022 4:57:23 AM • Sharp Computers... • Answered on Aug 11, 2022
Which specs has the RAM modul in a Sharp UP 810F ?
the manual should cover that, read it yet? it is not a computer at all posted to computer repair help. forum is is Point of Sale terminal, old name Cash Register. age 2008 , only clue is setting date example, RTM) so is 14 years old. not problem stated at all and wants more memory to do what not told, my wild guess is the P O S terminal has amnesia.? it forgets, and you did not read page 3 in the manual these words This POS terminal uses a nickel metal hydride battery pack for memory protection.The battery pack must be replaced at least every three years at the user's expense. this is RECHARGEABLE battery when fails memory dies. until replaced. just line on PCs the coin cell dies, same pain rtm https://www.manualslib.com/manual/324826/Sharp-Up-820f.html?page=3&term=memory&selected=4#manual there is no memory upgrades here, but if do, ask the maker for support. and my be super costly that, a new main board. the list of options from sharp are: this model. For your UP-800F/810F POS terminal, the following options are available: For details, contact your authorized SHARP dealer. Do not try to install any options yourself. 1. External printer model TM-T88III/T88IV, TM-U220/230 or TM-U295* 2. Remote customer display model UP-P20DPB 3. Remote drawer model ER-03/05DWB 4. Remote coin case model ER-48CC2, ER-48CC3 or ER-58CC 5. Remote coin case cover model ER-01CV1-5, ER-02CV1-5 or ER-03CV 6. RAM memory board model UP-S04MB2 (says extra) 7. Magnetic card reader model UP-E13MR3 8. EFT interface model UP-I04EF 9. Contactless clerk keys model UP-R10CL2 * The external printer TM series are not SHARP products there may be 2 choices. now. ask maker SHARP for SUPPORT UP-S04MB2 / S08MB2 Expansion memory board (4MB / 8MB)
7/1/2022 12:22:13 PM • Sharp Computers... • Answered on Jul 01, 2022
Does the Sharp MX-3040N support TLS Security for scan-to-email? I checked the network services and all I saw was a check box to Enable SSL.
It looks like the answer is No. https://www.google.com/search?q=Sharp+MX-+%223040N%22+support+TLS+Security+for+scan-to-email Are you sure you have that model number correct? It isn't showing for a manual and reducing the search query to 'Sharp MX-3040N shows nothing! https://www.google.com/search?q=Sharp+MX-3040N+manual .. ..
4/27/2022 2:03:26 AM • Sharp Computers... • Answered on Apr 27, 2022
Sharp EL-1701C - display issues
No you can buy a used one from eBay $10.00
3/30/2022 8:08:53 PM • Sharp Computers... • Answered on Mar 30, 2022
Sharp Actius RD10 Notebook Logo
Popular Tags
11 questions posted
Top Sharp Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Ngoro
john h
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Actius Sharp
  • Actius Sharp
Most Popular Question
need replacement battery
  • Computers & Internet
