20 Most Recent
KitchenAid KUDC10FXSS - KitchenAidR Classic Series Dishwasher Questions & Answers
18 month old kitchen aid kudc10fxss leaks water at bottom of door
Someone may've accidentally put liquid dishsoap rather than dishwasher soap into the fill cup. The bubbling will cause lots of foam to rise up above the float-switch without actually raising the switch (shutting off the water supply). Lots of helpers on the web recommended draining, wiping out the foam, pouring in a cup of vinegar and a handful of salt and running the rinse cycle a couple of times. It worked for me!
Kitchenaid KDPM604KPS dishwasher stops minutes into cycle
I couldn’t find any error code 2H but I did find an error code H2O. This code means insufficient water pressure. If the display reads 2H, it usually means the start delay function is turned on. The dishwasher will turn on in 2 hours if door is closed. This dishwasher is advanced. To understand all operations you should read the user guide or manual.
10/13/2022 10:19:23 AM •
KitchenAid...
Answered
on Oct 13, 2022
What is the correct button sequence etc to do a panel reset on a kitchenaid KUDE60HXSS1
Pick any 3 consecutive keys (except Start or Cancel, then press them in the sequence 1, 2, 3, 1, 2, 3, 1, 2, 3. The dishwasher will go through a self-test and short cycle, and reset itself.
My child stepped on the
I had this exact same story with my new Whirlpool dishwasher. My daughter fell on the open dishwasher door and afterwards it wouldn't latch closed. After researching online, I learned that 90% of the time it's bent door hinges. At $$130 each, $260 total, I didn't want to replace the hinges. So I removed the hinges, took them downstairs to my shop, put them in the vise and straightened them back with a hammer. Just took a few good, solid hits on each hinge and they were straight again. I installed them back onto the dishwasher and it worked like a charm! Door latches just fine.
Rinse aid dispenser leaks
The dispenser needle valve is not seating properly and correctly causing it to be rinsing and also the aid to be leaking out water.
