20 Most Recent Canon BubbleJet i9950 InkJet Photo Printer Questions & Answers
4answers
Error 5200
Sir,
Go through this link and check out
Thanks Good Luck
Appreciate to rate as "Fixya"
11/1/2021 5:37:49 AM • Canon BubbleJet... • Answered on Nov 01, 2021
Why can't my i9950 printer Work as it did before?
panal board replace
1/19/2015 6:15:48 AM • Canon BubbleJet... • Answered on Jan 19, 2015
Get canon printer driver for windows 7
I do not know that printer but try the cannon website under support.
8/24/2014 9:55:19 PM • Canon BubbleJet... • Answered on Aug 24, 2014
4answers
Canon i9950: Full waste ink absorber
Dhedik maybe this action can solved your problem Reset Waste Ink Counter printer Canon i9950 :  1. power off  Printer
2. Push and hold resume  button and push power button
3. Hold  Power button and release Resume  button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and  stop.
6. When green light on, push resume button 4 x
7. Push  Power button and printer will off, if that isn't off, push power butto again until print off position.
ok good try, don't forger to vote me, Fixya
8/17/2014 1:10:59 AM • Canon BubbleJet... • Answered on Aug 17, 2014
0answers
How
Be the first to answer 7/8/2014 8:30:02 AM • Canon BubbleJet... • Posted on Jul 08, 2014Be the first to answer
0answers
Won't print service sheet. The printer is flashing 5 orange. I have been round the loop of using the power and resume buttons.
I would update the firmware, this normally fixes those type of issues.
6/5/2014 12:45:44 PM • Canon BubbleJet... • Answered on Jun 05, 2014
I can not get Yellow to print
Personally I would just take out the print head and flush it through with warm water. When it is clean, add all the inks and run it through the clean print heads utility, until the test sheet looks correct. Another point, do not ever switch off the printer, as it cannot periodically clean itself. If it cannot clean itself the print heads can dry up and become clogged.
6/5/2014 12:43:35 PM • Canon BubbleJet... • Answered on Jun 05, 2014
Printer out of line
If you're referring to color alignment, there is a utility in the settings menu to calibrate it. You can also check online at Canon's web-site for calibration information.
5/19/2014 4:30:40 AM • Canon BubbleJet... • Answered on May 19, 2014
How to clean out the ink bin on canon i9950 please
follow my link below to another fixya solution that may resolve your problem also, as it lists waste ink reset instruction for many canon printers there. waste ink reset instructions
12/29/2013 11:56:26 PM • Canon BubbleJet... • Answered on Dec 29, 2013
0answers
4answers
Canon i9950
Seems impossible to reset the counter, is there a way to manually reset?
1/14/2013 2:01:54 PM • Canon BubbleJet... • Answered on Jan 14, 2013
Canon i9950 inkjet printer, keeps showing paper
Maybe it's just one small paper.
If it's on guarantee, take it to store, and describe the problem like this:
"Cant print. Don't know whats going on!"
So they don't charge you ;)
If it's out of guarantee, try to open all parts until you see the small paper.
Or it could be the sensor (piece of plastic) that was jammed, or get jammed when paper pass. Take a good look on that too.
10/8/2012 8:39:04 AM • Canon BubbleJet... • Answered on Oct 08, 2012
Can I reset the EEPROM of a canon print head?
Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
you done.
9/5/2012 12:33:07 PM • Canon BubbleJet... • Answered on Sep 05, 2012
Canon BubbleJet i9950 InkJet Photo Printer Logo
63 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
BubbleJet Canon
  • BubbleJet Canon
Most Popular Question
canon i9950 full waste ink absorber
  • Office Equipment & Supplies
