20 Most Recent Acer Veriton M460 Micro Tower Core 2 DUO E4500 2.2GHz Dvdr GigaBit Ethernet Wvb VM460UD4501 PC Desktop Questions & Answers
3answers
2answers
Acer veriton m460 won't turn on fan runs that's it
Power supply failure. Replace it. Get 50+ more watts than the original. Power supplies are inexpensive and can be replaced without affecting your operating system or programs.
BTW: Many "failed" power supplies still can deliver enough power to spin fans and turn on the lights.
I recommend: www.newegg.com
If this helps please vote for my solution.
2/17/2015 3:29:18 AM • Acer Veriton... • Answered on Feb 17, 2015
Problem with the monitor
hi, first of all,try to connect the cable to other device(laptop) to see if is working,because if you receive the message"No signal" then the monitor is working but the cable/signal did not cross to the monitor,then is working with other device then try again or check if you can connect the monitor with different port if you monitor has one vga/dvi or hdmi.
8/26/2014 10:32:37 AM • Acer Veriton... • Answered on Aug 26, 2014
Ports not working
Do you hear the hard drive seek?
5/16/2014 8:40:45 PM • Acer Veriton... • Answered on May 16, 2014
Here are my specs. Can i put an Intel E5800 on my machine?
Yes Intel E5800 will work but you may not be able to use Turbo boost and Hyper threading. over all it will perform nice.
1/22/2014 5:43:28 AM • Acer Veriton... • Answered on Jan 22, 2014
Intel E5800 wont work with Acer Veriton M460 SPECS BELOW
eric, Belarc will give you a comprehensive picture of your computer. GL
1/22/2014 5:30:30 AM • Acer Veriton... • Answered on Jan 22, 2014
ACER who has a direct phone number I can Call to talk to a tech?
I left you the online link to get that phone number. If you don't want to do that, give me the model number your acer's specs and I can figure that out in about 2 minutes. I don't sell computers, but at today's prices and depending on how valuable your rig is, sometimes buying new is better. Also, a lot of box stores offer free advice when you take your computer in to them, though call first.
1/22/2014 3:49:30 AM • Acer Veriton... • Answered on Jan 22, 2014
How do you get to the motherboard battery
To get to the motherboard battery just open the side panel on the case and look for a button shaped round battery on the motherboard. It's a little bigger than a nickel and is silver in color. It will have the number 2032 on it. Just pop it out of its slot and replace it.
1/7/2013 1:19:12 AM • Acer Veriton... • Answered on Jan 07, 2013
Ethernet controller veriton 1000 driver
Download here:http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=415Please unzip the file when downloaded
11/6/2012 9:31:46 PM • Acer Veriton... • Answered on Nov 06, 2012
Restarting
If the PSU power supply units fan is not working the PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Test all power and data leads that attach to your hard drive IDE,SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have secure dust free connections and are not faulty or just replace them they could be faulty motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
make sure all leads that are attached to your drives dvd\cd floppy have secure dust free connections and are not faulty or just replace them they could be faulty a computer needs
power and data to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty power lead or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
you might not have enough computer ram
not having enough computer ram will run your computer over its limits putting to much strain on the CPU central processing unit and can cause memory dumps
you might have to many programs trying to or accessing the internet at the same time scroll to bottom toolbar (bottom of screen) right click select task manager applications you will see whats running if you see anything you dont need running select end now and you might uninstall that specific program if you or computer does not require it to run and some unnecessary programs that could be jamming up your computer also under processes see what is ticking over in the background again if you see something you dont need to be and users you will see who is using your computer you might need to add more computer ram if you're not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility of the ram before making any purchase
might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
hope this helps
9/20/2012 10:34:11 PM • Acer Veriton... • Answered on Sep 20, 2012
How to find drivers for my motherboard
You can try this website for drivers http://www.driverguide.com/it`s very helpful.Serial # should be on the desktop pc somewhere under it.
7/14/2012 1:27:09 PM • Acer Veriton... • Answered on Jul 14, 2012
3answers
I have a few program installed before but now already delete. So how to delete the program by via Regedit? @_@
best way:
Switch On your PC/ Laptop and log in to windows. Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear. Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot. After reboot your problem should be resolved.
12/19/2011 4:45:07 AM • Acer Veriton... • Answered on Dec 19, 2011
2answers
Motherboard EG31M
test all leads that attach to your hard drive including electrical extensions IDE SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty if its a 40 pin ide it will be the first to fail make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
also check your computer ram modules and cmos battery to make sure they are dust free and securely seated and the battery has plenty of charge Cmos battery on some motherboards are soldered in
hope this helps you
11/21/2011 2:33:55 AM • Acer Veriton... • Answered on Nov 21, 2011
Hi.. can u help me?
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause you problems
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
hope this helps you
11/18/2011 6:43:48 AM • Acer Veriton... • Answered on Nov 18, 2011
Acer Veriton M460 Micro Tower Core 2 DUO E4500 2.2GHz Dvdr GigaBit Ethernet Wvb VM460UD4501 PC Desktop Logo
52 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Veriton Acer
  • Veriton Acer
Most Popular Question
acer direct phone number call talk tech
  • Computers & Internet
