20 Most Recent
Acer Veriton 5100 PC Desktop Questions & Answers
Acer desktop 5100 has power but wont boot up
The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact. Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
I need to knows the
you just plug it in port thats all you have to do it gose in the back of your pc if you have a place in the front it will have a small door in front or side some do jim
No sound is coming from my external computer
Hello....
No Sound, No Volume Control, Mixer not Found, No Sound device installed…etc etc, This is a generic issue with all Windows OS updates....many of the users are facing this issue....this issue began after an auto update from MS changed many IRQs of Win OS, mainly the Sound and Audio Control system of Windows.
1 - R U facing NO Audio / No Sound issue...?
2 - Is ur Volume Control not responding ?
3 - Is ur Sound and Audio Device in Control Panel Grayed out ?
4 - Do u get a msg "No Active Mixer Devices Installed....when u try to open Volume Ctrl etc etc ?
If ur ans to any one of them is Yes...then u are being spammed by Microsoft....as ur Sound Control IRQ is being frozen by a recent update from Microsoft....
NOTE..THIS…IS…VERY..IMPORTANT...
No file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it…or giving any help on this.
Full solution is available in my website (Support page)...it's quite simple process to fix it, and I am not charging any money, just trying to do some service and help everyone affected by this stupidity from Microsoft.
www.sureshayyar.110mb.com
visit my support page.
all the best...
Iwant to install an extra 1GbRAM-what specs/Pt Nos
Hello
Thank you for using FixYa for your problem
Sorry but on there website max is 512MB of ram
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
I have 3 hard drives in my acer that are
Short and quick if the bios can see them but your operating system can't, chances are that either the format is wrong or the disks are not formatted at all.
In windows go to control panel
Administrator tools
computer management
disk management
This will bring up all the hard drives, logical drives and any other type of drive that you have hooked up. Find the drives you are looking for see if the operating system can see them, if it can it will tell you what the format is or even if the disk is formatted. From there you should be able to find your way.
Hope this helps
I cant start up my PC
try reloading windows program again is usually the first option
we dont want you to go off on to deep and lose all of your data and files
please try the above then get back to me
if you answer in this post it will notify my mobile
but just in case
[email protected]
cheers
I have been given a acer veriton 5100 it has a
"Ubuntu" is a Linux operating system, not a Windows operating system. It will not run any windows programs or autoplay any windows CD's unless you have an "emulator" or hypervisor installed, which is not by default.
Here is a link to the Ubuntu website that you can browse to find out more information on that Operating System - http://www.ubuntu.org
There you can research the running of a Windows emulator called "WINE" (much to detailed to get into here). Or you can purchase a 3rd party hypervisor, such as VMware Workstation, that will run a virtualized copy of a Windows operating system (such as XP) inside Ubuntu.
Long story short - you cannot use your Windows disks in this laptop with Ubuntu operating system installed without a add-on emulator or program.
Windows Mail not responding
try going to
www.majorgeeks.com
download
flashpeak slimbrowser
hope this works for you
or get onto microsoft for further guidance
may be re installing the program again will solve it too
Regs
Drewdotcom
Windows Mail
Hi, this fix was on a website I found & may help..
This problem happens because your version of Outlook Express is set up to use Secure Socket Layer (SSL), which your ISP does not use.
To fix this problem, open Outlook Express, and click:
- Tools
- Accounts
- Then click on your connection and click Properties
- Then click Advanced
- On this screen remove the checks from the boxes This server requires a secure connection for both Outgoing mail (SMTP) and Incoming mail (POP3).
You may have to play with the settings a bit to suit your setup.
Rgds,
Windows Mail
Whatever 'Windows Mail' you are using, I guess you have checked all the config. options? I mean if you are using Outlook Express, then go into 'Tools' then select accounts, then select your isp's account details (if they are not there, thats your problem) then click Properties. Under the general tab should be your ISP's mail server details, your user name (below that) & your email address. Next the 'Server' tab.. shud be info relating to your ISP. If you do not use Outlook Express, consider setting it up as a test. Do it manually as per above. If you need further help, let me know. Rgds.
ON INITIAL BOOT UP
Does it give you a command prompt,example c:/?If so type chkdsc and this will scan the hardrive for boot errors.Let me know.
Help
If you are still having troubles, try this.
Click on start> run> type in msconfig> ok>
click on the boot.ini tab> make sure the safeboot box is not checked.
